Old 01-22-2010, 10:47 PM   #151
Cribbin's Avatar
sorry guys but a serious question here lol
paul,
i have the problem with my car that it will not react like it should, as in change direction quickly and dart around the track. it has plenty of grip, once it is in a corner it is great, plenty of steering and rear grip, but the initial steering is lacking badly. i have tried all sorts of things, like shock oils, sway bars springs etc, and the only thing that i can do to get the steering back is to push the ackermann forwards, but then the car will spin too easily on power. but i then change other things to fix this, and then i have the same problem i did to start with.
what would you do to make your car react faster?
thanks
ben
Bro-Kin Racing Group
X-Ray T3
X-Ray T2 '007
Castle Hill Raceway
Futaba LRP Tekin
Cribbin is offline   Reply With Quote
Old 01-23-2010, 01:36 AM   #152
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
paul,
thanks
ben
lol, turn in sooner lol.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 01-23-2010, 03:34 AM   #153
Andy63's Avatar
paul,
thanks
ben
This is what you can do
you can begin with to have 100% steering on your transmitter.
You can change the caster to less caster for a little more responsive steering.
try stiffer springs. you can also increase your camber in front. but only a small amount.
do you have toe out in front?
softer shock oil can make the car feel more responsive.
hope some maybe helped? sorry paul, but i know your busy
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 01-23-2010, 05:09 AM   #154
TimV's Avatar
Trader Rating: 49 (100%+)
Originally Posted by Stogie View Post
Hey Paul... say you're planning on pulling a friend through the icy Wauwatosa neighborhood streets behind your car on a snow sledding disk. What gauge rope would you recommend, assuming you weren't planning on exceeding, say, 35mph?
Also, would you recommend wearing a helmet for such an activity??
If you want to do it right, use a set of jumper cables instead of a rope. Also, helmets are for sissies.
- - - Express Motorsports - - - MW Designs - - - Mimi Wong Clan - - - Final Thoughts Racing - - -
- - - Team AKA - - - RDsquared - - -
It's the year 2010. Shouldn't vacuum cleaners be quieter by now?
TimV is offline   Reply With Quote
Old 01-23-2010, 05:14 AM   #155
cyclone x's Avatar
haha tim
Chase Chandler
Sponsors:HOTBODIES Express .The Track. Stevo Racing
Cars: VE8, F104 PRO, B4.1, HPI BLITZ, Losi SCTE
cyclone x is offline   Reply With Quote
Old 01-23-2010, 01:55 PM   #156
Gravity RC
paul,
thanks
ben
stiffer springs or more front toe out sounds good too me also, i would hate to change too much since you said that the steering snd grip is good.
Thnaks!.
jumpers sound good to me. and yes i am a sissy, LOL
Paul L is offline   Reply With Quote
Old 01-23-2010, 07:08 PM   #157
ds400's Avatar
Default XII Link
Hey Paul,
did you use your Hudy Tweak on you XII Link? How do you tweak it when using the setup system?
How did you find the car handling in general. Any building advice? Can you post you setup? I am getting the car close to the N.Z nationals and wont have much time to work on it. I un on asphalt low grip without tire additive..
Thanks for your help.
Didier
ds400 is offline   Reply With Quote
Old 01-24-2010, 06:23 AM   #158
Gravity RC
Originally Posted by ds400 View Post
Hey Paul,
Didier
Hi. i dont have a hudy tweak station but if i did i would be using it, the bubble one seems the most accurate to me. I think that the car is good, but i know nothing about asphalt/12th scale, i have maybe raced it 4times in my life. I do have a set up on the xray site, i think its called "testing", but that is for high bite carpet. sorry i couldnt be more help, maybe their is a set up on the site that would better suit your conditions.
Old 01-24-2010, 07:54 AM   #159
trickd122's Avatar
Default Balancing with chassis weights
-Hello Paul
I had a quick question do you use Chassis weights to balance your Nitro car as you do your electric car If not why?
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 01-24-2010, 01:30 PM   #160
Gravity RC
Originally Posted by trickd122 View Post
-Hello Paul
Yea i do, but i can't get it perfect, i run 20 or so grams on the pipe side if the gas tank. but its always a little heavy on the electronics side.
Old 01-24-2010, 02:29 PM   #161
mtbboy's Avatar
Hey Paul.
I ran your recent Trackside setup at our local track today and all I can say is Shamwow.
The car never gets out of shape anywhere.
Very easy to drive the car fast and tight!
It seems to be getting easier to drive as traction comes up as it is a new layout.
If I am running a 009 how many shims if any are needed under the rear link over the hub?
The t3 has a higher shock tower position and I am not sure how it translates to the 009
Thanks again.
Dave.
mtbboy is offline   Reply With Quote
Old 01-24-2010, 04:55 PM   #162
Default XRAY T 2 07
Paul,
I have a T 2 07 how can i use a lipo on that car? It hits the top plate and the rear bracket any suggestions.
joe hose is offline   Reply With Quote
Old 01-24-2010, 07:01 PM   #163
mtbboy's Avatar
Originally Posted by joe hose View Post
Paul,
If I may Paul.
You will need to mill the offending piece of aluminum out of the way.
You will need to use longer screws on the top deck and mount the top deck with the thinnest washers you can get away with.
The next issue is the bellcrank or steering arm.
Raising the deck produces play.
You will need to fit washers in between the bearings it mounts to and the bellcrank itself on the top and bottom of the bellcrank.
I run my 007 in 17.5 with great results
Dave.
Old 01-24-2010, 11:12 PM   #164
Andy63's Avatar
Paul,
i guess you have 6 cell chassies? Then just move the lipo to the right so halft of lipo is outside the chassie. Then you just hook it there. Its not neccesary to move the upper deck anywhere. the lipo fits fine on the 6 cell chassies. just move it more out on the right.
something like this:
http://img223.imageshack.us/i/16072009565.jpg/
Old 01-25-2010, 05:53 PM   #165
Scott B's Avatar
Trader Rating: 43 (100%+)
Hey Paul,
For Mod 12th scale with 1cell lipo what wind motor and rollout do you run??
Thanks,
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
