Old 01-14-2010, 06:41 PM   #91
ChadRacing's Avatar
Hey Paul,
I was wondering if you could help me figure out the gearing i should be around when running a Nemesis 13.5. The chassis i am using is a 009 Foam spec with a FDR of 1.7. And im using a LRP SPX ESC.
The help would be very appreciated.
Plus, see you at the Birds
ReVtech / Trinity / EAMotorsports
HotShot RC / Nexus Racing
Xray T2 '009 w/Exotek Chassis, BMI DB12rr, Tamiya F104X1
Team Durango DEX210
ChadRacing is offline   Reply With Quote
Old 01-15-2010, 06:56 AM   #92
Gravity RC
Originally Posted by mcsquish View Post
WOW Paul, first a new tire sponsor now a new fuel sponsor. Good luck with the new go-go juice!
LOL. Yea, things are going to be different this year but i really think all the stuff is good so im pretty excited. Thanks
Originally Posted by ChadRacing View Post
Hey Paul,
Hi Chad. if it were me i would start at around a 100/32 with your speedo on power profile 7. check the speedo and motor temps and go from their. if you run it on profile 4 you can gear it 100/34or35 and again check the temps.
I hate saying this but i must be honest with you and say, that if your going to be competing against some of the new style speedo's (Tekin, Advanced, Mamba) it would be far fetched to think that you will have compairible power.
Paul L is offline   Reply With Quote
Old 01-15-2010, 10:24 AM   #93
ChadRacing's Avatar
OK..thanks for the info
Team Durango DEX210
Old 01-15-2010, 04:56 PM   #94
mtbboy's Avatar
Hey Paul.
You seem to use the 6 degree front hubs alot on tighter tracks and the 4 degree on more wide open tracks.
Why do you use the 6 degree hubs on a tight track?
And yeah, the new Tekin software is ridiculous...
Dave.
mtbboy is offline   Reply With Quote
Old 01-15-2010, 10:48 PM   #95
Trader Rating: 35 (97%+)
Send a message via AIM to King of B Main
Default Aluminum Shocks
Hi Paul,
I just bought the aluminum shocks and have been trying to bleed them to get less rebound. I drilled a little larger hole in the cap so more oil can come out but still cant get less than 70% rebound.
Any help would be much appreciated or should I just stick with the plastic shocks ?
King of B Main is offline   Reply With Quote
Old 01-16-2010, 04:44 AM   #96
Default Xray Alum shocks
Hi Paul,
saw your reply on using aluminium shocks on a T3.
You say you use 700 front but with which pistons?
The alu shocks come with a choice of 1.1,1.2 or 1.3 pistons.
We are currently using 1.2 with 400 oil.
regards
Don
donwhit is offline   Reply With Quote
Old 01-16-2010, 10:25 AM   #97
Hey Paul,
Just gotta say man your skills behind the wheel are sick and congrats on the wins this year....
My question is when running rubber on carpet do you run any drag brake or does it primarily depend on track layout or size of track or do you just not run it at all?
Thanks,
Steve
TEAM Black Ops.
NUCRPTRACER is offline   Reply With Quote
Old 01-16-2010, 06:39 PM   #98
Gravity RC
Originally Posted by mtbboy View Post
Hey Paul.
Dave.
Hi Dave, i now use primarily 6deg blocks. when the bite is low and the car is loose i will sometimes use 4's but i like to run 6's when i can. Thanks
Originally Posted by King of B Main View Post
Hi Paul,
If you want very little rebound, drill a small hole in the plastic cap, not the aluminum, this will vent the chamber above the bladder and allow the bladder to flex with more ease resulting in less natural rebound without having to bleed lots of oil out.
Originally Posted by donwhit View Post
Hi Paul,
regards
Don
Hi, the info was for aluminum shocks with 1.1 pistons. Thanks
Originally Posted by NUCRPTRACER View Post
Hey Paul,
Thanks,
Steve
Hey Steve, Thanks.
yes i do run drag brake, i dont like to use a ton of push brake so i run a good amount of drag brake (3or4 on my lrp) then feather the push brake on some of the harder breaking corners. but i run the push brake almost like a E-brake its set to 100% so the tires lock up if the brakes are even touched, but that way their is not a large range of motion atall.
the only downfall with that is that when i get nervious i brakecheck on accident a lot. and it dosent work for 12th scale very well atall.
Old 01-16-2010, 09:08 PM   #99
STLNLST's Avatar
Trader Rating: 21 (100%+)
C'mon man.....you still get nervous I'm not buying that....LOL
STLNLST is offline   Reply With Quote
Old 01-16-2010, 10:57 PM   #100
Gravity RC
Ha, it depends on the situation. but you got Reinhard on your butt, i dont care if your baby Jesus.lol
Old 01-17-2010, 12:45 AM   #101
Default Thanks
Thanks Paul
I would wish you Good Luck at the Birds , But you got SKILLS, so no need for Luck!!!
Old 01-17-2010, 11:39 AM   #102
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
I think sometimes we forget that there are other "Paul's" out there. You're still the best to us! I still need to talk to you. Works been killing me since the new year so I haven't had much time for anything.
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 01-17-2010, 02:40 PM   #103
hollywood tc5's Avatar
hey paul, could you post a carpet setup for the t2 009 eu chassis
BOSS MOTORSPORTS
wrecking ball,sox,hollywood
BOSS MOTORSPORTS
hollywood tc5 is offline   Reply With Quote
Old 01-17-2010, 02:45 PM   #104
ToysRUsKid's Avatar
He has a few of them posted on http://forum.teamxray.com/xsheets.php for just about every car he's touched. You may have to look at a couple of them to find the carpet vs asphalt, but they are there. Maybe the last IIC setup.
Old 01-17-2010, 03:27 PM   #105
another thing is that exotek chassis what do you think of it
BOSS MOTORSPORTS
BOSS MOTORSPORTS
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
