Old 11-08-2010, 07:23 AM   #601
Gravity RC
Originally Posted by RCknight View Post
Paul, I don't have much experience with sway bars and I was wondering if some light bars would be beneficial in the slower VTA class or not? Should I run a softer springs as well? Also any set ups you know of for med carpet would be great. Thanks
Hi, you will just have to try the sway bars. the car will roll less(side to side) with them, the car should have better forward drive with them but sometimes in the 17.5 classes that is not really needed. if you are going to just try some small ones i would not change the springs, if you are going to try bigger bars i would drop a spring rate and see what it will do.
Originally Posted by ToysRUsKid View Post
what's up Paul, just here to say hi! How are things going? I know you're happy this year is almost over, it's been a monster for you.
Hi man. things are good, definately a long year, not over yet LOL.
hope things are good with you.
Originally Posted by jgraham37128 View Post
Paul, thanks for the help on the ackerman. I have two cars one is a t3 2011 I just built and the other is a T2 009 EU. I noticed on the T3 the outside tire is at 30 degrees and the inside tire is around 20 degrees at full throw. On my T2 09 it's 30 degree on full throw both left and right but the inside on the left is 17 degrees and when I turn it to the right it's 20 degrees. What can I adjust to make both the same on the inside tire?
Thanks,
JG
Hi, i would assume that when your wheels are straight your steering rack (inner ball studs) are not perfectly on center. measure your steering tie rods and see if they are the same legnth or atleast within .5mms to start.
thats really the only thing that it could be unless if something is really tweaked or off.
Paul L is offline   Reply With Quote
Old 11-08-2010, 07:43 AM   #602
jgraham37128's Avatar
Trader Rating: 24 (100%+)
Default Ackerman
That was is it. off by +3.0 mm.
Thanks,
JG
jgraham37128 is offline   Reply With Quote
Old 11-08-2010, 08:31 AM   #603
Lonestar's Avatar
Hi Paul
I would need some advice for my T3 (2010) please. I ran my first onroad race of the season saturday, indoor, tight, (very) technical, rubbers on carpet, 10.5 mill. The car had the full-stock setup with just 50WT oil and 1hole open everywhere (the MM32 tires we run like to be brutalized to finally heat up). The car was great with awesome low-speed cornerspeed, but the rear was a bit of a handful in two of the faster sections - one was a left 90-deg turn right after a chicane (so basically when turning left the car was still recovering from the chicane's last right bend) and the other one was the 90-deg (left) turn right after the (short) straight. Car was straight, symmetric, bind-free, mechanically it was 100% there. (spec) Tires were gooed properly, like the faster guys. I did the 9th time, tq'ed the B, grrrrrr
Where would you first start in terms of setup changes to fix this?
Thank you!
Regards,
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 11-08-2010, 08:40 AM   #604
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Paul, when was the last time you bolted a spare tire to either the trunk or roof of your touring car to prove a point? Is that true or just a rumor?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 11-08-2010, 09:35 AM   #605
Trader Rating: 16 (100%+)
Hi paul, thanks for the clarification. It has really helped
ronaldo-1234 is offline   Reply With Quote
Old 11-08-2010, 10:32 AM   #606
JayL's Avatar
Paul: have you tried mounting the body posts to the rear of the rear shock tower instead of the manual setting in front? pros/cons?
JayL is offline   Reply With Quote
Old 11-08-2010, 10:34 AM   #607
Send a message via AIM to HenBeav
Paul, we are having problems ripping rubber front tires, mostly blues but also has happened with solaris mediums. Anywhere from 2 to 10 runs and they develop the line on the inside of the tire and then you can't bet they rip in the next 4 runs. I seem to be the best at it, pretty standard front end, parallel links, 2 degress camber, 50wt oil 3 hole, 2.8 or 3.0 springs. Others at the track in 3 different cars also rip tires but not as fast as me. Is there anything we can do setup wise to help this?
[URL]http://www.fastlanehobby.com[/URL]
Support your local Lowe's, Walmart and Layne Machine Works INC.
