Old 07-23-2013, 08:59 AM   #2341
chasingthepack's Avatar
Originally Posted by Paul L View Post
If the Mesh is proper a spur will last a long time. for carpet i will use the same gear for several races, on asphalt with some small stones and debris i may not change for a while or with some bad luck possibly once or twice per event, At ETS i made the whole week with the same spur.
Hi Steve, Thanks! i needed more luck than that, lol. im sure ill see ya soon.
No problem!. Yes the kit comes with a tall shim to put under the ball stud on the steering rack. as for offsetting the servo horn or saver I am not really 100% sure on that. I have had that conversation with many people and their seems to be a good argument for both sides. I run my servo horn straight up but i could be wrong.
thanks
i can only account for the savox servo,the savox doesnt have as much throw as some others so the horn needs to lean towards the top deck to get an even throw,epa will still be different from side to side to get it spot on
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 07-24-2013, 07:11 AM   #2342
Gravity RC
Originally Posted by rosko View Post
Was any new parts tested at the ets race
Hi Rosko. I did see some new steering bits along with the new belts, new layshaft bulkheads and i think a chassis but i did not get a chance to look at it closely.
Originally Posted by Troy Carter View Post
hey Paul,
I know you seem a bit down on your performance at ETS but we are all proud of you here. That's some seriously tough competition and you did well.
Last time I was on here I was struggling with a wiggle in my car coming out of faster corners running mod at Leisure Hours. I had tried to mimic your 2013 Nats setup but I ended up going back through the car and found a couple things that were not what you had. I reset the car with your Nats setup and headed out this week. No more wiggle! I did discover the rear toe was only at 2 and I think that played a big part of the problem because it didn't lock the car in under power.
What do you think about springs? Have you tried the progressives all around? I changed from the 2.3's in your setup to the soft progressive springs and the car stopped lifting a tire in mid speed turns and was better under braking. That made it easier to drive for me which was good but I wonder what a firmer spring like the 2.5's or firmer progressives all around would do.
Thanks,
Hi, for a high speed track such as leisure hours i think stiffer could work, At the hudy arena (also super high speed) most of the team ran the 2.5/2.8 spring all around, I ended up on the 2.5/2.8 in the front with standard 2.5's in the rear.
im glad that you fixed the wiggle in your car!, and yes the stiffer springs are for sure a option.
Great, Thanks!.
Paul L is offline   Reply With Quote
Old 07-24-2013, 10:55 AM   #2343
esckalayd's Avatar
Hey Paul,
I have a 4.0T motor that I am going to be using in my T4 to run at Kissimmee/Full Throttle. What gearing would you recommend i start with? And another rookie question, do you make you speed adjustments with the motor and ESC with a mod car or are you changing gearing frequently?
Anthony Schimizzi AKA ~The Rookie~
| Serpent America - DeSoto Racing |
esckalayd is offline   Reply With Quote
Old 07-24-2013, 03:44 PM   #2344
Gravity RC
Originally Posted by esckalayd View Post
Hey Paul,
Hi Anthony, I would gear around a 8.3, from their it is all in the speedo set up and static timing. I rarely change the gearing.
Old 07-24-2013, 05:56 PM   #2345
Hi Paul,
Is it possible to post your T4's setup for last ETS race in Hudy Arena ?
mos-leung is offline   Reply With Quote
Old 07-25-2013, 05:01 AM   #2346
esckalayd's Avatar
Forgot to ask, do you run 64P or 48P gears? I'm not sure how well the 64P gears would hold up under the wear and tear and braking. With the internal drive (1.9) and 48P gears a 99/23 puts me at 8.178.
Thanks for the info. Looking forward to seeing you at Full Throttle soon. Hopefully George and Steve can entice you to come down and show us all how its done.
Old 07-25-2013, 08:46 AM   #2347
Trader Rating: 27 (100%+)
If you use 48p, 84/19 gets you to 8.4
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 07-25-2013, 09:03 AM   #2348
Skiddins's Avatar
An 86t 48dp spur is about the largest you'd want to fit, and even that is level with the bottom of the chassis.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 07-25-2013, 10:32 AM   #2349
esckalayd's Avatar
Thanks for the info guys, haven't been running the T4 long, but the 3 races i have i ran 17.5 and will be moving to mod. I will pick up an 84T and 86T 48p spur with a 19T and 20T pinion. That should give me enough to work with.
Old 07-26-2013, 06:18 PM   #2350
rosko's Avatar
Paul do u use the standard motor mount or the optional mount? Do u know the intended purpose of the optional motor mount
rosko is offline   Reply With Quote
Old 07-26-2013, 06:51 PM   #2351
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
What'd up Paul ? Been about 7months since I visited this thread (been running off road locally) . any who... Trying to gear up for carpet season early this year. Any tips for spec racing with the T4 u have found ?
And another question. Would u run same oil/piston setup running stock vs mod ? I think spec racing u look for more corner speed than in mod racing since u have less acceleration out of corners, and would think different setups would be recomended or am i off base?
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 07-27-2013, 07:00 PM   #2352
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Paul,
LG1 is a great product. I do not recommend it for suntan lotion on your face. It burns.
That is all.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 07-27-2013, 07:38 PM   #2353
hanulec's Avatar
Originally Posted by L.Fairtrace View Post
Paul,
That is all.
It could be a good chemical peel for reality show "house wives"
That was too funny today...
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-28-2013, 05:11 PM   #2354
EDWARD2003's Avatar
Hi Edward.
I have balanced the rear pod in the past but i do not currently. The chassis i will balance on pins or at least get it close. you can also then ballance the car as a whole and it will be fairly close. I would not add weight, i would move the battery until the balance is better and if you cant do that i would move the electronics around then.
Thanks!
Thanks for you help Paul.
As for the battery, I can't move it. It's in a fixed position. The electronics have been placed and still there is a 13 gram difference. Should I just add lead weight to compensate for the difference or let it be?
EDWARD2003 is offline   Reply With Quote
Old 07-29-2013, 02:40 PM   #2355
Gravity RC
Originally Posted by mos-leung View Post
Hi Paul,
Yup, sorry it took me so long, just been kinda crazy lately. http://forum.teamxray.com/xform/inde...D=477&setup=t4
Hi. I run 64P, if the mesh is set perfect you will not have a problem stripping 64p, 48p definately gives you a little room for error though, either way though i think its not a advantage. ill be down their soon for sure!
Thanks!
Skiddins
Perfect!
When we were doing testing for the T4 we had a different motor mount but i have seen nothing since then so i and i think everyone has been running the kit motor mount. I dont know that a optional one exists for sale?
Hi!. I think it Really depends on the track but i would say that a good mod set up should work well in stock as, im sure their will be little tweaks here and their depending on how its handling that day as always. for high bite carpet i dont think that i have gotten the car much better for it was crazy good last year, for lower bite i think that i will be going back to the 3hole piston set up as the car seems more responsive with the less smaller hole pistons, for lower traction i will start with 3H 1.0, 350 and see how that feels next time.
Good luck!
Paul,
That is all.
LOL, sorry, I recommend spraying it very close and directly to a towel or rag on a windy day. unscrewing the cap and fine tip art brush works well also.
No prob. I would not, I would find a way to move the battery, file a plastic piece or some way to move the battery or make it balanced somehow other than adding weight. I think their is a way somehow.
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
