Old 03-21-2011, 08:44 AM   #916
Gravity RC
Originally Posted by Paul L View Post
It should be the same, any 2,000 should be rated in cst. i use Xray 2,000.
The reason why they say "Diff" oil and "Shock" oil is because 100-1,000 is commonly used in shocks, 1000- 500,000 is commonly used in diffs.
Paul L is offline   Reply With Quote
Old 03-21-2011, 08:55 AM   #917
Afazli79's Avatar
Send a message via MSN to Afazli79
Carpet you use 2000, how about low grip aspalt?
Thx..
Team MaxPower Malaysia...
Web : www.maxpowerbattery.net / www.bizonline2u.com
MaxPower / HobbyWing / Team Powers / Hudy / Xray / Robitronic / Tamiya / Tekin / Orca / LiteModz / Huge RC / MuchMore / LRP / Exotek / Smokem / SpecR / Atomic / SpeedMind / Sorex / Fijon / Paragon / Team Associated / Serpent / DS Racing
Afazli79 is offline   Reply With Quote
Old 03-21-2011, 09:06 AM   #918
Gravity RC
Thx..
Its been a while since i tested it on asphalt but i think 1,000 is good
Old 03-21-2011, 09:11 AM   #919
Xpress's Avatar
Good luck this weekend.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 03-21-2011, 09:16 AM   #920
Afazli79's Avatar
I only have 2000oil and 500oil. Can i mix it up?
Old 03-21-2011, 11:18 AM   #921
Gravity RC
Thanks man!
yes, but you will never know exactly what you have. but you should be able to get it close.
Old 03-21-2011, 12:37 PM   #922
Paul, will you be at Jackson RC at all this season before the 2011 Paved Nationals there?
Sam
samstheman2 is offline   Reply With Quote
Old 03-21-2011, 01:04 PM   #923
Gravity RC
Sam
Hi Sam, Its not 100% but i think i will be at the Xray challange.
Old 03-21-2011, 05:40 PM   #924
gonzo416's Avatar
Trader Rating: 39 (98%+)
Hi Paul, I bought an after market diff thrust assembly. The rings are grooved, but when assembled it is the same size as the Xray one. Is there a difference in performance? I am planning on using the after market rings with the Xray thrust bearing.
gonzo416 is offline   Reply With Quote
Old 03-21-2011, 09:17 PM   #925
Trader Rating: 41 (100%+)
Who is the head cheese at RC America?
Thanks,
Unhappy customer
On-point/ EA horsey power/XFactory / Hudy / Tekin / Trinity / KO Propo / Reino's Ragu
mracer is offline   Reply With Quote
Old 03-21-2011, 09:24 PM   #926
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
If it were me I would call and talk to Bryan or Ralph. I can't imagine a situation at RCAmerica that either one of them couldn't handle.
Phone: (800) 519-7221 or (214) 744-2400
Hours of Operation:
Mon-Thurs 9 A.M.-6 P.M. (central time)
Fri 9 A.M.-1 P.M.
Old 03-22-2011, 08:32 PM   #927
Wonton's Avatar
Paul / EA / anyone who rocks
When your driving do you brake alot or do you roll through corners? If you do use the brake do you brake before turning into the corner? Do you use drag brake? Is there anything noticable about your car that lets you know when to get back on throttle to power out of a corner. Do you adjust your steering d/r or do you keep it the same always. Are you very smooth with the throttle or twitchy through the curves?
Thanks for the Help!
Wonton is offline   Reply With Quote
Old 03-22-2011, 10:50 PM   #928
infokiz's Avatar
+1
I have had the hardest time with braking since I started using brushless.
infokiz is offline   Reply With Quote
Old 03-24-2011, 09:09 AM   #929
ByteStream's Avatar
Hey Paul,
I'm running your Cleveland setup w/ 1.5 front & 2.5 rear camber on a tight technical layout, the car handles well but I am looking for a bit more exit corner steering (push on power) ... I could sacrifice a bit of entry corner steering if need be, any suggestions? (standard hexes all around perhaps?)
Also a general question .. say you have 1 front & 2 rear camber .. what causes you to go to 1.5 front & 2.5 rear camber .. or vise versa (since you are increasing/decreasing both front and rear at the same time). Are you looking for more/less lateral grip? what are you sacrificing in each case?
Thanks in advance.
ByteStream is offline   Reply With Quote
Old 03-28-2011, 09:22 AM   #930
kghills's Avatar
Trader Rating: 40 (100%+)
Hey Paul. Congratulations on your ROAR Nationals win. Very cool. Maybe next years will be closer for us.
Keith and Jason.
Jason's dad
Check out Jason's video http://www.youtube.com/watch?v=eU2jqOnhJ9E
Photos: http://s816.photobucket.com/albums/zz90/kghills/Jason%20Hills%20RC/
Thanks to Team Associated and Reedy for their support.
kghills is offline   Reply With Quote
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
