Old 02-10-2013, 08:51 AM   #2071
R Dodge's Avatar
Originally Posted by tnewlon View Post
Paul,
First off let me tell you THANKS! It's great how you make yourself available to all of us. Now my questions:
Why do you recommend the blue rotor instead of the green? I have been reading in the 1/12 thread and was told green is the way to go.
Second, where can you get a 70 spur? I run an X12 and I have to run a 74. 72 are never in stock from precision and I have not seen a 70. Tried a 72 from CRC but diff would not tighten up, and yes I also bought new diff balls since it uses smaller ones. Thanks
RW makes spur gears starting at 70 in 1 tooth increments. At Snowbirds I ran between 70-73 depending on tire diameter.
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is offline   Reply With Quote
Old 02-11-2013, 10:45 AM   #2072
Gravity RC
Originally Posted by Peakki View Post
http://forum.teamxray.com/xform/inde...D=71&setup=x12
Did you have one hole in piston or std 2 holes?
Why to raise the side links?
What are RCA green side springs?
And why to have the shock more angled?
I'm having European Championships race next month and I'm struggling with turn-in.
http://forum.teamxray.com/xform/inde...D=72&setup=x12
My setup is that.
The carpet is a bit tricky, not high grip but you really have to drive on power or otherwise the car locks up and the rear end is like with handbrake on.
Very hard to drive on-power/off-power, on every car make on model.
Also, the carpet gets moist from the tire additives and don't get any faster though.
Your Set up looks ok to me. with 12th scales its always the little things. obviously more front camber would help with turn in but it could make it hard to drive. I might try stiffer side springs if i were you.
I raised the links and worked on the football to get maximum travel out of the rear pod. not so much for set up but it seems to work well.
The side springs are a kit that RC America sells, they go quite stiff as sometimes i will even run the black spring (way stiff).
As for the shock angle, Im not really sure to be honest. just felt right to me when building, lol.
Paul,
Hi. Thanks!. a Blue rotor is just where i would start if i had to go racing tomorrow, it is totally possible that a green is the way to go. with the stock motor set ups i just always recommend where i would start BC its impossible for me to test every scenario to really know for sure. So if you have some documented info i would go with that. I think Robby handled your spur gear question.
Originally Posted by pierre johnson View Post
My question to is pointed towards understanding the differance between the two and would like to experiment with them both , but I hear 64 pitch is more popular than 48 pitch and if so could you explain your take this subject. ..team trinity p.j
Hi Pierre, i run 64P when i can, I dont think that you would ever notice a difference on the track but the cars run a bit quieter and your gearing option is much greater with 64P but their is really no other reason.
Originally Posted by andrewdoherty View Post
OT, but see if using an unflanged bearing against the pinned side of the hub lets you tighten down on the CRC 72.
Not sure I follow I don't recall flanged bearings in the diff assembly. Maybe I'm missing what you are saying. I would love to be able to run the CRC diff but tore up an axel trying to tighten it up. It would not work on my sons 12R5.1 either. I now have 2 new assemblies with ceramic balls that I cannot use, ugh. PM me with any info. Don't want this taking up space on Pauls thread.
Im kinda confused on this as well. I have only used the standard xray gear so i dont have any suggestions on the other gears. If you figure something out i would be interested to know for the future though.
Thanks Robby!
Paul L is offline   Reply With Quote
Old 02-12-2013, 07:21 PM   #2073
beavis353's Avatar
Hello,
My name is Justin. Im writing you today to inquire about a full sponsorship with the Gravity RC products.
I'm pretty fast.
I thank you for your time.
beavis353 is offline   Reply With Quote
Old 02-18-2013, 08:43 AM   #2074
Johnny Wishbone's Avatar
Hi Paul,
In your opinion, if changing from a flexi top deck to a stiffer top deck nets better performance on a cars setup, does this mean you're setup is missing something that would make the flexi top deck the one to use? Would you consider a top deck change a big adjustment or a small adjustment?
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 02-18-2013, 10:23 AM   #2075
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Originally Posted by beavis353 View Post
Hello,
I'm pretty fast.
LOL. Yes. I have first witness of incredible Slash 2wd of his speed.
Old 02-18-2013, 10:41 AM   #2076
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Hello,
I'm pretty fast.
Paul, I think Chase can take him.
When are you going to start an Ask Paul Lemieux, RC America/Thunderpower/XB4 thread?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-18-2013, 10:50 AM   #2077
Gravity RC
Originally Posted by Johnny Wishbone View Post
Hi Paul,
Hi. I would consider a top deck change a fair change. i dont test a ton with it though. I would say that the majority of the time i tune the flex to traction and leave it at that (high grip, less flex) (low grip more flex). if teh chassis is too soft or two stiff the car can handle inconsistent, especially in high speed/Load sections.
someday their will be a justin/chase showdown. lol
Old 02-28-2013, 07:44 PM   #2078
Gravity RC
Its Kinda cheating to bump my own thread. But falling to page 6 is Staring in the face of not being relevant, so I must do so. Lol
Old 02-28-2013, 08:07 PM   #2079
Xpress's Avatar
Sorry Sir......I'll do better.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 02-28-2013, 08:10 PM   #2080
Andy w's Avatar
Well, since you bumped your thread I will throw you a easy one.
The only sedan class I have raced is 17.5 blinky but will be getting into mod sedan this summer. Is there a rule of thumb on FDR from a 17.5 to mod. At the track I race at I would normally be at around 4.0. So if I was to go to a 6.5 or whatever mod motor would I go up, down or stay the same?
Andy w is offline   Reply With Quote
Old 02-28-2013, 08:19 PM   #2081
R Doyel's Avatar
Sorry Paul, I'll keep a closer eye on that.
Here's a topic. I just made the switch to mod this year, coming from 17.5 NR. Got any driving advice for me? Thanks, and look forward to seeing you at RROC again this year
R Doyel is offline   Reply With Quote
Old 02-28-2013, 08:23 PM   #2082
R Doyel's Avatar
Good topic!
Old 02-28-2013, 08:23 PM   #2083
Trader Rating: 23 (100%+)
Perhaps the title of off-road specialist means you need two threads now!
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 02-28-2013, 08:28 PM   #2084
Drew Ellis's Avatar
The pain the horrible pain. Lol
Thanks Drew
RCAMERICA-Xray-Hudy-GravityRC-Kopropo-PROLEVELRC-Team EAM-ORCA-P1Brand-AVID-ProlevelRC Raceway-MOTIV-Max Power America-SRC America
Drew Ellis is offline   Reply With Quote
Old 02-28-2013, 08:51 PM   #2085
NolanP's Avatar
Paul do you ever run anything other than a 4.0?
Are you a dad again yet?
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
