Old 11-13-2010, 02:33 PM   #631
Gravity RC
Originally Posted by jake95 View Post
do you run a gear diff if you do what oil running
thanks for your help
i always run between 1000 and 2000. normally 1000 for asphalt and 2000 for carpet.
Paul L is offline   Reply With Quote
Old 11-13-2010, 04:32 PM   #632
rcko's Avatar
Trader Rating: 15 (100%+)
Paul, can you give a quick summary of what cSt equates to Weight. For example, 20,000 cSt is what weight oil? Thanks
rcko is offline   Reply With Quote
Old 11-14-2010, 06:32 AM   #633
Gravity RC
Hi, I dont think losi, trinity and associated 50wt is even the same. someone once had a convertion chart for all manufactures oils converting them all to CST but i dont remember where that is.
I think all the thicker stuff for diffs has always been measured in CST but im not 100% sure on that.
Old 11-14-2010, 07:07 AM   #634
CSt is a well defined standard, where as wt aint.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 11-14-2010, 07:29 AM   #635
HarryLeach's Avatar
Send a message via AIM to HarryLeach
I believe this is the info you guys are looking for.
http://www.twf8.ws/php/index.php?opt...per&Itemid=175
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 11-14-2010, 07:34 AM   #636
Very nice link indeed - bookmarked! Thanks!
Niklas Hansen
Old 11-15-2010, 08:50 AM   #637
Gravity RC
Thats It, Thanks guys!
Old 11-15-2010, 08:57 PM   #638
jake95's Avatar
Trader Rating: 27 (100%+)
thanks
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 11-16-2010, 07:09 PM   #639
jgraham37128's Avatar
Trader Rating: 24 (100%+)
Default Scales
Paul, do you ever place your finished car on four scales and see what the dynamic weight is? If so how do you adjust it, and how close do you try to get each scale?
I have my static weight set but when I place it on the four scales I'm off quite a bit. What should I look for?
jgraham37128 is offline   Reply With Quote
Old 11-17-2010, 06:24 PM   #640
Jason, it's a good idea to put your car on a Hudy Quick Tweak station first if you have one. That will eliminate any spring pre-load or tweak questions first.
Bonadona is offline   Reply With Quote
Old 11-17-2010, 08:35 PM   #641
Default Tweak
I do. It's in the middle but to one side. How close is acceptable? When I put it on the scales it seems to be off more than it really should.
Old 11-17-2010, 08:45 PM   #642
I'm assuming you are talking about the bubble on the tweak station. The closer to center the better, but I too am interested to see what Paul has to say. I've seen both Paul and Drew lift each wheel of the car by hand so they can feel the weight. I guess this comes from many years of experience. I don't think I'll be learning that trick any time soon.
Old 11-18-2010, 05:55 AM   #643
Gravity RC
Hi Guys, i have done it 100 different ways, i do it by hand and get it pretty close like that, but i tweak station (bubble) will do the same thing as feeling for the weight like i do. If i ever have a car that is seriously awesome i will put it on 4 scales to document the F/R weight %.
I have also used 4scales to tweak the car and it does work for me, youl never get it totally perfect, but you just want your left and right resr close and your left and right front close.
Maybe you are getting varied results from variables with the 4 scale system, next time you try this first use the tweak station get the bubble centered, then put the car on the scales, wright down the weights LR,RF and so on. then leave the scales in the same spot but rotate the car so the rear tires are now on the scales that the front tires were on. then compair the results. if the results are way off you will know that your scale system is flawed. tweak in the board, not accurate scales, different height scales, etc.
Old 11-18-2010, 06:09 AM   #644
Default Paul
Thanks Paul, if you do see your car isn't centered on the tweak station where do you start in order to correct the problem?
I also noticed I built my car and ran it last weekend for the first time. I noticed after a couple of runs my body started dragging. I trimmed it on the sides thinking this is what was dragging. Next time out, it was still dragging I trimmed the front and that fixed the dragging. When I got back home I was checking everything and noticed my ride height had dropped from 5.0 for 4.4 letting me know why the body was dragging but I never thought to check it since we're running carpet and tire wear is really minimal. With this being said I assume my shocks settled in? Is this normal? This is where I plan to start on getting the tweak set back on the car, because I know everything is built equal from the left to the right side.
Old 11-18-2010, 09:53 AM   #645
hey Paul
i would like a to get back into sedan racing after a 5 year absense. I was going to MMI at the same time you were. We met a couple times and raced against eachother at SRS. after leaving AZ i moved somewhere that didnt support sedan racing, i.e. no tracks. I just want to know if sedan racing is still popular on the club level at all. the class has appeared to have completely faded away at the amatuer level. I'm moving to denver CO and would like to know if sedan racing would be the right choice. is it dead? i ask you because you get to travel all over the places and probaly have ur finger on the pulse of sedan racing in this country. thanks.
RMRCracing is offline   Reply With Quote
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
