Old 02-11-2012, 03:56 PM   #1531
R Dodge's Avatar
Originally Posted by JamesL_71 View Post
I noticed Robbie Dodge and Craig Xavier were running the G12s in blinky 12th. What compounds were they running? Did they have any comments on how the cars worked with the new tires and/or setup changes needed vs the typical black/yellow combo often used in 17.5 12th?
Hi James,
Craig and I both are fairly new to the design and characteristics of today's 1/12 so a lot of what we did was trial and error, but for the most part we were pretty successful. Craig preferred the Medium front and rear and pretty much stayed on that the whole week. I tried Soft all around, Medium all around, Medium front/Soft rear and I also preferred Medium all around. We attempted to use the same logic of running a yellow (soft) rear to free the car up, but due to the size of our tires (40mm front, 41mm rear) and the type of rubber the Soft is made of, I feel like the Soft rear locked my car in a little more than the Medium did. I know for Paul, he feels differently about this but he is also running Mod and going at least 2X the speed we are going. The only combination I did not try, that I really wish I had, was Soft front/Medium rear.
I honestly have never run a black/yellow combination of any sort on my car in high bite conditions as I began testing Paul's tires about a month ago when I really started focusing on preparing my 1/12 for Snowbirds. From hearing others talk I am sure my setup is all based on freeing the car up. I know I changed the angle of my dampening tubes to make them more level, I went up from a .018 (speedmerchant) side spring to a .020 and even cranked 1 round of preload on them, I removed some ackerman by moving my inner steering link forward, and added .5 deg front camber. I also prefer the CRC Black Art Audi body, I think it's the R8C as it seems to have less downforce than the Protoform AMR that Paul runs.
Hope this helps!
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy★
R Dodge is offline   Reply With Quote
Old 02-11-2012, 08:08 PM   #1532
Thanks Robbie, very helpful.
Are yall gonna make it to the Carpet Nats in March?
JamesL_71 is offline   Reply With Quote
Old 02-12-2012, 01:16 PM   #1533
R Dodge's Avatar
I would love to, but I don't think the money is gonna work out. Would be cool to use some paragon again!
Old 02-19-2012, 11:31 AM   #1534
Gravity RC
Thanks Robby.
Paul L is offline   Reply With Quote
Old 02-19-2012, 12:31 PM   #1535
Scott B's Avatar
Trader Rating: 43 (100%+)
Paul, Congrats on you're win at the winter Nats.
Can you post you're NT1 setup please??
Thanks,
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 02-19-2012, 01:36 PM   #1536
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
hi paul
i am looking into changing rotor from red to blue what difference would it make
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 02-19-2012, 04:27 PM   #1537
jetbill007's Avatar
Trader Rating: 20 (100%+)
Paul,
Can you help me locate where the o-ring and thin and thick brass washers should be located when re-assembling a Thunder Power motor?
jetbill007 is offline   Reply With Quote
Old 02-19-2012, 10:42 PM   #1538
Infinite 12th's Avatar
Paul, any of your 12th scale car pics from the snowbirds?
Infinite 12th is offline   Reply With Quote
Old 02-20-2012, 11:32 AM   #1539
Gravity RC
Thanks,
Hi, I will have the NT1 set up on the Xray site tomorrow. Thanks
Originally Posted by Craig W View Post
hi paul
Hi Craig. The major difference that you will see is a increase of torque.
with the blue rotor you may want to gear up to get a similar top speeds of the red rotor, then evaluate weather you have more torque or dropped motor temps once you have achieved that same top speed. for the most part i think that the blue rotor is the best all around rotor, but the green and red definitely have their place for more specific applications. Thanks.
Originally Posted by jetbill007 View Post
Paul,
Hi, i shim everything from the bottom of the rotor (no shims up by the sensor). i will add or take away shims from the bottom until i get roughly .2mm end play. Thanks!
I can take some with my phone and try and post them, don't know how good they will be but ill try
Old 02-20-2012, 12:19 PM   #1540
jetbill007's Avatar
Paul-thanks, how about placement of the oring- or not use it?
Old 02-20-2012, 12:27 PM   #1541
Can't wait
That's awesome you won 12th at the birds
Hope to see you do well at the Worlds with it
Kel
Old 02-20-2012, 01:17 PM   #1542
Trader Rating: 19 (100%+)
Hey Paul, could you tell me the advantages/disadvantages to using the 2 piece forward suspension mount on the rear of the car, Im waiting on my car and i didnt know if it would hurt it if i put a 1 piece on if i decided to. Thanks!
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 02-20-2012, 05:09 PM   #1543
Paul, do you ever use front arm sweep? Where does it give you more steering entry,mid or exit. Are you going to post your snowbirds tc setup? thanks
franc furter is offline   Reply With Quote
Old 02-21-2012, 04:45 PM   #1544
spammy's Avatar
paul i am trying to get a t3 2012 through my local hobbie shop and he cant get threw r/c america he calls and email i really need the car i am going to carpet nats.can you look in to it or give me phone numbers or email add. thanks paul
___________
Leighton Lederer
{R/C Plus Salem Oregon}
spammy is offline   Reply With Quote
Old 02-21-2012, 05:14 PM   #1545
RC America's Avatar
Hi Leighton,
If your local shop is RC Plus from your signature, we normally receive faxes from them, but I have not seen any come through in the last week or two. Phone number is the same as always, 214-744-2400, 9-6 central.
- Bryan
RC America is offline   Reply With Quote
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
