Old 07-12-2010, 03:13 PM   #421
Originally Posted by Paul L View Post
Thanks guys , sorry i let you downLOL.
Thanks ED, sometimes it wasnt so pretty but in the end it was good.
Hi again, I do use servo tape to hold my battery in. I use a 5mm wide strip going across the battery at the very front of the battery and at the very rear.
This way the chassis flex's perfectly underneath. Keep the serfaces clean and it wont come out, dont use too much servo tape, otherwise you will never get it out. .
Thanks Paul for your response.
And i do not think you letting us down, i have really enjoyed to
watch and see you and of course all others driving the A-main.
I have to wait for a chassis like you, in the meantime I had a response from Xray that they are looking seriously for this chassis to make this as a option part, i hope they dont wait to long.
Regards YGM.
Ed
eded1 is offline   Reply With Quote
Old 07-13-2010, 08:24 AM   #422
Gravity RC
Regards YGM.
Ed
Cool, i think that they will do something like it for sure, they had chassis at the worlds that looked very nice but i did not have time to test it all. so we will see.
Thanks. Paul
Paul L is offline   Reply With Quote
Old 07-13-2010, 09:25 AM   #423
Johnny Wishbone's Avatar
Hey Paul,
Your Worlds setup sheet looks pretty empty, could you check it out, again. **Never mind, I guess I caught you inbetween working on it.
Whats a DNA wing look like compared to the other PF wings, is there a pic of this wing somewhere that a person can see what it looks like, AND why do you prefer that wing? Is that for asphalt, carpet or both?
Thanks, and thanks for your last response, exactly what I was looking for.
Old 07-13-2010, 10:04 AM   #424
Gravity RC
Originally Posted by Johnny Wishbone View Post
Hey Paul,
I think that wing has just a touch more high speed steering. it is the wing off of the protoform DNA Foam or Dna rubber body. I have run it on asphalt and carpet but i am more likely to use it for asphalt.
Old 07-13-2010, 10:37 AM   #425
Way2Evl's Avatar
I was wondering why you take other routes to stiffen up the chassis than just using the chassis post. Like counter sinking the top deck, suspension arms, etc..
X-Ray T3|Tekin|KO Propo|Spektrum|Thunder Power|Hyperion|Sorex
www.speedworldraceway.com
Way2Evl is offline   Reply With Quote
Old 07-13-2010, 11:35 AM   #426
Gravity RC
Hi, I dont have a great answer for that, i countersink the top deck just because it is a more solid way to mount it, the chassis post reduces the flex a lot and also shorten's the distance between the pionts of flex, we have gome away from short top decks for that reason. on my really soft chassis car i did use the chassis post behind the steering to make it stiffer.
suspension material stiffness is a totally different thing but i have not been able to test it that well lately.
Old 07-13-2010, 12:06 PM   #427
Way2Evl's Avatar
And thank you for all your answers to my questions. I really appreciate it and it helps out tremendously!
Old 07-13-2010, 12:28 PM   #428
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Hi, I wouldnt really change anything on my car but i think that my cars have well ballanced set ups right now. If your in the situation where your car works when its cool but dose not work well when its hot, then i think your set up is off in the first place. with good tires and a cool track almost every set up will work decent, its when the track is hot is where the set up flaws really show.
But i would thinka softer chassis and suspension when the track is
really hot could be better in a lot of cases. I would moove the shocks in on the arm to make things sofer instead of changing the oil and springs, that should work the tires much less.
So get the two hole arms front and rear to soften the car up? Why would you say try that over shock oil or a spring a spring change? Thanks!
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 07-13-2010, 01:12 PM   #429
Way2Evl's Avatar
I think he said the outer hole of the two hole suspension stiffens up the car. I'll let him answer though.
Old 07-13-2010, 01:38 PM   #430
He said to move the shocks in on the arm, and theres only one hole with the stock ones. Whats the difference with the two hole arms though, is both holes in a different spot or just one?
Old 07-13-2010, 02:32 PM   #431
JayL's Avatar
the holes are inside and outside of the one-hole IIRC
JayL is offline   Reply With Quote
Old 07-13-2010, 04:36 PM   #432
Way2Evl's Avatar
Maybe he meant to move the shocks on the tower because he just told me The outer hole is stiffer and i think the inner hile is for more steering. The two hole suspension arms have a hole to the right and left of standard arms.
Old 07-13-2010, 05:14 PM   #433
JayL's Avatar
Paul's quotes:
" if you go with the outside holes the car just becomes stiffer, the shock has more travel that way so the car will drive much more direct. "
"I would moove the shocks in on the arm to make things sofer instead of changing the oil and springs, that should work the tires much less"
which makes sense, the leverage comes from the distance from the tire to the shock mount:
outside hole, arm has less leverage thus stiffer
inside hole, arm has more leverage thus softer
Old 07-14-2010, 05:47 AM   #434
Gravity RC
No problem!
I say that because a spring change can get weird, in most spring sets the jump is not only its stiffness but its progression also with number of coils as well as wire size changing.
That being said, the arm change is Huge also but atleast you know your simply increasing or decreasing the moovement of the shock threw travel the suspensions travel, thus resulting in the car being stiffer or softer, "spring and oil".
yes the outer hole would be stiffer and the inner hole softer.
both holes on the two hole arms are defferent from the one hole arms. one to the inside and one to the outside.
Maybe i told you something conflicting or we wernt on the same page.
jays post below should help when broken down like that.
Originally Posted by JayL View Post
Paul's quotes:
Thanks for the breakdown.
Old 07-14-2010, 05:53 AM   #435
Gravity RC
I would like you guys to know that im not saying that the two hole arms are always better.
I honestly think that in many cases the one hole arms are the best. At the Worlds i used the 2 hole arms but their were reasons for that.
high minumum weight and big tires, if that race is 1350G minimum weight and normal size tires i most likely would have had one hole arms on my car.
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
