Old 02-06-2013, 07:35 PM   #2056
Tekin Prodigy's Avatar
Trader Rating: 55 (100%+)
Paul, so happy I got to finally meet you. Thank you for taking time to help fellow racers at the birds. I was curious if you could inform me what is the motive behind drag brake with mod touring. Do you run any? How much? And how much push brake do you use? Thank You Chad
Xray T4
Tekin Prodigy is offline   Reply With Quote
Old 02-06-2013, 07:42 PM   #2057
rosko's Avatar
I ask kevin h. Same question. Do u prefer U.S. style or euro carpet track
rosko is offline   Reply With Quote
Old 02-07-2013, 01:50 AM   #2058
Peakki's Avatar
Originally Posted by Paul L View Post
Hi Peakki. Having the steering links like that seems to give me a bit more steering in the corner. The other layout which you saw I think was made by Eric Anderson. Alex and i ran the standard stuff.
Do you have some shims between servo and servo mounts, or between links and saver or between servo and servosaver?
I'll try this setting on the weekend.
What about front end settings in general, are you running 3mm longer upper link or something else? Caster?
A setup sheet from the race would be nice
Destiny&V-Dezign 1:12- Sanwa M12s - Xray XB4 2016 - Xray XB2 DE - HW XR10Pro & Team Orion R10.1 Pro & Sanwa Super Vortex Zero Gen2- Team Orion Vortex & Muchmore & Reedy BL motors - Sanwa & Highest & Sav÷x servos
Peakki is offline   Reply With Quote
Old 02-07-2013, 09:51 AM   #2059
Gravity RC
Originally Posted by schreff View Post
Paulie...
2 things...
#1. Ficco wants a rematch in the cheese curl contest. We'll have an official bag ready for you 2 at the Nats.
#2. Where's the fist!?
Hey Schreff.
First off Ficco has no chance in the cheese puff comp lol. I believe the fist in in one of two places, either back on Ehrlich's mantle or in Sweden somewhere, i get the feeling we will know more soon.
Originally Posted by andrewdoherty View Post
I wasn't sure if you saw I would be running a T3'12. Were you suggesting that I use Hardman's set up from last years Birds, or is there another '12 setup you start with?
Yea I missed that. i suppose that Alex's winning set up from the 2012 birds would be good then, Maybe try that.
Hi Chad. No problem!
In Mod TC i always use drag brake. I dont like to use push brake very much so i will use more drag brake than most. I just find it easier to be consistent that way. so if you feel that you are good at using push brake their is less reason to use drag brake. It seems like whenever i run really fast i use very little to no push brake, but the car and layout has to be perfect for me to use none. 15% drag brake is where i would start out with just about any speedo.
Thanks!
Hi. I prefer US style board tracks but only BC that is just what i am used to. Boards allow me to drive more like "connect the dots" to not crash. on euro style tracks i feel like you need to have more fluid lines and it is always a bit hard for me to adjust.
The servo is mounted behind the posts with the ball studs coming out the front of the servo saver. I ended up with 1mm also shimming the ball studs forward more on the servo saver.
Yes i used 3mm's of shimm's to make the upper arm longer (less steering/easier to drive). caster was in the middle.
I will do a set up sheet now.
Thanks!
Paul L is offline   Reply With Quote
Old 02-07-2013, 10:18 AM   #2060
al dente's Avatar
for the record, 11 cheese puffs is all i could fit. paul matched my 11 with room to spare. i am hereby withdrawing from the cheese puff rematch, due to stretched mouth corners, and high cholesterol.
Team CRC / Dumper's Speed Shop / Team Scream Racing / Black Art
RC America / FB/FX / Colorado On Road RC Club
5280 Raceway (5280raceway.com) home of the MILE HIGH INDOOR CHAMPS April 20-23, 2017
al dente is offline   Reply With Quote
Old 02-07-2013, 03:16 PM   #2061
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I had no idea the fist was high in cholesterol!
