Old 12-19-2012, 11:52 AM   #1981
Chris Adams's Avatar
As an indoor soccer pro, how do you juggle your time between the field and the track lol
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs
Texas EOS 2017!
Chris Adams is offline   Reply With Quote
Old 12-19-2012, 11:55 AM   #1982
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
Have u ever noticed Jacob blues having this tendency towards the end of their life? I rotate my tires regularly and u would say within the next 3 runs a ring will be all the way around the inside of tire. I have regularly checked my sidewall glue joints also and probably have reglued them all ...
So it would be safe to say that the traction rolling off power (no drag brakes)could be the sudden change in the suspension and side load on tire to cause TR? Paul thank u so much for sharing ur knowledge with us! Have a merry Christmas
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 12-19-2012, 03:32 PM   #1983
hey paul narrow or wide car works best in low traction conditions??thanks man
tamiya-2012nz is offline   Reply With Quote
Old 12-19-2012, 06:56 PM   #1984
Gravity RC
Originally Posted by Leester View Post
Paul, you have a PM.
Lee
Got it, thanks Lee
Originally Posted by samnelso View Post
Good stuff Paul. Thanks for this.
No problem!
Thankfully im so good at Indoor soccer that i don't have to practice. One time i played goalie for both teams we tied 1-1 and i scored both goals. Lol
No problem at all. I don"t think the issue is the tires, whenever i run Jaco Blues they seem to have a very similar pace and feel from run 2-10 or so. Traction roll is normally in the set up, the tweak of the car, or a bound up suspension pin or something like that.
Happy holidays
Hi. I got and returned your PM. Sorry i couldn't be more help.
In general i suppose i would try narrow, wider should be easier to drive but narrower could give more bite. But I don't think it is that general, results would depends on where it is being widened or narrowed.
And like i said, with F1 i would be lying if i had more advice.
Thanks!
Paul L is offline   Reply With Quote
Old 12-21-2012, 04:18 AM   #1985
Paul, you have a PM
Steve P.
srp67 is offline   Reply With Quote
Old 12-23-2012, 06:22 PM   #1986
Adam B's Avatar
What's up buddy? Hope you have a great holiday
Thanks!
Ps. I found the answer to my question in the set up book.
Franchise Racing Products * Fantom Racing * Pro One R/C Tires * RC America/Xray * Discount R/C Store * F1 R/C Lab * NORCAR @ The Gate
Adam B is offline   Reply With Quote
Old 12-23-2012, 08:40 PM   #1987
B00t13g's Avatar
Any chance you could share your settings for your flow? I understand you run tp motors and batteries, any reason you chose them over lrp?
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 12-25-2012, 08:37 AM   #1988
MD
MD's Avatar
Trader Rating: 118 (100%+)
Paul, Happy Holidays to you and your family.
MD is online now   Reply With Quote
Old 12-26-2012, 11:22 AM   #1989
Gravity RC
Thanks!
Great, thanks!. hope your holliday was good!
Hi, how big is the track, what motor will you aim to use?.
I started using thunderpower before they had motors BC i think the batterys are second to none. since i was using the batterys i was involved with them bringing the motors to the market, with me testing the motors i was totally comfortible with the with the progress that we made and now in the product. so i see no reason to use anything different.
Thanks, You Too!!
Old 12-26-2012, 01:43 PM   #1990
B00t13g's Avatar
Thanks, You Too!!
I'm using an Lrp x20 4.5. I'm running at mikes 90x40 I think. Thank you for the detailed answer and now understand your choice fully. Out of curiosity, what oil brand do you use?
Mackenzie Meyercord
Old 01-02-2013, 03:30 PM   #1991
robk's Avatar
Trader Rating: 22 (100%+)
Pit squiggles fo' life!!!
Old 01-02-2013, 03:44 PM   #1992
Gravity RC
Sorry about the delay, i dont know how i forgot about this.
I would go 5,2,0,0,0 geared around 8.2, 20 deg motor timing to start
5 is drag brake, 2 is punch and the timing is all disabled.
You know it!
Old 01-02-2013, 03:53 PM   #1993
B00t13g's Avatar
You know it!
Thank you! Just add power as needed I assume?
Mackenzie Meyercord
Old 01-02-2013, 05:12 PM   #1994
robk's Avatar
Old 01-02-2013, 07:54 PM   #1995
Gravity RC
yea, but that set up should do in the ball park of 50mph, with rubber tire on that size track you will only get in to trouble trying to go faster than that.
Thanks!
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
