Old 10-15-2013, 01:49 PM   #2461
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
Originally Posted by Skiddins View Post
Can't you just increase the ride height a bit?
I did try that I went droop but it just laid over that much more . and still had major buildup . they r using a verity of traction compounds at this track which I'm sure is why I had more buildup than normal (not my normal track i run at ).
I also tried to limit droop to 1.5/3mm f/r but it didn't have the corner speed That it did with 3/5mm droop . tks for the link Whiteside I'll have to pick some up to try .
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 10-16-2013, 11:37 AM   #2462
Gravity RC
Originally Posted by R3VoLuTiOn View Post
Not sure if theres another thread for the Gravity stuff.
Got my hands on the canister and LGC kudos to Kody @ Emerald City RC
LOVE THEM.
Awesome! Thanks
Originally Posted by PROMODVETTE View Post
Paul, on your 1/12 tires, what do the soft/med/hard equate to as far as the color ratings from other mfgs? Just need something to compare to when someone says to run black or pink etc. I tried to hit them with a durometer but there isn't enough rubber on the wheel
Yea, when they get thin the Durometer wont be accurate. Soft is 30, med 23 and hard 35. I have a super soft rear that i am working on but im not sure on a release date of those.
Originally Posted by Stratus Racer View Post
Special thanks to Paul Lemieux for all the help with my car this weekend at IIC. My car was hooked, my driving was my biggest obstacle. Your help helped me win both of my mains. Paul, you rock!
Glad i was able to help! see ya!
Originally Posted by rosko View Post
We want to c some iic set ups
I just got home last night so i will be working on that soon. Thanks!
Originally Posted by R Doyel View Post
Hey Paul, I'm going to run 10.5 blinky touring at Speedworld for the first time, this weekend. The guys there are saying to start at 5.7 FDR, but I'm wondering what endbell timing would be good. It is a stock out of the box Thunder Power 10.5.
Thanks!
Hi. 5.7FDr sounds pretty safe. I would start at 35deg end bell timing and monitor the temps.
Originally Posted by jlfx car audio View Post
This past weekend I can at a track with low/med traction and my car was really good but I noticed its rolling a lot in the corners which seemed to give the most corner speed but in the last 5 laps or so it seemed to bind up in a few tight corners as the chassis is getting a lot of buildup on it ( it was cleaned between heats) have u figured anything out with the chassis drag issue? For me it would seem like a Teflon tape would be the ticket if there was such a product. Hint hint.
Good hint . I have never tested anything like that, surely now the cars are dragging more than ever so maybe it is time for something like that.
Thanks!
Originally Posted by EAMotorsports View Post
Just FYI Paul is not due to be home till tonight or tomorrow. He stayed over in Vegas to go over to Thunder power for a couple of days.
EA
Thanks EA
Originally Posted by ercwhtsd View Post
maybe i will buy some and give it a try. Thanks!
Increasing the ride height will help some but not as much as you would think, unless you go 6.5mms or more, then the car will not handle well. My Advice when setting up a car is to not worry about the chassis drag, If it handles well and drags it dosent bother me at all. But that dose not mean that i wouldn't try some tape afterwards without changing the set up.
Good conversation. yes, if its dragging, let it. you could go higher ride height, higher roll centers, thicker oil stiffer springs etc etc, but in the end you will just have a car that drags less but dose not handle well.
Paul L is offline   Reply With Quote
Old 10-16-2013, 12:04 PM   #2463
AOD
AOD's Avatar
Paul did you and Dave kiss and make up?
AOD is offline   Reply With Quote
Old 10-16-2013, 01:22 PM   #2464
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 10-16-2013, 02:25 PM   #2465
Thanks Paul. Going to pick up some of that tape also. Its worth a shot . I've tried waxing the outer edges of chassis lol but by the time I'm ready to actually race its gone ,does no good ... The tape might be the same way just start coming off thru out the race but I'm going to see.
Different question same topic. How do u use droop with given traction levels ?
I know back at Drew's race last winter I found Ur droop #s vs my measured droop numbers r very different . which is fine BTW. But in general do u change droop for different traction levels ?
Justin & Matt Lyons
a800s sanwa m12s
Old 10-16-2013, 03:11 PM   #2466
chasingthepack's Avatar
something i do for chassis rub is when im cutting a new bodyshell i save the thinest part and cut 2 strips,at the mo i only put a 40mm strip under the motor with a piece sticking out to protect the motor as that can scrape as well,i stick it on with shoe goo,this is mostly due to a banked sweeper but the other strip goes on for other tracks,this stops the chassis from wearing away
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 10-16-2013, 03:37 PM   #2467
Yea I would be doing this also if I raced on outdoor tracks . I'm sticking to carpet. All the decent /good tracks within 4hrs of me closed down /stopped racing
Justin & Matt Lyons
a800s sanwa m12s
Old 10-17-2013, 12:05 AM   #2468
Paul, I cant thank you enough for your help at the IIC, I was really struggling after the first day of practice, and your help really turned things around.
Again, thank you very much.
Rich
gdcopbdcop is offline   Reply With Quote
Old 10-17-2013, 09:31 AM   #2469
Gravity RC
Not yet
In the past i would have thought that with higher grip you can use more droop but i don't think it is that cut and dry. all i can say is that 2.5-3mms of droop over ride height is standard now for almost every situation. I have used way more and less before, but only in special circumstances.
That's a good tip for asphalt if you don't like scratches.
Rich
No problem Rich. I could tell that you were not having fun do to the car so thats when i step in.
See ya!
Old 10-17-2013, 09:32 AM   #2470
Gravity RC
IIC Set ups.
I did not see any "14" set up sheets on line so i did them with the standard sheets with text on the bottom for the changes of the new cars.
http://forum.teamxray.com/xform/inde...D=91&setup=x12
http://forum.teamxray.com/xform/inde...D=567&setup=t4
Old 10-17-2013, 10:14 AM   #2471
Did u run all the top deck screws?
Justin & Matt Lyons
a800s sanwa m12s
Old 10-17-2013, 11:08 AM   #2472
Skiddins's Avatar
..And what shims on rear outer camber link?
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 10-17-2013, 01:37 PM   #2473
Originally Posted by Paul L View Post
IIC Set ups.
would you mind filling in this one paul?
any asphalt set ups?
http://www.petitrc.com/reglages/xray...SetupSheet.pdf
Old 10-18-2013, 07:04 AM   #2474
Gravity RC
I only ran the front most 4 and rear most 4 screws in the deck.
Skiddins
sorry 4mm
oh where did you get that? I will try . Im kinda stupid when it comes to stuff like this, would i then save it as a pdf then attach the file on here??
Old 10-18-2013, 08:33 AM   #2475
Skiddins's Avatar
... would i then save it as a pdf then attach the file on here??
Yep, just use a pdf editor to fill it in then save it, and add it on here as an attachment.
This does appear to be something that Xray have missed (for the first time)
There was no editable sheet available for download and nowhere on the setups section of the Xray site for the new car
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
