Old 06-14-2011, 12:05 PM   #1081
Gravity RC
Originally Posted by burrppp52 View Post
how do we know wat FDR to use for diff turn motor ???
Hi.
This is a rule of thumb for non timing speedos and any motor manufacture. depending on the track size and motor it could be a tooth or two on the pinion different. for timing speedos it depends completely on the speedo setting and their is many different gearing options based upon the timing settings on the speedo.
Everyone needs to take notice of motor temp at 3min when trying a new set up to ensure not to blow a motor. any manufactures motor will taper off in on track performance around 190deg (magnet gets weak) and most manufactures will not blow up untill 210-230 deg or more. if at 3 min your motor exceeds 170deg you are most likely too aggressive on gear or timing for a 6 min run.
Again this is for non timing speedos and just a good rule of thumb for a starting point.
21.5 turn, 3.6 overall
17.5 turn, 4.2 overall
13.5 turn, 5.1 overall
10.5 turn, 5.7 overall
5 turn, 8.1 overall
4.5 turn, 8.4 overall
4 turn, 8.9 overall
hope this helps a little. Thanks
Paul L is offline   Reply With Quote
Old 06-14-2011, 12:40 PM   #1082
trf415msx's Avatar
Trader Rating: 15 (100%+)
hi paul
what kind of traction compound that you used for tire warmer or the traction compound that you use for The reedy race......thank you
trf415msx is offline   Reply With Quote
Old 06-14-2011, 10:17 PM   #1083
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
Originally Posted by Paul L View Post
Hi. the set up was good, my result was 7th but the car was capible of better. It had good forward bite and made very nice carousels, it did lack a touch of low speed tight steering which i was never able to get at the race. i will be starting with that set up at the ETS final next month, hopefully with a nother race under my belt i can round up the last necissary adjustments, but right now i dont know for sure what they are. possibly a thinner rear Gear diff setting to help the car rotate a touch more?
Thanks for the insight...and for clearing up the spring issue, that's what really threw me off. 2.6F springs, 700F oil, and anti-dive all at the same time had me scratching my head! Looking forward to watching you wheel at ETS...sure would be nice to see a US driver on the podium!
-rocky b
flatspunout is offline   Reply With Quote
Old 06-15-2011, 06:32 PM   #1084
Gravity RC
Originally Posted by trf415msx View Post
hi paul
Hi. At the reedy race their was a 5 min FX2 sauce rule that was inforced for the invitational drivers, so that is what we all used their, and FX2 has proven to work well on asphalt. When I can use any sauce any way that I want, I normally like to not use tire warmers, I feel like warmers can be very good but can also be very bad if not done right. I try to take as many varibles out as i can when saucing tires.
I have been using my own sauce for almost 2 years. It is now being sold by RCAMERICA, it is called "Liquid Gravity", their are two kinds LG1 and LG2, LG1 is agressive and penitrates rubber and LG2 has a much higher oil content and is a great treatment for used tires.
For new tires i reccomend to clean tires with motor spray then sauce with LG1, let air dry completely and simply run. For used tires I recommend to clean the tires with LG1, let dry completely then rub in a small amount of LG2 and also let dry, then run. I find that this method is easily duplicable and works well.
-rocky b
No problem, sorry about the mistake.
lol, Ill try for podium but no guarantees on that one.
Old 06-15-2011, 06:47 PM   #1085
I have been using my own sauce for almost 2 years. It is now being sold by RCAMERICA, it is called "Liquid Gravity", .
It might be in stock from RCAMerica, but its not on their website, and they have not bothered to reply to an email.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 06-15-2011, 08:16 PM   #1086
Gravity RC
Hi. It is a new product for them and Im sure that they will have it up on the site soon. I will make sure you get what you need, What email adress did send it?
Old 06-16-2011, 04:24 AM   #1087
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Nexus racing has it in stock
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 06-16-2011, 05:13 AM   #1088
Gravity RC
Good Call. I would try their
Old 06-16-2011, 11:29 AM   #1089
Hey Paul im currently building a tc6 and was looking for some suggestions on a esc motor and a servo got any??????
Johncho is offline   Reply With Quote
Old 06-16-2011, 03:18 PM   #1090
Thanks for the advice last week paul, certainly worked on bumpy track tq and won meeting. along with new track record.
Regards
Ricky Copsey
xray uk
prodriver is offline   Reply With Quote
Old 06-16-2011, 06:27 PM   #1091
Gravity RC
Hi. I like the Futaba S9551 short case servo. I use Thunderpower motors and batterys, i have tested a lot with Thunderpower on the equipment and i think its good. I use a Lrp sxx speed controller.
For the TC6 on asphalt i would look for Rick howarts set up from this years reedy race, his car looked pretty good. For carpet i would check out some of Kevin Heberts carpet set ups, look for the 2010 TimeZone Grand Prix or the 2010 halloweene classic i would try one of those first for his car looked good at those races.
Thanks, good luck!
Regards
Ricky Copsey
xray uk
Cool, Good job!!
Im glad you were able to make some of that stuff work for you.
Old 06-16-2011, 08:21 PM   #1092
Thanks, good luck!
Cool, Good job!!
Thanks Paul i will look into that!!
Old 06-17-2011, 05:32 AM   #1093
StarrRacing's Avatar
Default Asphalt Assault Series
Hello Paul, I hope all is well with you and yours.
It was nice to see you at the Asphalt Assault Series race #2 at Strictly RC
last Saturday. I just wanted to say "thank you" for coming and providing
your expertise to all the drivers at the race. Always a gentleman you are!
Watching you blister the track on your exhibition runs was awsome as usual.
However, I would have "really" liked to see you participate in the actual
racing.... I think I heard you may be at race #5 at Leisure Hours Raceway
Aug 21st, for the finally...
Hopefully you will be able to race then, the last time I saw you run on that
track it was the most "impressive" pieces of driving I have ever seen!!!
....bar none!
Take care, and thanks again,
Jeff Starr
U.S. Coast Guard (Retired)
Traxxas 4x4 (x2), Associated SC10,
XRay T3 '009 (VTA), XRay T3 '10 (USGT), Tamiya M05 (Mini),
Tekin, Spektrum.
StarrRacing is offline   Reply With Quote
Old 06-17-2011, 06:59 AM   #1094
Gravity RC
....bar none!
Hi Jeff. I am going to try and make the race at Leisure. i assume that their will be a mod class at that one, so i will race.
Thanks, see ya!
Old 06-17-2011, 09:46 PM   #1095
TEXT's Avatar
Hey Paul,
I just wanted to say sorry that I have been busy lately and haven't been contacting you as much this summer. I recently just got a job and will be looking forward to hanging out with you once i have a little bit of money in the bank. I hope your racing season and family have been well and I hope to hear from you soon! Take care, and let me know when your next race is so I can watch it on LiveRC.com thanks !
Your Friend, Alex
Tamiya VDF2
Spektrum DX3s Radio
Homemade ABS Drift Tires 2" piping
Off-brand fluorescent orange rims
Toyota AE86 body (white w/sharpie marker)
TEXT is offline   Reply With Quote
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
