Old 01-07-2010, 04:44 AM   #1
D3878's Avatar
Default Help with Gear Ratios?
Can someone explain gear ratios? I have a TC5 looking to get started with.
Cisco Systems: The Human Network
TC5 FT / Spektrum DX3-S / Mamba Max Pro ESC 5700kv
D3878 is offline   Reply With Quote
Old 01-07-2010, 08:13 AM   #2
gacjr0's Avatar
Trader Rating: 15 (100%+)
gearchart.com is useful, mute your audio before using it though.
Excel is a powerful tool for figuring gearing.
For what you have listed, tc5/mamba 5700/assuming rubber tires, I would start at 6.5 FDR.
FDR = spur/pinion * transmission ratio.
Be prepared to go higher/lower with pinions based on heat/speed needs.
-Dangerous with power tools-
gacjr0 is offline   Reply With Quote
Old 01-07-2010, 08:26 AM   #3
trerc's Avatar
Trader Rating: 89 (100%+)
So to help you out a little more the TC5 has 2.0 diff ratio so say you running a 120t spur (64p gears) and a 37 pinion. You'll take 120 divided by 37 (spur/pinion) multiply that number by your diff ratio (2.0) and it will give you your FDR (final drive ratio) which in that case would be 6.49
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 01-07-2010, 09:27 AM   #4
gashuffer's Avatar
Trader Rating: 48 (100%+)
Very good reading. Enjoy.
gashuffer is offline   Reply With Quote
Help on gear ratios jamie814340 Electric On-Road 8 12-28-2005 08:31 AM
Gear ratios N15M0 Rookie Zone 14 10-06-2005 04:36 PM
SEO by vBSEO 3.5.0
