Closed Thread
Old 12-22-2009, 06:05 PM   #151
Brollywood's Avatar
Why is everyone surprised? This is what roar does. They stand back for so long, let everyone (companies/racers) stretch the rules to the max then change the rules. Then they change their mind on how they enforce it. Remember the carpet nats in Conn. Orr won with brushless and they had no clue what to do. So they let it run. He won. Then years later they finally put guidlines up. This rule is a joke. Now after coming back into onroad and getting the right chargers with the right update, they are changing the rules. wasted racers money. Im not surprised. ROAR is a joke. The only reason i go to the nationals is because the track thats hosting it. not the roar crew or their rules. supporting the tracks not the problem
Brollywood is offline
Old 12-22-2009, 06:05 PM   #152
L.Fairtrace's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to L.Fairtrace
Who Cares
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline
Old 12-22-2009, 06:22 PM   #153
STLNLST's Avatar
Trader Rating: 17 (100%+)
TOAST-to-the- T..........
STLNLST is offline
Old 12-22-2009, 06:30 PM   #154
Regional Moderator
CarbonJoe's Avatar
Like it or not, there are tolerances on everything electronic, computer controlled or not. A lot of electronic components are spec'ed with either 5% or 10% tolerance. For example, the second meter we used at the Halloween Classic, a Fluke 77, has an published accuracy of +/- 0.3%. There isn't a specification for repeatability, so even if the battery is exactly 8.400 volts, the meter could read 8.425 volts. Or an illegal 8.425 v battery could read 8.400 v. Adam claims that this would result in the racer being DQ'd for that round, when in fact it is the measuring device that is wrong. Also, note that Fluke specifies this as the "Best Accuracy", whatever that means. And the values also vary with temperature.
To the best of my knowledge, my ICE and Checkpoint chargers aren't upgradable, and are pre-programmed to stop the charging process at a non-configurable voltage (and mine read back the voltage as between 8.401 and 8.405 when charging is complete). So if the tolerances line up such that the charger's built-in meter reads low, and the ROAR meter reads high, what should the racer do? (Don't forget the repeatability factor). If you say that they should come and check the voltage after every charging cycle during the Nats on the ROAR meter before coming through tech, you're not being realistic.
Why not use some common sense and allow the racer to run the car to drop the voltage into the "legal" range before being allowed through tech? The last thing that this hobby needs is to alienate paying customers in the current economy.
*** The Gate - Celebrating 7 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline
Old 12-22-2009, 06:43 PM   #155
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
I think we have more important issues than arguing over 0.04 or 0.02 volts.
Here is a summary.
ROAR removed the .04 and .02 tolerance for Lipo Batteries for their events.
The tech team is there to help you match your battery charger voltage reading with their meter. You figure out through simple math calculations where your charger needs to stop charging, either manually or automatic.
If everyone is being measured by the same meter from when the doors open to when the doors close does it really matter if it is 100% accurate or not? Probably not.
You move forward from that point on.
This thread is closed.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline
Closed Thread
The future of 1/12 scale Roland S Electric On-Road 1003 05-04-2016 06:11 AM
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19920 04-03-2013 08:30 AM
5 Cells, the time is now!! Or atleast by 2008 Frank Root Electric Off-Road 421 08-20-2007 04:52 PM
ROAR to 4 cell.... Advil Electric On-Road 1394 12-21-2006 09:50 PM
SEO by vBSEO 3.5.0
