LRP SXX StockSpec ESC
#886
Yep..2. 1 x novak 40mm high speed behind motor and 1 x 30mm high speed on alu heat sink on motor..
In my opinion..fans dont do too much when the motors are hot..Just carrying excess weight..
I will take off for winter and add for summer..Mainly for when u are sitting on the hot ashphalt...
#888
Took the LRP SXX SS Out for a run today and it's sh!t. Nothing but cogging issues with it. 2 laps it was fine and then 3rd lap it was a mess. Changed sensor wire, change gearing/ Changed it to No boost even and 1 feel and still the same!!!!
Brand new esc and this sh!t happens with a well known product. Not happy jan!!!
#891
Been searching but didn't find much. Just installed the sxx stock spec in the tc5. 17.5 duo. Looking for a safe profile and fdr. Little testing so far not on track and so far find myself at 0 6 9 2 with a fdr of 4.8. After 4 min of runtime I temp around 138 and the spedo had 1 flash for temp. I have retarted top end but think its useless on a small track of 80x60. should I aim for an fdr of mid 5's?
#892
#894
Gearing from the SPX means nothing with the SXX-SS, that is comparing a grape to an apple.
#895
SXX high speed brakes
Hi all..
How are people finding the high speed brakes, as to the SPX?
In my opinion..The sxx brakes suck,,,,
Getting the cheap arsed hobbywing...They say it has brakes..and its cheap..I have given up with the SXX...waste of cash, blows motors, and its not that fast...
Mike
Mike
#896
[QUOTE=Sean Cochran;7529058]Your gear and boost are both too high. I would start with boost around 6-7 and gearing in the 6s. I ran a SXX-SS with x-12 3/4/7/2 geared 6.45:1. this was on a 100 foot straight. Tried running gear at 5.9 the same night and 6.45was definately faster.
In my opinion..Its still way too low....I cooked all my motors using a bigger pinion...Start around 7-8fdr...
#897
#898
hey can someone give me an starting FRD with Profile 7, using and X12 17.5
on an 100 by 50 track... rubber tires Track is not too tight
#900
Your one of the lucky ones. Mine was faulty from the 2nd lap.
