Old 01-10-2013, 05:54 PM   #2011
Trader Rating: 57 (100%+)
I'm in the process of changing my T3'12 over from VTA to 17.5TC. There has been a little talk locally about gear diffs in front with some of your silicone in it. Would this be a wise choice or is the gear diff up front better set for mod? Which cst would I want to use with a 17.5 if that is acceptable?
PROMODVETTE is offline   Reply With Quote
Old 01-11-2013, 01:40 PM   #2012
Gravity RC
Hi. it seems as the set ups get more refined the gear diff in front is becoming a better and better option. In Cleveland i used 1million with success and last weekend i used the 2.5million and liked it a lot as well. I dont think its just a mod thing though, if you are currently using a spool i would say that the 2.5million has a better chance of working with your current set up where as the 1 million may take some tweaking to get it to work well.
Paul L is offline   Reply With Quote
Old 01-11-2013, 08:31 PM   #2013
who makes 2.5 million?
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 01-12-2013, 01:27 AM   #2014
Xpress's Avatar
Gravity RC products available at Nexus Racing and other fine retailers.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 01-17-2013, 07:29 AM   #2015
Gravity RC
thanks!
Old 01-17-2013, 09:37 AM   #2016
I just got some of the 2.5 from Nexus and boy does it taste good!
Old 01-17-2013, 06:51 PM   #2017
PMV
What out drives are you using? I just picked up a diff ordered some 2.5mil and need to decide on out drives... Anybody with opinions on the various offerings out there?
jeremybigham is offline   Reply With Quote
Old 01-17-2013, 07:44 PM   #2018
I'll just be using the stock aluminum ones that come in the diff kit.
Edit, started to build it tonight. The stock ones feel pretty weak. The manual suggest the 304971's when using a gear diff up front so I will go ahead and get them while I'm ahead.
Old 01-17-2013, 09:22 PM   #2019
rosko's Avatar
Did paul go to the yokomo ets race?
rosko is offline   Reply With Quote
Old 01-18-2013, 02:14 PM   #2020
Gravity RC
Yup, I would recommend the spring steel ones, that way you will never have a issue and they absolutely last forever.
Nope. Track looks cool though
Old 01-18-2013, 02:50 PM   #2021
Tekin Prodigy's Avatar
Trader Rating: 55 (100%+)
Hey Paul, I wanna pick your brain a little bit. On some setup sheets your consistant with your droop setting (ie: 3mm over ride hieght all the way around on asphalt) but some sheets you might run 5mm front 3mm rear or visa versa. Would you mind explaining what makes you decide to run more front, rear or both? Furthermore, when going to a new track, carpet or asphalt, what is your common starting point? Thank you very much. Chad
Xray T4
Tekin Prodigy is offline   Reply With Quote
Old 01-18-2013, 04:27 PM   #2022
Thanks for the heads up guys spring steel it is...
Old 01-18-2013, 07:42 PM   #2023
rosko's Avatar
Whats the difference in feel of anti-dive using low rc in ff and mid rc in fr vs. Mid rc ff vs. High rc fr
Old 01-20-2013, 09:33 AM   #2024
Gravity RC
Hi Chad. 2.5-3mms above ride height is pretty standard for me. so that is where i would start at a new track, carpet or asphalt. I will say that i think the rear droop can be more important than front droop in terms of steering and overall ballance. i will tune the overall steering of the car with rear droop, 1.5-2mms being the most rear traction, 4mms being the most steering, anything outside the window of 1.5-4mms above ride height is not good for the rear in any scenario. Lately i have been finding that front droop dose not really give a huge difference in steering balance but it does in the way the front rolls. it seems like more front droop kinda rolls up and over more and less forces the car to roll down and in to the track more.
Im not saying it is right for all scenarios but In my latest set up I ran a lot of front droop for two reasons, one to keep the nose of the car from dragging on the track as much (rolled more up and over), 2 because in modified with the super soft oil (300cst 4hole) while accelerating hard the droop would really top out hard and i could feel it on the track, running a lot more droop stopped that from happening. so it is possible that as backwards as it sounds that with a thinner front oil set up you may need to run more front droop.
Obviously this is all subject to change though .
Hi. with this you will want to eliminate the variable of your camber link, so if you do it you will want to take camber gain into consideration and get the inner camber link shimmed to where it would still be the same distance from the lower pin in both cases. if you adjust for that you should notice that when running the antidive overall higher you will have less front end roll. On carpet it would likely be more steering but less forward traction, On asphalt it would be kinda up in the air as to weather you would get more steering or not, but less roll none the less.
Old 01-20-2013, 03:07 PM   #2025
Kropy's Avatar
Send a message via AIM to Kropy
Paul - You are my everything...............And good luck at the Birds!!!!
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
