Old 06-25-2013, 06:58 PM   #2311
Gravity RC
Originally Posted by tufferwilde View Post
Hi Paul,
Do you feel the 1999 Tal Bachman song "She's So High" has proven to have any inspiration to your RC career?
Thank you,
Chris
Originally Posted by dizzy1 View Post
Wilde-I think 1999 was the year of the peniscolada boat experiment?
Originally Posted by R Doyel View Post
I love this thread
lol
Paul L is offline   Reply With Quote
Old 06-25-2013, 09:12 PM   #2312
Bcholka's Avatar
Originally Posted by Paul L View Post
Hi Brian, what speedo/motor are you running? drag brake is super dependent on the speedo and motor/gearing. Thanks!
Hi Paul,
We're running the following:
Tekin RS Pro ESC
Tekin Redline Gen2 6.5t
20t pinion/stock spur
Currently have RS Pro set at 20% drag brake and we like it but still curious what you like to run at.
Thanks!
2-Tekno EB48.2's, 1-Tekno ET48, 1-Tekno NB48, 1-Tekno NT48, 1-Tekno SCT-410, 1-AE B5, 1-AE B5M, 1-Kyosho RT6, 1-Kyosho MP9e TKi, 1-TLR Losi Mini 8ight
Our Awesome Sponsors: Tekno RC, AKA Tires, Dialed Designs Airbrushing
Special Thanks to: Trackside Raceway, Clark R/C Park & RC Scoring Pro
Bcholka is offline   Reply With Quote
Old 06-26-2013, 05:38 PM   #2313
Gravity RC
Originally Posted by Bcholka View Post
Hi Paul,
Tekin RS Pro ESC
Thanks!
I honestly have no idea what the equivalent drag brake would be to mine with that equipment. I run between 20 and 25% normally on my LRP so i can only guess that you are pretty close. I can check it out next time i run in to you though.
thanks
Old 06-26-2013, 06:59 PM   #2314
bhambrent's Avatar
no word as of yet, sorry
Thanks Paul L.
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 06-26-2013, 07:10 PM   #2315
Bcholka's Avatar
thanks
Sounds real good Paul--Thanks much for your response!
Old 07-01-2013, 10:57 AM   #2316
R Doyel's Avatar
Paul, I’ve always used Thunder Power in all of my offroad cars, and had no problems. I’m thinking of switching to TP in my Touring Car. I normally have been running a 5.0 with a little boost, and it has worked well. I was wondering what motor/boost combo you run at Norcal? Thanks!
R Doyel is offline   Reply With Quote
Old 07-01-2013, 12:34 PM   #2317
Gravity RC
Paul, Iíve always used Thunder Power in all of my offroad cars, and had no problems. Iím thinking of switching to TP in my Touring Car. I normally have been running a 5.0 with a little boost, and it has worked well. I was wondering what motor/boost combo you run at Norcal? Thanks!
Hi! i uses a 4.5 at norcal, 25deg motor tining, geared 8.3. LRP flow speedo with 0 torque timing, 3 boost timing, 4 boost angle and activation, 1 turbo timing. this is where i would start, from their you can pour it on a bit with the speedo settings if needed.
Old 07-01-2013, 02:23 PM   #2318
peter.'s Avatar
hello paul
is the thunder power z3r 4.5t a match for the new team orion vortex vst2 4.5t
with top end speed and torque
greetings peter
peter. is offline   Reply With Quote
Old 07-01-2013, 02:53 PM   #2319
R Doyel's Avatar
Thanks Paul!
Ryan
Old 07-01-2013, 11:31 PM   #2320
Team Pink's Avatar
Trader Rating: 20 (100%+)
Paul have you ever tried running a short front camber link, and a long rear? If so what did you find it does. Also what about the other way around; long link front and short link rear? Thanks for the awesome thread! Very informative.
Team Losi Racing/ Spektrum/ Horizon Hobby/ JConcepts/ Hobby Star/ Schelle Racing
Team Pink is offline   Reply With Quote
Old 07-03-2013, 09:19 AM   #2321
peter.'s Avatar
hello paul
Why did you change from hobbywing esc to the lrp flow
Old 07-03-2013, 12:35 PM   #2322
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Good luck in Slovakia Paul.
Old 07-05-2013, 11:50 AM   #2323
Gravity RC
Originally Posted by peter. View Post
hello paul
greetings peter
Hi I have never tested the new Orion motor but i can say that i have never felt that i was at a lack of power with the Z3R 4.5.
Hi. Lately i have been running my camber links middle all around for the most part. with set up it is sometimes a lot of give and take so i would say that the advantage of going to a long front and short rear link would be that the car should have really good forward traction, i think that the disadvantage would be that the car could become hard to drive in quick switchbacks as the rear would stay very flat and the front would have more roll. Of course this is with a hypothetical set up and conditions surrounding the changes. With a long rear link and short front link I think that its advantage would be initial steering and a better rear to front roll balance in the corner but i think that the car would lack forward traction. Im not sure if this across the board with all cars though, because every so often something that seems so set in stone will flip and work opposite as the weight rules power and designs change.
thanks
hello paul
Hi. I have run the Flow at the last few events because i am comfortable with it on normal size tracks. For large tracks i have been more comfortable with the hobbywing, so i still have both as a option depending on the track.
I think ill need it
Old 07-08-2013, 07:45 PM   #2324
Magnet Top's Avatar
Sifu,
I wanna go to Slovakia too... can you stash me in your luggage ?
The very best of luck bro, not that you need any.
Jake D.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 07-08-2013, 07:49 PM   #2325
flameoutgarrett's Avatar
Send a message via MSN to flameoutgarrett
Paul,
How do I stop from overheating on the 5th level of excitebike on my Nintendo?
I cannot stop hitting the mud patches and cannot set tq! Lol
Team fun-Www.rc-trim.com-Team Speedmerchant-Team Orca-Team Br00d
flameoutgarrett is offline   Reply With Quote
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
