Sakura Zero - New Touring Car!
#1081
had a go with a friend's...i really like it!
#1083
http://www.rcmart.com/catalog/rc-sak...o-p-31570.html
big difference in how the motor is mounted in car.
3racing make motor mount is SAK-66 before.....and now SAK66/V2!!
Why?
http://www.rcmart.com/catalog/rc-sak...=595_1419_1467
#1085
The New motor mount drop the motor height 1MM lower.
It will clear most of the big pinion. (up to 55T with a spur gear of 72T 64P)
It will give enough gear ratio clearance for 21.5 no-timing
#1086
ver. 2 motor mount !
#1087
#1088
Hello,
I read through most of the thread and I have a few questions:
1) Is the car durable?
2) Does it use a special spur?
Thanks,
Paul
Thanks,
Paul
#1090
umms and errs
Hi all im thinking about getting the sakura zero and just want to know what people think of it on the whole when compared to the alternatives.
I currently run a xray t2 008 and my choices are either an exotec chassis for the 008 or plump up for the sakura!
What do you think?
What do you think?
#1091
#1092
Does anyone know if a different make belt will fit the rear as I have snapped mine tonight and have not got a spare. I have tried a Tamiya TRF415 belt but it is a little bit too long it works but will not last long as it is loose.
Thanks in advance for any help
#1093
Trf 416 rear belt will fit + no more broken belt issue.
http://www.rc-mushroom.com/product_i...ducts_id=14451
Remember to use 20t and 38t pulleys.
#1094
I have that problem with 4.0t before.
Regards Robert
#1095
I am using the 3racing low friction front belt and it is much better than the old generation. It was a bit tight at the beginning but now run very smooth without any sign of skipping. Part number as link below.
http://os.3racing.hk/products.php?products_key=4671
