Old 11-17-2011, 01:56 PM   #1351
sham55's Avatar
Default Hello Paul L
Just wondering if u had run a lrp xtec motors just want to knoe whats the different between the lrp 4.5t and the thunder power 4.5t in terms of power .. Or either turn motor between this two brands .
Tamiya TA05 ver II., HotBodies Cyclone TC, HPI Formula Ten, Team Atleast M Chasis, Xray T2'09 Foam Spec, Xray T2'09 Rubber Spec, Xray T2R Pro , Xray T3'12 Lipo Ver.
Lrp Stock Spec, Lrp Tc Spec, Speed Passion 60A, Hobbywing 120A, Tekin Rs Pro.
Lrp Vtec 4.5t, Lrp Vtec 9.5t, Speed Passion 11.5t, Orion 11.5t, Orca Qx1 11.5t
sham55 is offline   Reply With Quote
Old 11-18-2011, 02:20 AM   #1352
Hi Paul,
Do you ever run anti squat on your cars? If so, what does it usually do to the balance, I remember back in the day ALL cars used to run it, whereas now, no one seems to?
Mb3195 is offline   Reply With Quote
Old 11-18-2011, 07:30 AM   #1353
Gravity RC
Originally Posted by jgraham37128 View Post
Paul, how do you measure 10mms behind the bumper?
Hi. I first take a tall straight edge and stand it up behind the car, I then allign the straight edge with the wing (upper most lip of the wing). then i use a hudy droop block which is 10mm and slip it between the straight edge and the rear most bumper. it will be within 1mm every time. If you are having problems holding everything straight while measuring you can use double sided tape on the wing to hold the wings position while measuring, then just re-set the tape untill you get your proper 10mm. once its straight you can partially ream threw the wing, tape and bairly in to the body to make your dimples, remoove the tape, ream the holes properly then your all set.
Originally Posted by KWT-NITRO View Post
hey Paul, what's up buddy?
its been awhile how are you and and how's racing??
i got few question since a couple of friends are running on an asphalt track near Dubai and i might go over there.
1-is the protoform mazda speed 6 still the body to use??
2-the track is quiet big with two main straights, straight is about 60 meters long, if running a 4.5T motor, what spur/pinion do you recommend??
3- they spray the track with water/sugar, shall i use sauce or not??
4- the car still have your vegas set-up for carpet, how about a new one for asphalt, mid traction, big with highspeed turns??!!
5- how is the gear diff for asphalt and what oil do you run for asphalt??
cheers buddy
Ali
Hi Ali, good to hear from you!.
1 The Mazda speed 6 is still the most well rounded body for me.
2 60 meters is quite big so timing in the speedo may be nessissary to reach the speeds capible of that size track, i do not have a ton of experience with this but here is where i would start if i had to go with my exact equipment right now. monitor temps carefully at first.
Thunderpower 4.5, Fan on motor.
LRP Sxx V2 speedo,with fan.
Gearing for xray 114/27 or 8.0 overall ratio.
motor timing 15deg
speedo setting 2,2,5,4
3 yes use sauce.
4 I would look at my 2011 reedy race set up, normally on asphalt you need to have your car set up with more steering than carpet.
5 rear gear diff is good for asphalt also. 1000cst is the norm, if you want more rotation you can go softer, if the track is big and sweeping and your car has pleanty of steering you could go to 1500 or 2000, then it would allow you to motor around faster. but if the car is pushing, you will want to stay around 1000 in the rear.
No problem, Good luck!
Hi. I have not run the Lrp motor at all, so i can not say without speculating. I will say that i think the Thunderpower motors are good though.
Sorry.
Originally Posted by Mb3195 View Post
Hi Paul,
As you are saying, i did used to run anti squait quite a bit also. i have not tested it with todays power and weight cars. I will make an effort to get to the track sometime soon to test it. so maybe ask again in a couple of weeks.
If you test it, let me know.
Thanks.
Paul L is offline   Reply With Quote
Old 11-19-2011, 12:48 AM   #1354
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
hi paul
if you were running 17.5t thunder power with lrp what setting would you run please
Craig W is offline   Reply With Quote
Old 11-19-2011, 03:53 PM   #1355
KWT-NITRO's Avatar
thanks alot buddy,
will let you know how it works
cheers
Ali
Team Kuwait, Team Terribles, www.rccck.org
Kuwait National Champion
FEMCA Truggy Finalist & FEMCA Buggy Semi-Finalist
Thanks to all my sponsors: Modelix/Ultimate Racing, AKA Racing, AVID Racing, Stick-it1 Racing and HES
KWT-NITRO is offline   Reply With Quote
Old 11-20-2011, 08:20 AM   #1356
Gravity RC
Originally Posted by Craig W View Post
hi paul
If i ran 17.5 it would be blinky, with a 4.0 overall ratio to start.
