Old 06-13-2012, 10:36 AM   #1711
Gravity RC
Originally Posted by artwork View Post
Paul...nice job at the warm up race!
Where you running any new parts or the same old stuff? Your car looked great out there.
Hi. yes their were new parts and i did test many of them and liked some of them. I thought that the set up as a whole was in a different direction that i normally try and work in, so i think that had a lot to do with it. Normally i try and get steering from running less ackermann and stiffer front shocks and such, but with this set up i worked with softer front springs and a lot of ackermann to be easy on the front tires, then i worked more with weight distribution to get the steering back. I think in the end i had a set up that was not tuned in to a corner and had good traction without hurting the front tires too bad. I will post the set up for it worked great even without the new pieces.
Paul L is offline   Reply With Quote
Old 06-13-2012, 11:44 AM   #1712
Paul,
Which motor setting did you use (ratio + motor timing).
Which speedo setting did you use?
I guess you were using a 4.0T.
Hugo is offline   Reply With Quote
Old 06-13-2012, 11:51 AM   #1713
Send a message via Skype™ to orzel24
Thank's Paul to upload the set up.
What is the final weight of your car ready to race?
Also I see you generate a lot of overall traction how you planning to change it for much hotter conditions in the end of July?
Blazej Orlowski
orzel24 is offline   Reply With Quote
Old 06-13-2012, 12:56 PM   #1714
Magnet Top's Avatar
Sifu,
Diffs down ?
Yet again trying to make sure we aren't asleep ?
btw, seeing you drive without sauce at the worlds wasn't surprising.... it reminds me of how good you are at car control... specifically the show you put on at the xray challenge in Portland a few years back, Nearly an entire lap in nitro where you switched on drift mode and counter steered your way around. It was brilliant...
Cheers,
Jake
Magnet Top is offline   Reply With Quote
Old 06-13-2012, 01:26 PM   #1715
Trader Rating: 54 (100%+)
Originally Posted by Paul L View Post
Hi. The two piece front sus mount could help you a bit with steering but i wouldn't only look their, the car is surely tunable without worrying about sus mounts.
I would try adding some shimming to the steering ball studs. by shimming them forward 1mm it will give you less ackermann (tires will turn more equally) and the car should have more on power steering. That is what i would try first, secondly i would try and lay in the rear shocks
I tried the 1mm shim and shock position and it deffinately made the car rotate alot better. The car feels less edgy and its easier to drive. My lap times were alot better, and more consistant this past race.
Jamison R is offline   Reply With Quote
Old 06-13-2012, 03:26 PM   #1716
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Hi Paul,
When you put on a new rear belt in your Mod cars do you start the eccentric centered or a notch lose or tight?
Old 06-13-2012, 03:57 PM   #1717
Tekin Prodigy's Avatar
Trader Rating: 55 (100%+)
Hey Paul,
Was wondering on your 1/12 when you run mod or any class i guess, do you ever use your brakes, like a quick tap at the end of a straight or do you use zero brake in 12th scale? What about drag brake? Thank you!!!!! Chad
Xray T4
Tekin Prodigy is offline   Reply With Quote
Old 06-13-2012, 04:31 PM   #1718
NR
NR's Avatar
Trader Rating: 52 (100%+)
Originally Posted by andrewdoherty View Post
Hi Paul,
Thought I could help on this one, and Sure Paul will confirm.
He runs the rear belt lose and the front belt tight as it gives the car a little more feel and drive I believe.
Nathan
NR is offline   Reply With Quote
Old 06-13-2012, 05:51 PM   #1719
Nathan
Thanks NR. Can you put loose and tight into quantifiable terms for a new belt? ie, front 1 notch tighter than neutral and rear one notch looser than neutral?
I have been running the front tighter than the rear and agree that I prefer it.
Old 06-14-2012, 02:24 AM   #1720
defcone's Avatar
Trader Rating: 15 (100%+)
BLS951, is that the new servo from futaba or just a typo?
defcone is offline   Reply With Quote
Old 06-14-2012, 04:32 AM   #1721
NR
NR's Avatar
2 Notches from the centre notch Fr and Rr
Old 06-14-2012, 07:53 AM   #1722
Gravity RC
Originally Posted by Hugo View Post
Paul,
Hi, I used a 8.5 ratio, with a 4turn 15deg timing. Hobbywing V2 speedo, 20deg turbo, 20deg boost, 500Acc, turbo delay Off. Thanks
1480g is the weight so i am pretty close to that. Im not sure what i will change for the hot conditions, nothing as of now.
Originally Posted by Magnet Top View Post
Sifu,
Diffs down ?
Cheers,
Jake
Hi Jake, yes the diffs are down lol. Thanks!
Great
Hi Paul,
I think 2 notches loose of center. Thanks
Originally Posted by Tekin Prodigy View Post
Hey Paul,
Hi Chad, I try not to use break in 12th scale but sometimes i might in a emergency or a super fast tight 180. but normally no.
No problem
Nathan
Normally yes, Thanks Nathan.
Typo BLS551, sorry
Thanks!
Old 06-14-2012, 07:59 AM   #1723
1480g? That's 100g above the limit!?
And of course ECS in front?
Blazej Orlowski
Old 06-14-2012, 01:35 PM   #1724
Gravity RC
1380 then lol. yes, 50mm ecs in front.
Old 06-14-2012, 01:37 PM   #1725
Trader Rating: 19 (100%+)
I say you go with the 1480 answer and have the competition pounding their heads on how you did it!
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
