Old 06-11-2013, 06:30 AM   #2281
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
Thanks Troy C.
i was not expecting those temps from a mod. and on asphalt. So im guessing 180 is about the limit. Once at that point start taking timing out?
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 06-11-2013, 07:10 AM   #2282
Gravity RC
Yup, the gear seems pretty good, you may be able to go up one tooth on the pinion or maybe split the difference by going to a 112 from your 114. Get the best fan on the motor possible and boost it up with the speedo. I would keep the boost and the turbo timing the same. I dont know if the values are the same from my speedo to yours but i would start with 15deg each and work up from their. 180deg is safe, 190 is ok, 200+ and your pushing the envelope.
Paul L is offline   Reply With Quote
Old 06-11-2013, 02:38 PM   #2283
Bcholka's Avatar
Hi Paul-Brian from TS,
Quick question about the XB4--do you set yours up on a station??
I understand the importance of a station for on-road but many times I hear people saying it doesn't matter as much for off-road. If you do use a station for the XB I assume its the Hudy 108905??
Thanks!
2-Tekno EB48.2's, 1-Tekno ET48, 1-Tekno NB48, 1-Tekno NT48, 1-Tekno SCT-410, 1-AE B5, 1-AE B5M, 1-Kyosho RT6, 1-Kyosho MP9e TKi, 1-TLR Losi Mini 8ight
Our Awesome Sponsors: Tekno RC, AKA Tires, Dialed Designs Airbrushing
Special Thanks to: Trackside Raceway, Clark R/C Park & RC Scoring Pro
Bcholka is offline   Reply With Quote
Old 06-11-2013, 02:57 PM   #2284
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I see the pictures from ETS and Worlds and its hard to tell what fans top guys are running on their motors. I know the rule in some parts of the world allows 40 mm fans, and for us under ROAR its 30 mm max. Do you have any suggestions? I'm working to make sure I keep my Reedy 4.0/5.0 and HW 3.1 cool for our last 2 series races later this year.
Old 06-12-2013, 08:43 AM   #2285
Gravity RC
Thanks!
Hi Brian, I do use set up gauges on my car but i modified my touring car ones to work. Im not going to say that it is necessary at all but they are nice.
yup the 108905 is the system and i think you might need the 108928 shim as well for the rear axle's
The best fans that i have found are the Superior hobbies one's, the R1 wurks ones and the Gravity RC fan. i feel that the performance of all three are virtually the same, R1 and Gravity are almost the exact same. At Reedy, Marc, Victor and Christopher all went home with one of those three fans and seemed impressed by the flow of them all. I would definitely suggest getting one of those three if you don't already have.
thanks
Old 06-12-2013, 12:04 PM   #2286
Quick question about the new NT1 shocks, I measured them against the T4 shock and are identical from what I can see. The only difference was overall length my guess is due to a longer shock shaft. The specs for the NT1 says they're almost identical except for the shock body and the shaft, what's the difference in the body? And can. Use the T4 shock if I just purchase the new NT1 shock shaft?
Want to know because I always buy an extra set of shocks when I purchase a new kit and already have 2 extra sets for my T4 (3 total), I build them soft, medium and hard so I don't have to do it in the pit and waste time just to not like the feel and have to build all over again.
JOE SI is offline   Reply With Quote
Old 06-12-2013, 12:20 PM   #2287
Bcholka's Avatar
thanks
My vote is for the Gravity RC fan--HANDS DOWN!!!!!
Old 06-12-2013, 12:22 PM   #2288
Chaz955i's Avatar
Did you check part numbers? That may give the answer you are looking for.
Chaz955i is offline   Reply With Quote
Old 06-12-2013, 07:04 PM   #2289
Didn't even think of that, thanks
Old 06-12-2013, 09:26 PM   #2290
Braincell2's Avatar
Hi Paul, I just wanted to say thank you for the interview it was the bomb! Just to note all of you guys that frequent this thread have a lot to be proud and thankful of. This guy is a great champion and promoter of the sport of rc racing. Keep on rising to the top my friend. We need more like yourself. " The RC Guru " for DialedNTV / DialedNRC the Comcasty and Verizon Fios Cable TV networks
Braincell2 is offline   Reply With Quote
Old 06-12-2013, 09:27 PM   #2291
Braincell2's Avatar
If you missed the US number one touring car drive Paul Lemieux's call-in interview tonight. Boy I pitty you! It was most informative. Hey! but guess what you can see it on demand and looped on DialedNTV! As quoted by his himself," man this is an exciting rc show that you have!" " Feel free to call me anytime for future interviews" "Too cool show" (Paul Lemieux 6/12/2013) +1
Old 06-13-2013, 06:48 AM   #2292
Gravity RC
Hi, honestly i dont know, I am yet to have a new Nt1. if you cant figure it out by part numbers let me know and i will figure it out somehow.
No Problem, was fun!
talk to you soon
Old 06-13-2013, 09:03 AM   #2293
The part numbers are different as far as I can see, but I'm not sure f they're different because the T4 part numbers are listed in a set of 2 and the NT1 are listed separately.
IMO they're the same, only difference s the shaft, which is probably longer.
Can't wait till I get the new NT1, the orange makes it look sick
Old 06-13-2013, 11:46 AM   #2294
rramjet's Avatar
Location: Everett WA in the Summer Mesa AZ in the Winter
thanks
OK I give. I can't find a Gravity Fan. Is it a joke I missed?
rramjet is offline   Reply With Quote
Old 06-14-2013, 08:59 AM   #2295
Gravity RC
OK, Did a bit of research. The T4 shocks are different, The Rx8 and Nt1 shocks are the same though. Both the nitro and the T4 shocks are sold in pairs. the shock body's and the shock shafts are different but the seals, caps, pistons etc are the same. so from nitro to electric the shocks will not be compatible in any way.
Hi, Gravity does sell a fan. It is PN GRC:350, A limited amount are available in the first batch, so they may be hard to find. I know RC america has them in stock.
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
