Old 11-02-2010, 02:49 AM   #586
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
Hi Paul,
I found the culprit, or at least one of them with my terminal understeer. It turned out to be over tightening of the top deck screws. Now the car turns in better and is better on power too.
There still seems to be a factor I am missing though. After a race meeting I attended on the weekend it seems that the biggest influence on the handling of the car is how the car is prepped from the time the kit is first assembled to the first time the car is put on the track, not the setup on the car.
I have also noticed on many occasions that a track changes alot from a club meeting to a major event. The biggest problem my friend and I ,and probably 99% of people, are having is the changed track conditions influence this unknown factor of the car and setup changes have no effect. I have had my car understeering at one event and oversteering at another and not one setup change has had an effect on the car. I also tend to think that some people fluke the unknown factor and that is why there car is handling better in changing conditions. But then I could be wrong.......
Just a bit of food for thought, hopefully I can do enough testing over the next few months to figure the mystery out Failing that, whats your hourly rate for you to prep my car and give it a test run
dontfeelcold is offline   Reply With Quote
Old 11-02-2010, 08:52 AM   #587
Gravity RC
Originally Posted by HarryLeach View Post
Always more than one way to skin a cat, thanks for the feedback.
no problem!
Originally Posted by ronaldo-1234 View Post
Hi Paul,
Do you have any setups for T3 EU Rubber on Asphalt (Hot climate areas like Thailand) ? How would you change the setup as the track temperature rises and falls?
Hi. out of all the set ups that i have had for sure my 2010 reedy race set up was the easiest on tires, In hot conditions it is very important to have a car that turns really well and does not Kill the front tires. normally this means that the set up must roll a good bit to not work the front tires too hard but also has really good steering. lastly once you achieve a car that does so you have to drive super smooth and really try to not slip a tire, especially on corner entry.
That was definately the key to me being competitive on asphat at a few races this year. as for specifics on set ups i dont really have anything that i would do different for super hot weather. i dont really get to test a ton under those conditions. the hotter it is the smoother you must drive.
hope that helps.
Originally Posted by dontfeelcold View Post
Hi Paul,
Wow, i totally agree that for some tracks the "normal" set up changes dont really effect the overall result of the car atall, as the things that you wouldnt think of might. Thanks for the info.
Paul L is offline   Reply With Quote
Old 11-02-2010, 05:54 PM   #588
Trader Rating: 77 (100%+)
What is your favorite servo to run in your car? Thanks for the help.
goin2drt is offline   Reply With Quote
Old 11-02-2010, 08:41 PM   #589
Customworksking's Avatar
Trader Rating: 73 (100%+)
Thumbs up U
Hello Paul lites on,
Kevin here where r u running now days? Scotty went to dirt correct? If he runs 1/8 e lmk
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 11-02-2010, 11:31 PM   #590
R3VoLuTiOn's Avatar
Trader Rating: 26 (100%+)
I run my T3 2010, currently in the 17.5 non boosted class. I run my FDR from 3.8 to 4.4 on two tracks. Ive noticed halfway through a qualifier if I'm running a low FDR, the car seems slower. The temp of the motor off the track is < 150deg, and the RS has never had more than 2 LED's light up.
What could it be? Could it be the motor? Battery?
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 11-02-2010, 11:47 PM   #591
Trader Rating: 16 (100%+)
Default Clarification on Ackermann
Thanks PauL for the write up on hot weather set-ups.
I have nv used ackermann as a tuning tool bcoZ i dun uds the concept behind it. I tried reading up on it last nite but I am still clueless on the final effects.
Ackermann is the angle difference btw the inner and outer wheel at full lock. Greater Ackermann means more angle difference between the inner and outer wheel implying that the inner wheel will travel less (@ slower speed) and outer wheel will travel more (@ faster speed). Thus, can i presume that it give the car better rotation (bcoZ it pivots abt inner wheel) around the corner and also more initial steering?
how does ackermann affect initial steering, steering thru mid corner and exit?
On the older T3, what ackermann position (servo post, Servo saver & steering block) will u use for a Medium sized track than have only 1 high speed corner, 2 medium speed, and 4 hairpins??
I noticed most of ur steering post at #2, but the kit manual uses #1. What is the rationale behind this?
Sorry if i'm asking too many qns. Really lost on this topic.
ronaldo-1234 is offline   Reply With Quote
Old 11-03-2010, 01:01 AM   #592
It was interesting to note at a race meeting I attended on the weekend, I and most others had this issue. One guy who is normally fast also had this issue until one of the qualifiers his car all of a sudden had excellent steering and TQ'ed that round and placed second overall. He gained about 0.5sec on his best lap. I overheard from his Dad that he changed the diff before that run.
