Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 03-14-2004, 11:38 AM   #16
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Plugging in the wire from the ESC to the Rx backwards?
Servo might cause a problem too. Swap servos.
Can't Really think of anything else.
DOMOisCOOL is offline   Reply With Quote
Old 03-14-2004, 11:57 AM   #17
JusBox's Avatar
how old is your radio? it might need to be retuned.
JusBox is offline   Reply With Quote
Old 03-14-2004, 12:40 PM   #18
MugenMTX3Kid's Avatar
Send a message via AIM to MugenMTX3Kid
Ill try swaping servos
My futaba is 6 years old now, but it wasnt glitching when i had my Dually on.
My Airtronics is 2 years old now (MX3).
MugenMTX3Kid is offline   Reply With Quote
Old 03-14-2004, 02:42 PM   #19
Swaping servo still glitches, I can record a short video of it glitching if anyone can help.
Old 03-14-2004, 02:46 PM   #20
Regional Moderator
disaster999's Avatar
go to your hobby store..and try changing EVERYTHING..new servos, receiver, speed control, motor and radio...do the batteries if you have to
dont put it in your car and just let it run on the counter...if that still glitches, then i have no idea
disaster999 is offline   Reply With Quote
Old 03-14-2004, 02:55 PM   #21
Whoa, i wont buy all those things, and my hobby shop probably wont let me use it without paying.
Ill try to email novak.
Old 03-14-2004, 03:49 PM   #22
Send a message via AIM to Roberto Falcon
hmm sounded like a problem i had ... buy a new receiver and i know it will stop . cause mine use to do the same thing .. hope this helps !
CorallyUSA / Superior Hobbies / RC3 Grafix
Roberto Falcon is offline   Reply With Quote
Old 03-14-2004, 03:50 PM   #23
damn it cant spell for sh*t .... SOUNDS *
Old 03-14-2004, 04:10 PM   #24
Regional Moderator
Send a message via AIM to Mike F
Criss cross your motor wires, osrta like a figure 8. Don't change the neg to pos or vis versa but just criss corss the wires as many times as you can. Also, put one of those capacitors across the pos and neg motor post. The capacitors that we use to have to solder on the cans.
Mike F is offline   Reply With Quote
Old 03-14-2004, 05:04 PM   #25
popsracer's Avatar
Will my KR 10x2 make it glitch because there is very little brushes left?? I might solder on my Stock motor.
Bad/worn Brushes, Com in need of truing, WILL glitch!
Some Receivers are more susceptible than others, but you need a nice true com and good brushes no matter what.
popsracer is offline   Reply With Quote
Old 03-14-2004, 05:30 PM   #26
I changed from my Futaba to Airtronics and still glitches... wont changing to another reciever be the same?
I will try that criss cross.
Old 03-14-2004, 06:14 PM   #27
DOMOisCOOL's Avatar
We can meet up at RCtech or something and plug your ESC wire into my Receiver and go from there.
Old 03-14-2004, 06:15 PM   #28
Tek Nickal's Avatar
You can try my reciver and radio if you want. . . .
Tek Nickal is offline   Reply With Quote
Old 03-14-2004, 08:30 PM   #29
edseb's Avatar
Sorry my suggestions didn't help. They are just suggestions and a number of things can cause glitching. Good luck.
XRC Magazine
Carl Hyndman
edseb is offline   Reply With Quote
Old 03-15-2004, 03:46 PM   #30
Ill try direct soldering my battery to the esc and see if it is my connector.
Forum Jump
Glitches on Servo NOVICE4EVER Singapore R/C Racers 10 12-04-2007 08:24 AM
Glitches intrance Singapore R/C Racers 9 10-24-2007 04:53 PM
BAD GLITCHES HELP TylerOwenby Electric On-Road 9 05-20-2007 08:40 PM
i drive a FT b4 and my car glitches, please help slimbob Electric Off-Road 2 08-23-2004 08:34 AM
Novak SS5800 glitches StoneMan Electric On-Road 11 06-08-2004 09:47 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