HenBeav is offline   Reply With Quote
Old 11-08-2010, 03:55 PM   #608
gonzo416's Avatar
Trader Rating: 39 (98%+)
I figure I should post this on this thread because it has to do with Thunder Power. I have a 1S Thunder Power Lipo battery and some how the voltage dropped below 3.7 and the charger does not wan to charge it. This battery is about 2 months old. I am pretty good with my batteries so It boggles me how this happened. I also have another 1S and 2 2S packs that are swollen and I'm scared to charge them in fear they will explode. I am asking to see if I there is any recourse, as this was a good sum of money I spent. I am in no way bashing Thunder Power as these batteries have been very strong and work very good. They are all I buy.
Any help would be appreciated.
gonzo416 is offline   Reply With Quote
Old 11-08-2010, 05:37 PM   #609
What charger are you using? Is it even too low for the recover function on the thunder power charger?
Old 11-08-2010, 05:40 PM   #610
HarryLeach's Avatar
Send a message via AIM to HarryLeach
You said it dropped below 3.7, if it's still above 3, make sure your charger is set for a single cell, not a double cell pack. Between 3V and 4.2V shouldn't make any charger hiccup if you have it set up correctly.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 11-08-2010, 09:54 PM   #611
ThunderPowerRC's Avatar
Hello Gonzo, insted of posting here you should have called Thunder Power direct and ask for tech support. 702.228.8883 Yes you have recourse and we will be more than happy to help you out.
ThunderPowerRC is offline   Reply With Quote
Old 11-08-2010, 11:21 PM   #612
peter_robinson's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Paul L View Post
I have, i would start at 1,000R and 200,000 F if your going to try it.
What did you think of it over a spool in front? Was it on carpet?
For orders or inquiries, email sales@rc-trim.com. Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 11-09-2010, 01:34 AM   #613
jake95's Avatar
Trader Rating: 27 (100%+)
hi paul im running an xray t3 10 and it is taily and understeers any advice the track is low grip to
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 11-09-2010, 06:12 AM   #614
Gravity RC
Thanks,
JG
Cool, no problem.
Originally Posted by Lonestar View Post
Hi Paul
Thank you!
Regards,
Paul
Hi, it sounds to me like your shocks are pretty thick at 50wt 1hole, I normally use 3hole 700ft and 3hole 550R. I would try that first. after that i would try the 2.25 shimming in the front end (shimming out the front suspension mount holders to 2.25mms). you can also try adding 1mm to the rear camber link on the upright. those are the first things that i would play with on the car. hope it helps, Thanks.
LOL, it is true but it wasnt to prove a point. I was like 14 and just did it to be a dumbass.
Great!
I normally mount mine off the back of the tower, but honestly i dont know what i get by doing it that way. I have never really set out to test it but im sure it does work a bit different.
I have seen this problem before but its pretty hard for me to put my finger on why it happens to some and not to others. I think a lot of it has to do with driving and set up. from what i know of your set up its not crazy, normally more caster does make this happen more, are you running 6deg blocks by any chance. sometimes it just happens also BC of the tire/track. if it is a big problem i would suggest trying a different tire that everyone can agree on that does this less at your track. BC everyone scrambling to figure it out is going to be frustrating and possibly pointless.
Hi Gonzo. Talk Jim at TP and will Help you out with whatever he can do. I would like to ask how you are charging/ running your batterys though, I charge at 5 amps and dump them pretty hard in my mod TC and i have never had a problem with swelling. Thanks
so far i think it works pretty well, it was just different. i cant say that the car had more or less steering or anything. i think that the diff feels like it has less traction but can make smoother lines when driven right.
Hi Jake, It sounds like you are just lacking overall grip. when that happens to me i just try and get rear traction even though it wont help the understeer problem. i would moove weight forward in the car, this will add overall grip, and i would run more rear toe than usual, maybe 3.5deg.
from their i would work on my tires. After you run i would clean the tires with sauce on a rag then sauce like normal. I Hope something sticks, Thanks.
Old 11-09-2010, 12:08 PM   #615
gonzo416's Avatar
Thanks for the info. I appreciate it.
Hi Gonzo. Talk Jim at TP and will Help you out with whatever he can do. I would like to ask how you are charging/ running your batterys though, I charge at 5 amps and dump them pretty hard in my mod TC and i have never had a problem with swelling. Thanks.
I charge @ 5 amps and we run 5 minute quals and main. I will be calling them. Thanks
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
