Old 07-14-2011, 07:45 AM   #1141
Gravity RC
Originally Posted by StarrRacing View Post
Hello Paul,
Rumor has it you may be at Leisure Hours on Sunday for the BBQ Race....
Any truth? Can I put you down on the list for Modified Touring Car?
Im not 100% sure if i will make it yet or not but i am trying.
Originally Posted by jgraham37128 View Post
Thanks Paul. It's nice to be able to get set up info from you here on RC-Tech.
JG
No problem.
Paul L is offline   Reply With Quote
Old 07-14-2011, 12:13 PM   #1142
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Quitters never win!!!
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 07-18-2011, 08:10 AM   #1143
liteweight's Avatar
Hi Paul what car width are you running for outdoor asphalt?, And can you please explain what is the difference of running narrow or wider in terms for over all performance of the car?
Thanks again'
John's Mobile R/C Raceway outdoor racing
"The New Coliseum Carpet Track"
"MRH" Carpet racing
"Xray T3 2012"
liteweight is offline   Reply With Quote
Old 07-18-2011, 09:43 AM   #1144
Gravity RC
Thanks again'
Hi, i normally run 2.25mms of shim's in the front hingepins. the wider front setting feels to take away steering (especially corner entry) but when the car is set up right i feel it is easier to drive and carrys good corner speed.
In the rear i have always run 0 shimms in the front mount with shim's only for toein the rear mount. i have not played a ton with making the rear wider but when i have i feel like it is hard to get the rear to roll evenly with the front. wider hinge pins = less roll. from a traction standpoint it could go iether way but normally narrower will feel like that end of the car has more traction.
Thanks!
Old 07-18-2011, 12:55 PM   #1145
Paul, have you tested any kind of putty in your front gear diff? If you have what kind and did you mix any oil in. Thanks
franc furter is offline   Reply With Quote
Old 07-18-2011, 02:59 PM   #1146
Gravity RC
I have tried putty, i used only putty and it was really stiff but worked well. I have heard of people mixing putty and oil also. i would assume just a few drops of 100k or something would be a happy medium.
Old 07-18-2011, 03:08 PM   #1147
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Im not Paul by any means but one thing I can add about Putty in the front is that if its really hot outside it makes the car change a lot during a run. A few weeks ago at an asphalt race the track temp was 150. at the start of the run my car was OK when the putty was stiff. As soon as it got hot (about 2 min) it got more and more steering and became harder to drive. It took me a few packs to figure out it was the putty in the front being super soft because it got so hot. The bottom of the car was 125 after a run and the front diff felt like you had 20K in it as soon as you took the car off the track. After it sat for awhile it hardened back up.
Just a heads up if you notice a change during a run that could be the cause.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 07-18-2011, 03:52 PM   #1148
Do you expect the same effect with oils in the rear diff and track temps.
I run in Las Vegas, outdoors. Our ambient air temp today is 110...
Syxxstring is offline   Reply With Quote
Old 07-18-2011, 04:17 PM   #1149
Paul, I have a xray 009 upgraded to a 38t pulley does it really need to upgrade the fixed pulley to a 20t or just stick with 16t?
thanks
Localracing is offline   Reply With Quote
Old 07-20-2011, 04:12 PM   #1150
Gravity RC
EA
To help the diff not change as much i made sure that i got the diff as full as possible, with no air I felt that the putty does not change much. With silicone oil you will have the same result in hot temperature. so maybe a spool is just best for super hot weather?.
yes, you will notice the rear diff to get thinner also. in the rear it is not as much a problem though. 2,000 in your rear diff could become more like 1500 with heat, not as huge a change to the handling as it would be to the front.
thanks
Hi. I dont like the 16t center pullys. the drive train will be more efficient with the larger pullys and also your belts will last twice as long.
will you see it right away in lap times, ??. but i really do prefer the 20T pullys.
thanks!
Old 07-20-2011, 04:23 PM   #1151
Skiddins's Avatar
thanks
I thought the 009 came with 20t centre pulley?
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 07-20-2011, 06:29 PM   #1152
Team EAM
Not sure on that one Paul. I had her packed pretty tight. But I did not take it apart after a run and redo it. maybe it has moved around a little but after it sets for a while it is hard as a rock. But it was hot (150 degree track temp) so its possible it just melted.
EA
Contact Us
Old 07-20-2011, 06:43 PM   #1153
Fred Hubbard's Avatar
On the initial "packing" and each time thereafter that I add more gum I always break the diff by turning the outdrives for a few minutes outside of the car to ensure that the gum gets into every little space then I add a tiny bit more if needed.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 07-20-2011, 08:38 PM   #1154
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
For the sake of information...
I packed three Spec R front gear diffs with putty and noticed the same as y'all; Stiff at first and then softer, probably a combination of moving the putty around and temperature change. I even noticed the diff softening indoors on carpet, albeit summer indoors at our track can get to 90 degrees at times after coming out of my 75* pit room. I packed three with 3 different amounts of putty, and of the three, the two stiffest diffs eventually broke after only a couple race days. The gears stripped, I assume from the increased stress of the stiffer putty. I would like to try the ofna diff locker or the bad horsie grease next.
Old 07-21-2011, 11:47 AM   #1155
I've heard that anti wear grease like Tamiya has wil work fine in the front diff.
somebody?
eded1 is offline   Reply With Quote
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
