Old 01-06-2011, 11:34 AM   #751
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Originally Posted by Paul L View Post
HI, i would definately not use motor spray. on asphalt it does sometimes work, but for carpet i dont like to use it. lighter fluid is a good thing to use, also you can just use sauce. but i would say that motor spray is one of the worst things for carpet that you can use.
Do you like Buggy Grip for cleaning?
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
Dane is offline   Reply With Quote
Old 01-06-2011, 12:50 PM   #752
Johnny Wishbone's Avatar
I definately think that a 1900 rotor is too heavy for any class or motor design. on my meeter 1600 is on higher end for what performs.
Paul, just wondering what you (and EA) are using for a rotor meter?
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-06-2011, 01:32 PM   #753
Gravity RC
I have used buggy grip to clean and sauce on asphalt before, but i have never used it for anything on carpet. it wouldnt suprise me if it worked though.
I use a I-Gauss, i assume that EA uses the same but i dont know.
Paul L is offline   Reply With Quote
Old 01-06-2011, 01:47 PM   #754
WOW, 1600 on a I-G, guess I better buy a new meter, I don't think Iv'e ever seen anything that high. LOL. Do the 2 of you get similar readings on the same rotors, or have you ever compared? (1600 wow )
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-06-2011, 02:03 PM   #755
Gravity RC
1600 is on the high end of what can work, I dont prefer it in all situations. the production 13.5, 17.5 TP motors will not have a 1600 rotor, for those winds it would be way too much magnetic field.
Old 01-06-2011, 02:17 PM   #756
Glad you cleared that up. Everyone would be a little upset if it wasn't like that out of the box.
A case of those motors with 1600 rotors would probably pull a small aircraft out of the sky.
Good luck at the Birds.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-06-2011, 05:08 PM   #757
Skiddins's Avatar
My Corally Red rotor;
I have found that with my ESC (Black Diamond), the high torque motors have a far better resilience to over/under gearing.
No matter what I gear at the motor comes off at 60degC max.
I found that using the same ESC with an X12 I had to gear a lot lower (7.60 compared to 5.28 with the Corally when running 10.5) and drop a profile as the temps on the motor were getting stupid.
I can't remember what ESC you run Paul, but when I had a Tekin I got fed up of fiddling with revs and turbo etc.
With the BD, noting can touch it coming out of a corner.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-06-2011, 05:38 PM   #758
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Skiddins,
Yes that rotor will measure that high as its a mod rotor. It has a smaller internal shaft that allows for magnet material. Thats not allowed in spec classes in the US. Mod rotors are made this way and when Paul talks about 1600 gauss he is talking a Mod rotor. Most spec rotors are in the 1300 range
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 01-08-2011, 10:12 PM   #759
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
I've used BG to clean and on the next run used Jack to clean- both times tires were sauced with Jack and I couldn't tell any difference. Tested it at 2 different tracks, so yes, BG works great for cleaning buildup on asphalt and carpet.
Hi Paulie! Measurements Paulie, MEASUREMENTS!!! LOL
BigDogRacing is offline   Reply With Quote
Old 01-08-2011, 11:05 PM   #760
Korey Harbke's Avatar
You want Paul's measurements? What?
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-11-2011, 09:48 AM   #761
Gravity RC
sorry big dog. ill get it to you.
Old 01-11-2011, 02:40 PM   #762
Skiddins's Avatar
Originally Posted by EAMotorsports View Post
Skiddins,
EA
That explains it, and having looked at the rules I can see where the difference lies
Out of interest, is it possible to make a high torque rotor but within Stock specs?
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 01-11-2011, 05:42 PM   #763
Team EAM
Originally Posted by Skiddins View Post
There are limits due to materials and amount of material. I have seen some of the newer rotors in the 1400 range but they are few and far between. And even at that seem to be almost to strong for spec classes here.
EA
Contact Us
Old 01-11-2011, 06:59 PM   #764
infokiz's Avatar
Paul when you say "motor cleaner is one of the worst things you can use on tires for carpet" would this include non-chlorinated brake cleaner?
infokiz is offline   Reply With Quote
Old 01-11-2011, 07:36 PM   #765
ChadRacing's Avatar
EA: Thanks for the help!!
Hey Paul,
I have never tried using lighter fluid to clean the tires and i was wondering how would you go about applying it to the tires to clean and how long to let it set? Advice will be appreciated.
ReVtech / Trinity / EAMotorsports
HotShot RC / Nexus Racing
Xray T2 '009 w/Exotek Chassis, BMI DB12rr, Tamiya F104X1
Team Durango DEX210
ChadRacing is offline   Reply With Quote
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
