Old 06-11-2011, 09:30 AM   #1066
Gravity RC
Originally Posted by Solara View Post
Paul....I heard you are heading to STRICTLY RC this weekend just to entertain us slow guys in Chicago area. Are you going to run the super slow class called open 17.5 with us slow guy..? If you are...I bet alot of us with ditch the MOD class and mount up the 17.5....but if you are running mod, then we need to ditch the slow 17.5 and strap in the 4.0T....
Looking forward to seeing you this SUNDAY. Howard
Hi Howard, i will be at Strictly tomorrow, i am going to come to help anyone who is having trouble with their cars, I am going to run some with Goops car BC he wants me to set it up for him. not totally sure if i will race or not.
See ya tomorrow.
Originally Posted by ThunderPowerRC View Post
In reality Paul runs a 4.0 because it matches his IQ.
Gotta love the support from a sponsor, lol.
Originally Posted by prodriver View Post
Hi Paul another couple of questions for you regarding suspension for this bumpy track..
the track is www.southendrccc.org its a converted off road track has alo of hills and EXTREMLY BUMPY you take the wrong line and you will find yourself in the wall.
regarding suspension would you run small pistons with thin oil and soft springs or large pistons with thick oil and soft springs or either configuration but with harder springs??
I am a local to this track and have tried lots of different things over the years but the car never actually feels 100% settled and info would really appreciate it
and what is the effect of outboard toe in hubs??
Ricky
for suspension i would try soft springs, like maybe 2.6f and 2.4R with big bars like 1.5f and 1.4r, 3hole pistons with 400r and 500f. 5.5mm or 6mm ride height. i would think that the car would take the bumps pretty well with that suspension and be good to drive but the cornering speed could be down?.
i have never set up a car for really bumpy conditions.
You would most likely see better performance from more outboard toe over bumps. outboard toe in compairison to inboard toe will create less bind threw suspension travel. with outboard toe the rear of the car will roll more and have the tendincy to have less entry corner steering and more exit steering than the equivilent inboard amount. You must remember to take the wheelbase in to consideration, more inboard toe make the car shorter, so to test properly you should take that in to account while doing the change.
Good luck!
Paul L is offline   Reply With Quote
Old 06-11-2011, 09:01 PM   #1067
big_alex39301's Avatar
Default EA
I know this is an ask Paul thread, but I have a quick question for EA. Hey EA we meet at the children's race in southaven. I was with rocky, bonadona and you let me have a 98 tooth spur gear. I plan on racing at beat the heat in the 17.5 blinky class and was wondering what fdr you would recommend for a duo3 and tekin esc. I hear the track will be pretty big and I have no clue what gear to use. Thanks Man
big_alex39301 is offline   Reply With Quote
Old 06-11-2011, 09:12 PM   #1068
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 34 (100%+)
Any comments on your Reedy setup? It's very...unconventional I'd like to know more about what you were wanting the car to do and things you would change if you had it to do over again. Thanks!
-rocky b
flatspunout is offline   Reply With Quote
Old 06-11-2011, 09:57 PM   #1069
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Weak....
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 06-12-2011, 06:01 AM   #1070
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
hi little buddy
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 06-13-2011, 08:39 AM   #1071
Gravity RC
-rocky b
Hi. the set up was good, my result was 7th but the car was capible of better. It had good forward bite and made very nice carousels, it did lack a touch of low speed tight steering which i was never able to get at the race. i will be starting with that set up at the ETS final next month, hopefully with a nother race under my belt i can round up the last necissary adjustments, but right now i dont know for sure what they are. possibly a thinner rear Gear diff setting to help the car rotate a touch more?
Originally Posted by Kevin K View Post
Weak....
sorry, Fun was had. Thanks
Originally Posted by Matt M. View Post
hi little buddy
HI Matt!
Old 06-13-2011, 08:50 AM   #1072
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Did u really run 2.6F spring and 3.2R spring or was that a mistake? That's what the setup sheet shows.
Rui Goncalves
Reds Racing USA|Hot Race Tyres USA|Team CRC|Team Trinity|
Jackson RC|Horsham RC|Floyd Bennett|Blue Diamond
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 06-13-2011, 10:33 AM   #1073
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
The set up sheet shows 4 hole pistons. Is that what you were using, or was it just left blank accidentally?
See ya in Jackson. :P
Old 06-13-2011, 10:39 AM   #1074
nitrobeast's Avatar
Originally Posted by andrewdoherty View Post
I didn't notice it on the set up sheet. Which pistons were you using?
By any chance are you guys coming this weekend for the regional/nats warm up race?
Rui Goncalves
Old 06-13-2011, 12:46 PM   #1075
I wish! I won't even get to NJ for Nationals until Thursday night.
Old 06-13-2011, 03:21 PM   #1076
robk's Avatar
Trader Rating: 22 (100%+)
LG1 & LG2 = the hot lash!!!
thanks Paul!!!
Old 06-13-2011, 05:53 PM   #1077
Xpress's Avatar
thanks Paul!!!
"Bow down" to LG1 & LG2!
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 06-13-2011, 07:00 PM   #1078
Paul,
YGPM
outlandr91 is offline   Reply With Quote
Old 06-14-2011, 07:55 AM   #1079
Gravity RC
Hi. Sorry, that was a mistake. it is fixed now. 3.2F and 2.6R.
yes, I did use 4hole pistons.
thanks Paul!!!
LOL, even i wouldnt go that far. glad it worked good for you guys too.
I think that we are finding that LG1 makes the best cleaner BC its aggressive and lets lg2 work best as the sauce, LG1 wipe'd in and LG2 applied thin to air dry. Kinda like how on carpet it seems to be best to clean with sauce as opposed to motor spray or some true degreaser.
Old 06-14-2011, 10:23 AM   #1080
how do we know wat FDR to use for diff turn motor ???
burrppp52 is offline   Reply With Quote
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
