Old 01-20-2011, 07:02 PM   #811
Korey Harbke's Avatar
Check for setups from the KO Grand Prix. It's an indoor track, but the track is very very very high grip asphalt.
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-21-2011, 02:01 AM   #812
tb214's Avatar
I think this might be useful in understanding roll.
Lateral load transfer is given by..
(weight of that end of car x CG height x Lateral acceleration) / track width
how much you roll will also depend upon the total roll couple you have which includes roll center, anti roll bars, springs, shock oil etc. High roll center (less roll) is better for hi traction tracks, low roll center (more roll) for
low traction. Tuning from wheel offsets is easy and time effecient, you dont have to put into a setup system. It may change the wheel base slightly, and the toe as well( it didnt change my cars toe). During practice and race, I prefer changing trackwidth from wheel offsets rather than the suspension holders shim, because the latter will change shock position, thus possibly ride height, camber, downstop, roll center. Nevertheless, the latter is still a good tuning option XRAY has, which a lot of non-xray drivers want, the more tuning options the more possibility for fine tuning. Tuning trackwidth from suspension holders is more of a primary, permanent, long term tuning, whilst offset is more of a secondary, short term, quick and easy adjustment.
hope that helps.
"Inspired by the late Phillip Toshio Sudo."
tb214 is offline   Reply With Quote
Old 01-21-2011, 05:58 AM   #813
Gravity RC
Originally Posted by TJames987 View Post
Hi paul,
Is there a T3 setup that would be a good starting point for very high grip asphault like the Colisium in Frederick MD?
I would start with the KO Race set up. but i would incorporate the low roll centers all around and front shock set up (2hole 500) from the most recent set ups.
that is most likely where i will start this outdoor season.
Thanks!
Paul L is offline   Reply With Quote
Old 01-21-2011, 07:24 AM   #814
Skiddins's Avatar
Thanks!
Out of interest, why start with the lower roll centres as opposed to kit, is that due to lower grip levels?
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-21-2011, 08:25 AM   #815
Gravity RC
Skiddins
Hi, this is not going to make much sence, but you asked LOL.
for me the 11 car has a lot of natural roll. when i first started setting the car up i tried a ton of things to keep it from rolling so much, but everything that i did just made the car harder to drive and it still rolled a lot anyways. finally i just figured that if the car wants to roll a lot that i may as well just let it do so even more. so i put on low roll centers all the way around and it was definately easier to drive for me and just as fast. Then to make the car roll equally front and rear i made the wheel hexs change and went to the two hole front piston and that is how i got to the current set up.
i think for carpet it is good, for asphalt i would most likely run a similar set up but with standard hexs for better steering.
Old 01-21-2011, 09:14 AM   #816
Johnny Wishbone's Avatar
Hi Paul, I can't seem to find any setups from the KO race do you have a link? Is this under your name or someone else? And just to confirm, are you saying you would run this on carpet as well as a starting setup?
Are you still using the original inner rc adjusters or have you started to use the new version yet?
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-21-2011, 09:59 AM   #817
Skiddins's Avatar
Search Xray site for West Coast track
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 01-21-2011, 11:13 AM   #818
Gravity RC
I thought i posted my set up from west coast but i guess i did not.
For carpet i would start with my cleveland set up, http://forum.teamxray.com/xform/inde...&setup=t3_2011
For asphalt i am going to start with the same set up but with these changes.
1mm shorter rear wheelbase, long "bulkhead" front camber link, standard hexs, 0deg outboard and 3deg inboard rear toe.
what do you mean by "rc adjusters"?
Thanks!
Old 01-21-2011, 12:05 PM   #819
Those inner roll center adjusters that use shims instead of the shock tower for attachment.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-22-2011, 01:08 PM   #820
Gravity RC
No I have not been testing the new one's, i am using L1 and L2's.
Old 01-22-2011, 01:09 PM   #821
Gravity RC
Im off to the Snowbirds then the Winternats right after.
ill be back on here to catch up when i get home in a couple of weeks.
Old 01-22-2011, 05:35 PM   #822
Kropy's Avatar
Send a message via AIM to Kropy
Good Luck & Have fun in the sun!!!!!
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 01-23-2011, 02:47 AM   #823
millbank's Avatar
Good luck Paul.
cheers for your help, will let you know how i get on when i get all the extra parts i need.
Jay
Xray T2009 / hobbywing v3 120amp /LRP x12 6.5 / wet car
Xray t4'14 / Hobbywing v3 120amp / 13.5/ boost car
Xray t4'15 / Orca Vxx / Orca Rx3 17.5 / blinky car
TEAM DRIVER FOR MMR FLUX
millbank is offline   Reply With Quote
Old 02-06-2011, 05:19 PM   #824
Hi Paul. I hope this hasnt been asked before.
But...do you use the speed in and speed out(TN, RN) setting on your transmitter for the steering servo?
And if so how do you set it up in combo with the expo?
Eat more possum!
Lees52 is offline   Reply With Quote
Old 02-07-2011, 02:09 PM   #825
Skiddins's Avatar
Paul, have you ever measured the corner weights of your car, and more importantly, what is the weight distribution front to rear.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
