LRP SXX StockSpec ESC
#1021
My apologies as I just found the answer, in case anyone searches this topic I will leave it up.
Taken from the SXX Version2 manual, SXX StockSpec ESC states the same that mode #0 will disable all boost:
"MODE.3 (Dual ADPC MOD - "Boost"): the "Boost" adjustment is LRP‘s active motor timing system, depending on many different factors (current, throttle position, RPM, etc) the software calculates the perfect commutation.
MODE LED #0 #1 #2 #3 #4 #5 #6 #7 #8 #9 #10
Yellow/Red disabled Going from mildest to most aggressive timing profile (value 1 = minimum / value 10 = maximum) (alternate)
Caution: too high "Boost" values increase motor temperature excessively and in the worst case may damage your motor, make sure you find the best performance by increasing values step by step carefully!
Advise: if value #0 is chosen for Mode.3 the blue LED will flash in neutral position in normal operation to indicate that entire timing advancement is disabled completely for "true stock racing" as required by certain federations!"
#1022
PDF V2 Manual
Just cruising thru it, I hope they update it to have more than just boost for stock. Gotta run stock for the winter carpet season, but for all I care, if I have close to the same motor as the tekins ill be happy. How many people run the stock spec X-12's? I have heard they are fast. If they can take the heat like the X-12 mods then I imagine they will be fast.
#1023
nosram 90910 is the same as the SXX ss mk3, the 90955 is the same as the SXX version 2 (newer updateable version)
personally, i wouldnt reccomend the SXX mk3. ive just had a brand new one fail with in 2 meetings.
practise was fine, went to switch on for first heat on sunday, nothing, no signs of anything wrong, (switch, wiring problems etc) not smell.
pretty disappionted tbh
#1024
numbers
Numbers,,what do they mean?
At least the novak Kinetic with noivalink shows you "exactly" what you are changing...
On another note..Ran the sxx ss in 1/12 open using 5.5 ballistic...ran all day, never dumped and it was fast..brilliant 1/12 speedie
#1025
Something that has always puzzled me with RADIO/ESC SETUP- the required 'travel settings'. When the instructions ask for 100% travel of the throttle and brake, are they talking only set the travel %ages at 100% or are they talking 100% of the radios MAX travel %ages?
I hope I'm asking that right
#1026
#1027
#1028
#1029
Pretty sure it means 100% of what your radio is capable of. So if your radio end point goes to 150% you should set it at 150%. Its got something to do with expanding the amount of pulses to the speed control. A electronic whiz kid explained it to me once, he was very insistant that thats the way they should be set <---funny.
#1030
#1031
Pretty sure it means 100% of what your radio is capable of. So if your radio end point goes to 150% you should set it at 150%. Its got something to do with expanding the amount of pulses to the speed control. A electronic whiz kid explained it to me once, he was very insistant that thats the way they should be set.
I use a M11x by Airtronics and the end points go to 150%. I settup the SXX SS throttle end points to 100% and have not experienced any problems. I can not comment on other brand transmitters.
#1032
Yes it will work with no issues at 100%, the point is that expanding the end polint to 150% will provide additional steps in the pulse signal to the speed control. It basically smooths the steps in the wave signal, so it should make it a smoother throttle curve. Either way will work its just a matter of using the combo to its fullest capability.
#1034
I'm sure this has been answered before, how does this SXX stock-spec MKIII speed control compare to the Tekin(V203 or V208)? What features seem to be better? Anything thats not as good?
#1035
Is it better, I don't think its better or worse, not as programable, but if thats what your trying to get away from, then this is a good speed control. Pick a profile and go, if you nail the profile and FDR it can be a very fast combo, miss it and it will talk to you (cog), use that to tune and you can do well with it.