Always learning something in here... thanks Paul!
Old 02-07-2013, 09:31 PM   #2062
Clint161's Avatar
Hey Schreff.
Thanks!
Is this servo placement for weight distribution?
Clint161 is offline   Reply With Quote
Old 02-07-2013, 10:33 PM   #2063
Send a message via MSN to Racecarguy Send a message via Yahoo to Racecarguy
Paul...which do you prefer? Euro Fist or Americian fist? And is size a deciding factor????
Racecarguy is offline   Reply With Quote
Old 02-08-2013, 07:05 AM   #2064
Gravity RC
Honestly, it just kinda ended up that way and it leaves me more room for my receiver on the speedo side.
lol
Old 02-09-2013, 09:08 AM   #2065
Peakki's Avatar
H
Thanks!
http://forum.teamxray.com/xform/inde...D=71&setup=x12
Did you have one hole in piston or std 2 holes?
Why to raise the side links?
What are RCA green side springs?
And why to have the shock more angled?
I'm having European Championships race next month and I'm struggling with turn-in.
http://forum.teamxray.com/xform/inde...D=72&setup=x12
My setup is that.
The carpet is a bit tricky, not high grip but you really have to drive on power or otherwise the car locks up and the rear end is like with handbrake on.
Very hard to drive on-power/off-power, on every car make on model.
Also, the carpet gets moist from the tire additives and don't get any faster though.
Old 02-09-2013, 09:19 AM   #2066
Trader Rating: 57 (100%+)
I can answer this one. RC America sells a spring kit. http://www.nexusracing.com/product_i...oducts_id=4145 Comes with a little larger set screw, metal spring mount and 5 pair of springs, Softest to hardest are White, Red, Green, Purple, and Black.
PROMODVETTE is offline   Reply With Quote
Old 02-09-2013, 12:43 PM   #2067
tnewlon's Avatar
Trader Rating: 15 (100%+)
Hi. this is all for blinky 17.5. for TC i would go with 30-35deg timing and start with a 3.7 overall ratio. for 12th scale i would also go blue rotor with 30deg timing and gear at a 89mm roll out. with a 42mm tire size that would be roughly a 70 spur with a 47 pinion.
Paul,
First off let me tell you THANKS! It's great how you make yourself available to all of us. Now my questions:
Why do you recommend the blue rotor instead of the green? I have been reading in the 1/12 thread and was told green is the way to go.
Second, where can you get a 70 spur? I run an X12 and I have to run a 74. 72 are never in stock from precision and I have not seen a 70. Tried a 72 from CRC but diff would not tighten up, and yes I also bought new diff balls since it uses smaller ones. Thanks
tnewlon is offline   Reply With Quote
Old 02-09-2013, 06:27 PM   #2068
pierre johnson's Avatar
Location: im from cali but lived in texas most of my life
Default 48 pitch vs 64 pitch
My question to is pointed towards understanding the differance between the two and would like to experiment with them both , but I hear 64 pitch is more popular than 48 pitch and if so could you explain your take this subject. ..team trinity p.j
Team Rctarget /Capricorn America/Reds Racing and Hobby Recreation Products!
pierre johnson is offline   Reply With Quote
Old 02-09-2013, 09:52 PM   #2069
Originally Posted by tnewlon View Post
Paul,
OT, but see if using an unflanged bearing against the pinned side of the hub lets you tighten down on the CRC 72.
Old 02-09-2013, 10:41 PM   #2070
tnewlon's Avatar
Not sure I follow I don't recall flanged bearings in the diff assembly. Maybe I'm missing what you are saying. I would love to be able to run the CRC diff but tore up an axel trying to tighten it up. It would not work on my sons 12R5.1 either. I now have 2 new assemblies with ceramic balls that I cannot use, ugh. PM me with any info. Don't want this taking up space on Pauls thread.
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
