Old 01-20-2010, 02:04 PM   #121
mtbboy's Avatar
Hey Paul.
With your most recent Trackside setup, what ride height were you running and what is your fore/aft Balance set at?
Thanks.
D.
mtbboy is offline   Reply With Quote
Old 01-20-2010, 02:07 PM   #122
Gravity RC
Originally Posted by mtbboy View Post
Hey Paul.
Thanks.
D.
5mm front and rear.
Paul L is offline   Reply With Quote
Old 01-20-2010, 02:34 PM   #123
Johnny Wishbone's Avatar
Thank you sir.
When you go to the 009 inner rear roll center adjusters do you change out the shock tower as well? And if you are running with that setup wouldn't you have to shave the outer hubs down too? Have you tried the one hole rear hubs? Do you think that with the T3, going to the longer rear link (outside hole on rear hub) will lock the car in too much and create even more push problems?
Old 01-20-2010, 02:44 PM   #124
Gravity RC
Originally Posted by Johnny Wishbone View Post
Thank you sir.
The link will be lower with the 09 tower so you wont have to shim on the outside as much, with T3 tower and the old Cams you will run closer to 3mms on the outside. I tested both but im not really sure right now which way i like it, but right now i have the low link set up on the rear.
Old 01-20-2010, 03:24 PM   #125
energydrink's Avatar
hi paul. can you go over your theories of camber. how far do you go each direction and what you feel that does to the car.
Tamiya 415 MSXX...Associated B44...TOP Photon...Mugen MBX6
energydrink is offline   Reply With Quote
Old 01-20-2010, 06:06 PM   #126
Gravity RC
3deg is normally maximum for me. normally more camber equals more traction untill you get to around three deg's then you will get less traction or it will just drive weird. with every tire their is a maximum amount and for me it is usually 2.5 or three deg. 1 to 2 is normal for me to start with. then i will go more or less in the front or rear depending if i need more steering or not. camber is the easiest way to tune the car but it is still best to do it on the chassis because with more camber i feel like you can loose forward bite.
and obviously different set ups can require more or less camber also.
but you cant go wrong with 1.5 or 2 all around.
Old 01-20-2010, 10:29 PM   #127
Andy63's Avatar
Thanks alot Paul for answering my question before But heres another one hehe :P
How much % brake did you set on your transmitter on your T2 chassies? Say Las Vegas for example.
And is this your work? What do you do in your work?
Thanks alot mate! Have a nice day!
www.andrefossto.wordpress.com
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 01-21-2010, 12:25 AM   #128
Benzaah's Avatar
Trader Rating: 21 (96%+)
Also on trims on the radio, Do you turn down your steering on the radio at all? Do you have a certain degree mark you like to set the car up to have? I dont have ECS Shafts and I turn my steering down quite a bit to stop chatter at the expense of being able to steer around traffic. Better hand control is needed i think
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 01-21-2010, 07:44 AM   #129
Gravity RC
I use 100%brake, this way if i just touch the brake it locks up like an e-brake, this way its more of a brake button that i feather.
Right now i do make a living racing and do things on the side for my sponsors.
I always set my steering at full throw (inside steering knuckle bairly touching the caster block), even when i use the standard drive shafts with the noise and bind, it really does not hurt you as bad as it sounds atall.
I use between 20 and 40% negitive steering expo, i also run negitive throttle expo in mod, 10to20% normally, sometimes more.
Old 01-21-2010, 08:02 AM   #130
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
hi paul.....good luck at the birds....
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 01-21-2010, 10:32 AM   #131
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
Oh stop being so modest and tell the truth. You write cook books for a living.
Good luck to you in Florida!
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-21-2010, 10:41 AM   #132
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
I think I've seen that, isn't his favorite ingredient sausage?
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 01-21-2010, 10:48 AM   #133
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
wondering who in this world doesn't really know who paul is....
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 01-21-2010, 10:57 AM   #134
Team Tekin
TY@TEAMTEKIN's Avatar
Good info in this thread, just read all 9 pages.
Good at the Birds Paul, I'll be a watching as much as I can!
Ty Campbell
TEKIN / TLR / SOR GRAPHICS / MIP / PROTEK / KALGARD / AVID
TY@TEAMTEKIN is offline   Reply With Quote
Old 01-21-2010, 07:27 PM   #135
Gravity RC
Thanks Matt
LOL, Thanks
ouch, but a good one.
Thanks!!
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
