Old 01-24-2013, 10:16 AM   #2041
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
Paul since the hudy race in MO I have changed my set up more inline with ur mod set up from what I was running there . Tho.
In MO I was running ur droop setting u put on car . When I came back to Nashville to run the car I'm thinking had too much traction and after thickening the front oil and raising rear role center mounts (high dot mounts) I had to take 50% of my droop out of car and made it less tippie and had more corner speed .
It seems that the droop change made a huge difference in turning . What is this ?
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 01-25-2013, 09:25 AM   #2042
Gravity RC
Originally Posted by syndr0me View Post
The only way I can get the o-ring to work right is if I put it on the opposite side of what the instructions say, so that it's kind of like a rubber band around that groove rather than sitting in the groove of the other half. And I use a new one every time. I'll give it a try without next build.
Paul, your friends are coming to Denver to race mod sedan. Check it out.
Thanks. I talked to Ficco about it. its possible i could come but ill have to see as it gets closer.
Cool. Im not really sure but i think with thicker front oil you can run less front droop. I think with such thin oil the front end pops up so much under power and runs in to the droop screws hard and fast, then the car dives inconsistent on power, with a ton of front droop that dose not happen with thin front oil. with thicker oil that dose not happen in the first place so you can run less droop. Im not really sure how accurate this is but that is what i am beginning to think.
Paul L is offline   Reply With Quote
Old 01-25-2013, 09:59 AM   #2043
same here use a new one every time and fit it round the opposite side.
i smear with a small amount of rubber grease or the diff oil so that it slides in nicely on assembly and does'nt catch the edges.
T2 SLOW is offline   Reply With Quote
Old 01-25-2013, 06:38 PM   #2044
Hey Paul,
Somewhat quick question, I'm switching to a front gear diff from a spool on a T3 2011. My question is how will the GravityRc 1 mil cst diff fluid effect the handling of the car Vs the 2.5 Mil cst fluid?
Thanks in advance
Rugrat is offline   Reply With Quote
Old 01-29-2013, 08:37 PM   #2045
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Paul,
I've only been able to run Mod on our local carpet track, and a few of the asphalt tracks in our state. I'm bringing my 2012 to run mod at Carpet Nats. Do you have a setup you'd recommend as a starting point, or base set up? I imagine the set up I like here at Mike's wouldn't be optimal for the grip were likely to see at Nats. Best of luck this week.
Old 01-31-2013, 02:48 AM   #2046
hello paul. i am new to rc tech so i hope i make sense and hope you can help me out. i am amember at boronia radio controlled car club in vic australia. recently our 540 class got changed to "blinky". so i purchased a thunder power z3r brushless motor. i am driving the top photon which i am told has an internal ratio of 2.0. my gearing is set at 3.6 (which im told is optimal). the car is reasonably competitive but i would like that bit more. my question is what is the best position on the timing cap? i have it at 0 now but am not sure whether to just jump to 50 or should it be done in small steps. i am just worried about any damage i might cause. hope i made sense. thanks for your time.
simmo9872 is offline   Reply With Quote
Old 02-05-2013, 12:46 PM   #2047
Gravity RC
Originally Posted by Rugrat View Post
Hey Paul,
Thanks in advance
Hi. sorry for the delay, Im fresh back from the snowbirds. The 1million should have the most rotation in the center of the corner, the 2.5million should have slightly less rotation in the center but be a touch easier to drive.
Gotta run, Ill get to the other questions soon.
Thanks!!
Old 02-05-2013, 05:18 PM   #2048
NolanP's Avatar
Paul congrats on re-signing with Xray. Are you coming to the Region 5 race then? As well as gonna run the Chi-Town Shootout with the XB4? Hope to see again soon with your new toy from Snowbirds.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is online now   Reply With Quote
Old 02-05-2013, 07:13 PM   #2049
Hey Paul,
Thanks in advance
Thanks Paul!!! You are the BEST!!!
Old 02-06-2013, 01:58 AM   #2050
Peakki's Avatar
Hi Paul.
Saw a pic of your X12 at the Snowbirds.
It had the steering links front of the Xray servosaver. What is the benifit doing this?
Saw also some pics of Xray X12 cars with different electrics layout & different shock mount and motor upper plate than the current car. Can you tell something about that?
Destiny&V-Dezign 1:12- Sanwa M12s - Xray XB4 2016 - Xray XB2 DE - HW XR10Pro & Team Orion R10.1 Pro & Sanwa Super Vortex Zero Gen2- Team Orion Vortex & Muchmore & Reedy BL motors - Sanwa & Highest & Sav÷x servos
Peakki is offline   Reply With Quote
Old 02-06-2013, 12:07 PM   #2051
Gravity RC
Originally Posted by andrewdoherty View Post
Paul,
To me the best set up was Andrew hardmans Snowbirds set up. I will plan to begin with that at the carpet nats. Im sure if it is not posted it will be soon. Thanks!
Hi Simo. Sorry for the delay in my response. Your gearing sounds pretty close to me also. I would recommend going right to 30deg on the timing setting. I would never run less than 25deg. 30-40 is likely where you will end up. Just keep an eye on the temp, after 5 min the motor should be around 80deg C. warmer than 85deg and you could have trouble.
Hope that helps. Thanks!
Hi Nolan, I would like to do those races but i will not be able to make it to either of them. Thanks
Originally Posted by Peakki View Post
Hi Paul.
Hi Peakki. Having the steering links like that seems to give me a bit more steering in the corner. The other layout which you saw I think was made by Eric Anderson. Alex and i ran the standard stuff.
Old 02-06-2013, 12:52 PM   #2052
schreff's Avatar
Send a message via AIM to schreff
Paulie...
2 things...
#1. Ficco wants a rematch in the cheese curl contest. We'll have an official bag ready for you 2 at the Nats.
#2. Where's the fist!?
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 02-06-2013, 03:01 PM   #2053
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by schreff View Post
Paulie...
2 things...
1. Paul had a large fist shaped object to practice with but...
2. Alex smuggled it out of the country!
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 02-06-2013, 04:08 PM   #2054
Trader Rating: 42 (100%+)
On-point/ EA horsey power/XFactory / Hudy / Tekin / Trinity / KO Propo / Reino's Ragu
mracer is offline   Reply With Quote
Old 02-06-2013, 04:32 PM   #2055
I wasn't sure if you saw I would be running a T3'12. Were you suggesting that I use Hardman's set up from last years Birds, or is there another '12 setup you start with?
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
