Old 01-02-2013, 09:48 PM   #1996
Xpress's Avatar
Originally Posted by robk View Post
Pit squiggles fo' life!!!
Any idea where I could come by 3 or 4 sets?
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 01-02-2013, 09:51 PM   #1997
B00t13g's Avatar
Originally Posted by Paul L View Post
yea, but that set up should do in the ball park of 50mph, with rubber tire on that size track you will only get in to trouble trying to go faster than that.
Thanks!
Perfect! Thanks again!
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 01-03-2013, 09:49 AM   #1998
Hey
Billy20 is offline   Reply With Quote
Old 01-07-2013, 08:28 AM   #1999
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Paul it was great running with u and ur crew this weekend learned more in this weekend than I have in past yr. Tks so much for the tips advise and parts u helped me with . Me and my son r both thankful for ur help . What would u say the traction was at drews track ?
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 01-07-2013, 09:30 AM   #2000
Gravity RC
Originally Posted by Billy20 View Post
Hey
Hi Billy!
Hi Justin, was fun and i learned a couple things as well and was happy to pass them along. i would say that the traction was med to high grip.
see ya!
Paul L is offline   Reply With Quote
Old 01-07-2013, 09:36 AM   #2001
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Paul,
Need some of that $10,000.00 a gallon wale sperm....call me.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 01-07-2013, 09:42 AM   #2002
Gravity RC
Here is a link to the best and most recent set up on the T4.
i wouuld reccommend starting with 4deg caster though.
http://forum.teamxray.com/xform/inde...D=126&setup=t4
Old 01-07-2013, 10:11 AM   #2003
How did the front optional arms change the feel of the car .
Justin & Matt Lyons
a800s sanwa m12s
Old 01-07-2013, 11:49 AM   #2004
Would you go heavier on the oil or stiffen anything up if running 17.5 blinky?
Sean B. is offline   Reply With Quote
Old 01-07-2013, 11:57 AM   #2005
Gravity RC
the optional arms made the car have a ton more initial steering. was harder to hang on to for sure but really cut in well.
I wouldnt, i would just start with a less agressive camber setting and 4deg caster to calm the car down for starters and see from their if you need more steering.
Old 01-07-2013, 12:10 PM   #2006
From ur hudy set up what would u do different if u was running on a high bight track ?
Justin & Matt Lyons
a800s sanwa m12s
Old 01-07-2013, 12:59 PM   #2007
Gravity RC
Nothing to start with, not really sure yet. i havent run on anything higher bite yet with that set up. it was pretty good bite their though.
Old 01-08-2013, 10:11 AM   #2008
Tekin Prodigy's Avatar
Trader Rating: 55 (100%+)
Hey Paul, to be straight up, I am HORRIBLE at building my shocks. I'm good at filling with no air and tightening the cap, but then to achieve 25% or less, maybe 10% or 0 rebound, I just cannot achieve that without getting air in my shocks. Is there a special way with the xray shocks that you recommend building them without any air in them? They seem to settle out and with the bleeder caps, end up with no air after sitting for 24hrs, but I'm not sure if that is even possible. Thanks for any advice. Chad
Xray T4
Tekin Prodigy is offline   Reply With Quote
Old 01-10-2013, 05:58 AM   #2009
Gravity RC
Hi Chad, lol. If your not getting any air you are doing something right.
2 things to do if you are not already. First when you put the bladder on try pushing the piston up almost to the serface of the oil before installing the bladder. Second, make sure you push down slightly on the bladder to extend it in to the oil as far as possilble before putting the cap on. Also do not use the foam in the cap. Doing those things should bring the rebound to a minimum and make bleeding possibly net even nessissary.
Old 01-10-2013, 06:04 AM   #2010
Chad as we found out this weekend if u over tighten the cap on the bladder it can rip and soon as u run car air is back in shock and is very noticeable on high bite track .
I rolled the bladder in my finger tips to see the rip ....
Justin & Matt Lyons
a800s sanwa m12s
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
