Old 01-17-2014, 02:29 PM   #2611
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I hope I'm not speaking out of turn, but I think I have some info that might help in addition to what PL said. If you don't mind sharing the track surface, size and sauce used we might be able to direct you even better.
A. I don't know what tires you're using, but I have had success mounting brand new VTA tires on a powerful truer and then saucing each tire on the truer before you turn it on. Then put a little sauce on a 100% cotton rag. Wipe the tire down as well as you can before you start the truer. Be sure your cutter won't advance into the tire, you just want it spinning. Run the tire away from you and hold the sauced part of the rag on the tire. You want to get heat and sauce into the tire without stalling the truer. The tire will heat to 300*+ in a matter of seconds so be careful. Go through each tire this way and after a session let each tire cool down. 3-4 cycles of this will break the tires in beautifully.
B. I don't know what weight your GT runs at, but you may have problems with the same set up if it is drastically different than the 1550 for USVTA. The heavier oil and springs that make a VTA car work, may not allow the lighter GT car to work right.
C. In addition to the type of body, I would check to see that the GT body isn't rubbing. Different bodies and tires may require different post heights, which might allow the tire to rub under load.
Old 01-19-2014, 11:51 PM   #2612
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
just curious why i rarely see anyone using graphite battery strap.
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 01-20-2014, 06:14 AM   #2613
Customworksking's Avatar
Trader Rating: 73 (100%+)
Hello Paul I been dying slowly I need to race again I bought a boat,vette,chopper a few houses and still unhappy hope I still have my spot on the team LMK Kevin Bottoms
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 01-20-2014, 06:49 AM   #2614
I've heard it can tweak the chassis.
Dustin Brant - Fort Myers Fl
On-road T4'13, T3R, F104v2, x12'14, T3 Nitro
Offroad Desc210r, Desc410r, Dex210, Revo
Fladust is offline   Reply With Quote
Old 01-20-2014, 09:09 AM   #2615
Meradin's Avatar
Trader Rating: 19 (100%+)
Best comment I heard about the graphite battery strap...
"Why would I want an extra top deck in my car?"
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Meradin is offline   Reply With Quote
Old 01-20-2014, 04:55 PM   #2616
ToysRUsKid's Avatar
Has anyone had to shim the motor out from the mount to prevent the pinion or rotor? (not sure what to call the piece the pinion is on) from rubbing the battery? I couldn't get a centered mesh with the pinion/spur either until I put 1mm shims between the motor and the mount. Very possible I'm doing something wrong.
Old 01-20-2014, 05:14 PM   #2617
1AGOFST's Avatar
I found that the brand of pinion makes a difference. I use CRC and no longer have this issue.
1AGOFST is offline   Reply With Quote
Old 01-20-2014, 09:14 PM   #2618
Trader Rating: 20 (100%+)
Originally Posted by ercwhtsd View Post
I would probably use soft/soft for Eclipse and med/soft up by us.
Been a while Eric but I appreciate the help. Sorry I haven't made it up to the track this season.
As a quick follow up, I have found a decent setup at Eclipse with soft rears and med fronts. Starts really well and finishes good just a touch loose at the end. I think with a bit more work (read: Practice) I'll be OK with this down here.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 01-20-2014, 10:26 PM   #2619
Check the spacing on the sensor side of motor. If you shim the rotor to about 1 mm from the closest hall sensor, you might move the rotor far enough into the can to get the clearance you need.
Old 01-22-2014, 09:19 PM   #2620
ToysRUsKid's Avatar
Originally Posted by Paul L View Post
Glad it worked well!. No Their is nothing more. When i say starting point its just where i would start on almost any given track. From that their will be variables which may need some extra tuning to get perfect. Variables that will make a difference from one driver to another might be. Driving style, speedo, car , track layout, grip level, tire size, air temp etc etc. So one set up is never perfect for everyone. But i try and get my "starting points" to be as universal as possible.
Thanks!
I picked up a new 17.5 TP and added a the green rotor for 12th scale. Got a good "starting point" on gearing? I usually run a 42.5mm rear tire to start the day.
Old 01-23-2014, 08:11 AM   #2621
Gravity RC
I personally don't use it because i just hate bolting anything to a car that is not necessary to the function of the car.
LOL, thanks for teh call!
LOL. Im sure that if the graphite system were shimmed and fastened properly it would not tweak or make the chassis stiffer. If tape pisses you off then its a good option.
Its always been a tight fit for me too, some motors do have longer shafts than others. I wouldn't be against cutting the motor shaft some if that is the issue. Also the pinion as stated. Thanks!
Cool! Its possible that more bite in the track could cure that. Otherwise maybe a softer side spring with saucing a bit more front tire could help. (softer side spring for more rear grip, A touch more front sauce to keep the steering you are used to up front)
Honestly i don't. Gonna need some help on this one for sure. sorry
Paul L is offline   Reply With Quote
Old 01-23-2014, 08:31 AM   #2622
peter.'s Avatar
congratulations paul whit your deal with hobbywing
peter. is offline   Reply With Quote
Old 01-23-2014, 10:54 AM   #2623
ToysRUsKid's Avatar
I guess it's a good thing both of my ESC's are Hobbywing
Old 01-23-2014, 11:43 AM   #2624
ToysRUsKid's Avatar
XRay Car, TP Motor, HW ESC, Futaba electronics, Gravity Fan...
I think I'm Paul Lemieux
Wait...gotta work on my driving...
Old 01-23-2014, 01:58 PM   #2625
Congrats Paul for extending with Xray and congrats with the Hobbywing deal.
Some persons deserve it to be a teamdriver.
eded1 is offline   Reply With Quote
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
