Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 03-13-2004, 07:30 PM   #1
MugenMTX3Kid's Avatar
Send a message via AIM to MugenMTX3Kid
Angry Car still glitches!!! HELP
Hey, as some of you know, i posted "Car Glitching" or something like that before. Last time i put my GT7 in my Pro 3 and it glitches. Well i sold that Pro 3 and got myself a R2.
I got my pinion today and was playing in a tennis court with my friend on a yok (we dont have same freq or we never glitch before playing together). My car did the same problem as last time, abuot 30-40 feet away, the car starts to glitch. The antenna wire is not touching any graphite
I will put on my MX3 and see if it still glitches tomorrow.
If it still glitches, what else can make it glitch?!!
I will post a picture of the current car tomorrow.
MugenMTX3Kid is offline   Reply With Quote
Old 03-13-2004, 08:14 PM   #2
edseb's Avatar
Could be a number of things. Try to trouble shoot by process of elimination. Could be radio interference near by (does it glitch other places), try a diferent servo (Hitecs are known to glitch more often. Also the set screw on the horn can touch the circuit board in the servo and cause glitching), could be receiver (what kind are you using, cheapy), place receiver as far from servo as possible, could be numerous other things, isolate each electronic component.
XRC Magazine
Carl Hyndman
edseb is offline   Reply With Quote
Old 03-13-2004, 08:52 PM   #3
hmm, i could be screwing the screw on the servo horn too tight.. ill try that.
thanks
Old 03-13-2004, 08:59 PM   #4
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Try that
I told you to put the MX-3 on before, but you didn't listen
DOMOisCOOL is offline   Reply With Quote
Old 03-13-2004, 09:01 PM   #5
You told me that when i had my pro 3.
Old 03-13-2004, 10:29 PM   #6
Default glitch!!
dude just put 3 pieces of tape under the reciever and the speedo and make sure you dont have any burnt caps on you motors.. and also chk you reciever if your using the same one as last time .. that might just be your problem.. bad reciever..
M.B.
mb racer is offline   Reply With Quote
Old 03-13-2004, 10:47 PM   #7
3 pieces of tape? What is that for?
I am sure i am using the same rec. I onyl have 2, lol
Old 03-14-2004, 12:43 AM   #8
Tek Nickal's Avatar
Look at the endbell of your motor, see if the caps are black. They may be burned and you don't even know it, this would cause major glitching. Also, open the case of your reciver and check if there is any dirt. Try changing the crystals because crystals can be damaged if there is grit inside (if not any).
Tek Nickal is offline   Reply With Quote
Old 03-14-2004, 04:47 AM   #9
Rob Hochberg's Avatar
Send a message via AIM to Rob Hochberg
Aren't most tennis courts surronded by chain-link fence? One would think all that steel around you would definitely cause glitching..
Rob Hochberg is offline   Reply With Quote
Old 03-14-2004, 04:58 AM   #10
lee82gx's Avatar
almost everyone other glitching problem is solved by changing crystals(new ones)
lee82gx is offline   Reply With Quote
Old 03-14-2004, 05:55 AM   #11
jiggamacdaddy's Avatar
Send a message via AIM to jiggamacdaddy
I am having the same problem with my xray no matter what i do to try and get rid of the glitch. One of my friends who runs for novak told me that the older gt7 glitch from motor arching. He also, that now novak has found the fix. supposedly if u send it back to novak they will fix the problem for free by putting on a special capacitor.
hope the helps.
jiggamacdaddy is offline   Reply With Quote
Old 03-14-2004, 06:10 AM   #12
Definately try changing the crystals!! They can go bad from a hard crash or be defective. Believe me I found out the hard way.
kevinm is offline   Reply With Quote
Old 03-14-2004, 06:57 AM   #13
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
hope the helps.
How do you know if you have a old GT7 or not?
RKeasler is offline   Reply With Quote
Old 03-14-2004, 10:52 AM   #14
RKeasler-
IF you have the old GT7, the cap has no words on it (or sticker)
Rob Hochberg-
My friend was running his Yokomo with a Airtronics Blazer radio and it does not glitch
Everyone else-
Anyways, i changed to my Airtronics Receiver and tried it, guess what... IT GLITCHES!! I also tried loosening the screw on the servo and still glitches.
Will my KR 10x2 make it glitch because there is very little brushes left?? I might solder on my Stock motor.
Old 03-14-2004, 11:20 AM   #15
I changed to my Trinity GM3Pro and still glitches... im getting frustrated, this is what i did
1) Change my radio from Futaba to Airtronics
2) Loosening the screw on the servo horn
3) Changed my KR to GM3
What else can make it go crazy?
Forum Jump
Glitches on Servo NOVICE4EVER Singapore R/C Racers 10 12-04-2007 08:24 AM
Glitches intrance Singapore R/C Racers 9 10-24-2007 04:53 PM
BAD GLITCHES HELP TylerOwenby Electric On-Road 9 05-20-2007 08:40 PM
i drive a FT b4 and my car glitches, please help slimbob Electric Off-Road 2 08-23-2004 08:34 AM
Novak SS5800 glitches StoneMan Electric On-Road 11 06-08-2004 09:47 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
