Ask Paul Lemieux, RC America/MOTIV/Gravity RC
#196
But 5000 40C batteries will re-stocked again in market?
In fact i run 13.5T in 8min race.
I saw in photos of Snowbirds, all TP batteries of drivers using in any class are just 50C.
Best regards
Best regards
#197
Thunderpower will continue the 40c line. all the TP packs that i have run perform really well. maybe with the new speedos the guys are liking the 50c's across the board now. ? i have not yet re tested with all of that.
#199
I only ran 50C packs in Mod, which is basically a must have for Modified classes.
I used 40C packs in both 13.5 Touring Car and 10.5 12th Scale. While you'd think the 50C would be an advantage over a 40C in any case... I don't think that's true. The 40C packs felt a little better in the spec style classes. Almost as if there was a little more bottom end. Motors also ran a little cooler as well. I know that's a little hard to believe, but it's true.
And yes Dorian, it's messed up, but TRUE!
#200
I can help with this too as Paul and I are team mates at Thunder Power.
#201
Thanks Schreff
#203
#204
lol
#206
Hey Paul,
Have you try'd the forward motor postion they offer for the EU 009,Just wandered if it helped balance the car or what effect it actually has?
#207
Paul,
I was wondering if a 3mm right hand nitrite rotating shaft attached to a left hand Teflon coated rotating hub, cause too much kinetic energy rotational dissipation in the structural molecular composition of the main power source heat build up?
#210
uuuuhhhhhh, yea.