Boosted i suppose i would try a 6.5 ratio with 2,6,6,3. but honestly im not sure how close that would be anymore.
thanks alot buddy,
cheers
Ali
no problem!
Old 11-22-2011, 02:12 PM   #1357
liteweight's Avatar
Hi Paul just got my Xray 2012, when you switch car do you basically put your set up on the new car or you go by the stock setup that comes with it ?
My old t3 is pretty much dial on our local track, just wondering'
And also any suggestion for the new 2012 that we have to be concern about
John's Mobile R/C Raceway outdoor racing
"The New Coliseum Carpet Track"
"MRH" Carpet racing
"Xray T3 2012"
liteweight is offline   Reply With Quote
Old 11-23-2011, 07:51 AM   #1358
Gravity RC
Hi. I would start with your set up from the old car. with every new car it normally takes a little something different to get it perfect. I just posted My Med bite carpet set up on the xray site (2011 fall classic). It worked well at that track but rolled a lot at my local track, so you may just take a look at it.
Concerns, I have none. It went together really well for me.
Thanks!.
Old 11-23-2011, 08:09 AM   #1359
Craig W's Avatar
hi paul
can you help with some speedo setting plz for 17.5t boosted and 13.5t boosted in tc with tekin and speedpassion esc plz racing on 16x30 and 2030 mtr carpet track
Old 11-23-2011, 08:14 AM   #1360
Hi Paul,
Speaking of the Fall Classic race, what sort of changes did you make for that track vs a typical high bite carpet track?
You seem to run the MazdaSpeed6 almost everywhere, but I noticed a lot of people using the P37 and LTC @ the Fall Classic. Do you have any comments on what body you think suits the surface and traction level @ Mikes in Dallas?
JamesL_71 is offline   Reply With Quote
Old 11-23-2011, 08:57 AM   #1361
Skiddins's Avatar
Paul, how would you describe the effects of the different length links using the new upper clamps?
What effect are you after if you shorten/lengthen the rear links etc?
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 11-24-2011, 06:35 AM   #1362
Gravity RC
hi paul
Hi Craig. I dont race 17.5 or 13.5 boosted, and i have never run threw those speedos with stock motors. so i really have no clue, their is 100ways to set up a boosted system.
If by any chance you decide to run Non boosted it is much easier. 4.8-5.0 for 13.5 to start..
3.8-4.0 for 17.5 to start.
thanks
Originally Posted by JamesL_71 View Post
Hi Paul,
Hi. for changes, I used softer shock oil to get the chassis roll up, i used less front camber and more rear camber than i normally would on a super high bite track, the car was more front heavy than i normally would run and i used standard hexs where i normally use narrow rear. those were the major changes that i thought helped me get good traction and roll.
I did not test the other bodys at Mikes but i plan to run the speed 6 at the nats. It just has good ballance to me. If i were out of ideas on chassis testing then i would go back to testing the different PF bodys.
Skiddins
Hi. my rule of thumb is this.
Longer = more traction and more roll.
shorter = less traction and less roll.
for me if i go short rear and long front the car has the most steering.
If you need the car to be easy to drive you will want to be long rear and short front. also short in the front really helps the front end of the car stay UP and drive nice in switcbacks also.
But lately i have run them all over, its really nice to tune with.
Thanks.
Old 11-24-2011, 09:24 AM   #1363
jgraham37128's Avatar
Trader Rating: 24 (100%+)
Default diff oil
Paul, what's the advantage of the different diff oils? I seen where you ran 500 weight in Texas and most everyone I talk to is running 1000 or 2000. I did some testing with 2000 and the car had tons of on power steering, it would drive very good and I could pit it anywhere I needed. I then changed to 1000 and the on power steering went away but my lap times picked up?
Thanks,
JG
jgraham37128 is offline   Reply With Quote
Old 11-27-2011, 06:01 PM   #1364
haywood's Avatar
Trader Rating: 48 (100%+)
Default 2012
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 11-28-2011, 11:09 AM   #1365
Paul;
A good friend of Deiter's (Jim Bostrom) just passed away and I am looking for Deiter's phone number. Could you PM me his number so I can give hime the details.
Thanks.,
Bob Oaks
PM name is bobO
bob o is offline   Reply With Quote
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