Old 11-04-2010, 09:12 AM   #593
Gravity RC
for the T32011 i have found that i like the Futaba 9351, its a bigger servo and ballances the car nicer with the servo boing tucked in so far. for the T3 i like the BLS 551.
Hi Kevin, good to hear from you. I run at Harbor hobbies now. its not too far away. i think scotty is doing electric 8th scale
It is normal to have some tail threwout the run but it sounds like maybe yours is worse than it could be. First i would try would try a new Rotor, it is possible that the rotor gets weak even at lower temps, secondly i would try a different battery and lastly the speedo.
it could be any of these.
but make sure that your not chasing it if it is a normal amount of tail. last time i ran 17.5 non boosted i was able to run .1 to .2sec faster the first portion of the race than at the end.
No problem. for me the less ackermann i use (tires more paralell) the more steering i normally have, especially on power.
their is such a thing as perfect ackermann for a single given corner, the radious which the inside tire must make is shorter and sharper than the radious that the outside tire must make, this is why ackermann is applied any car. normally for carpet i will take ackermann away untill the car is loose off the corner for me then go back 1 incroment in the other direction.
On asphalt we worry about overheating the front tires so much that i take a different approach, with a spool in the front on asphalt the tires fight eachother so much threw the corner ( the tires are not able to diff and adjust for the distance that one tire must travel in compairison to the other in a given corner) so ackermann must be used properly to keep the tires from fighting eachother and heating up as much as possible. so on asphalt i will normally try and use more ackermann (more difference in angle of the tires while turning), that is if i can get the car to have as much steering as i need.
I always use full lock steering throw, so my inside tire never changes, at full lock the inside tire always turns around 30deg, so all that i am changing with ackermann is where i want my outside tire to be, roughly between 17 to 20 deg at full lock depending on the setting.
In the end its not all that complicated, for me if i need more steering i use less ackermann (tires more paralell) if i need the car to drive easier i use more ackermann (tires less paralell).
For sure With Ball diffs it is very important to have a perfect diff, the car will drive easier and carry more corner speed. Thanks
Old 11-04-2010, 01:10 PM   #594
jgraham37128's Avatar
Trader Rating: 24 (100%+)
Default balance
Paul, I noticed you said you use a larger servo on the T32011 since it's tucked so far in the chassis. My question is how do you balance your car when building it? How do you know it's more balanced with a larger servo versus the low profile?
Thanks,
JG
jgraham37128 is offline   Reply With Quote
Old 11-04-2010, 08:08 PM   #595
Gravity RC
Thanks,
JG
Hi, i know roughly what a section of the battery wieghs on the other side, with the servo being tucked in so far it just ballances better with the bigger servo. I ballance my car with the hudy pins from side to side. normally if i add lead it is across from the motor, and with a bigger servo or weight by the servo.
The left rear (motor) and right front (battery across from servo and reciever) are normally heavy on TC's even if they ballance well overall on pins. This is all static weight, nothing to do with cross weights for tweak.
no problem. Paul
Old 11-07-2010, 06:27 AM   #596
peter_robinson's Avatar
Paul,
Have you messed with running gear diffs front and rear? If so, what oil have you tried?
For orders or inquiries, email sales@rc-trim.com. Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 11-07-2010, 05:34 PM   #597
Gravity RC
Originally Posted by peter_robinson View Post
Paul,
I have, i would start at 1,000R and 200,000 F if your going to try it.
Old 11-08-2010, 04:06 AM   #598
RCknight's Avatar
Paul, I don't have much experience with sway bars and I was wondering if some light bars would be beneficial in the slower VTA class or not? Should I run a softer springs as well? Also any set ups you know of for med carpet would be great. Thanks
RCknight is offline   Reply With Quote
Old 11-08-2010, 05:50 AM   #599
ToysRUsKid's Avatar
Send a message via AIM to ToysRUsKid
what's up Paul, just here to say hi! How are things going? I know you're happy this year is almost over, it's been a monster for you.
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 11-08-2010, 06:24 AM   #600
Default Ackerman
Paul, thanks for the help on the ackerman. I have two cars one is a t3 2011 I just built and the other is a T2 009 EU. I noticed on the T3 the outside tire is at 30 degrees and the inside tire is around 20 degrees at full throw. On my T2 09 it's 30 degree on full throw both left and right but the inside on the left is 17 degrees and when I turn it to the right it's 20 degrees. What can I adjust to make both the same on the inside tire?
Thanks,
JG
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
