Ask Paul Lemieux, RC America/MOTIV/Gravity RC
#2551
Hi Paul. I'll be running in Omaha in the up coming nats. Its my local track . We race club every week. Top 3 are always xray. Luckily im the top 3. As of lately I have been loosing ground on time. Ex. Top 20 ave lap is 10.9 top xray and I'm stuck in 11.4. I just feel like my corner speed just not there . And also punch. I run thunder power. And speed passion ESC. In 17.5 class. What can I do to get corner speed and punch.
#2552
Also we have winter series and top driver from out of town with awsomatix killed us. Lap times out of this world for myself to get to. Around 10.2 or so.
#2553
Hi. Last time i ran 17.5 i ran my thinderpower at 35deg timing, green rotor, geared at 3.7, similar size track. seemed to be decently fast. as for the car you need to make sure the set up is balanced and drives good and it will carry corner speed. Maybe post your set up then tell me what you think it could do better and i could shoot you some suggestions or a while new set up to try.
Thanks!
Thanks!
#2554
Was that before or after ya burnt the first one down Paul?
#2555
Thanks!
Thanks!
Holders are .0
Roll center is quick change inner high on tower
Link have 2 mill spacer
45 wight 2 hole in shocks
3.2 spring
Shocks down
Fron ani roll bar #4
In back
Holders -.75
Roll center inner lower
Link has 5 mm spacer and link is short
40 wight with 4 hole
2.6 spring
Socks down
Anti roll #2
100 spur
46 pinion
Standard rotor
35 degree timing.
#2556
Up front.
Holders are .0
3.2 spring
Shocks down
In back
Holders -.75
2.6 spring
Socks down
Anti roll #2
100 spur
46 pinion
Standard rotor
35 degree timing.
Holders are .0
3.2 spring
Shocks down
In back
Holders -.75
2.6 spring
Socks down
Anti roll #2
100 spur
46 pinion
Standard rotor
35 degree timing.
On the motor i would try the green rotor and gear it up to a 48 pinion.
I would also try running the car softer for starters, 4hole 40wt all around with 2.4 spring rear and 2.6 front. also stand up the rear shocks one and the front up 2. That is what i would try first but it will take some tuning with droop and camber.
good luck!
#2557
#2558
Lol, we both had issues with motors that weekend, mine just still works.
#2559
Will going softer help with traction rolling. As traction comes up I have be very carefull not to traction roll
#2560
Yup, definitely a softer set up will help with traction roll. It will help reduce the high pressure spikes threw suspension/tire to the ground and it will also let it roll more to drag the chassis on the ground before it has a chance to traction roll.
#2561
Paul thanks for all the info over the past few weeks about traction rolling and sweep tire traction .
I will say knowing what affect camber link changes makes made all the difference in the world once the springs were chosen . in a Yr I haven't moved a camber link . lol but this past weekend at the champs I pretty much changed them every heat either fighting or aiding traction . I will say tho I cought wind these sweeps used at the champs were on harder wheels and different inserts that others . the stiffness of the rims were night and day with other new sweep tires (these were 15+-% harder at the race ).
All and all I got the old T4 working great made some fast laps with my set up just the driver couldn't do it every lap . will say tho Brock's T4 was nice . .2 slower but way more stable . going to try his/Ur spring/oil setup when I can get some 2.3s
#2562
Special "package" delivery.....Signature required...
#2563
Confucius says “Never impose on others what you would not choose for yourself”
