Ask Mike Blackstock
#691
hey mike, i gotta question for ya... making caster -4 as opposted to 0 does what for ur car?? and also... what do u do to ur car to give it -2 kickup?
these questions might seem dumb but id really like to know.
#692
I got 2 questions... With the TC3 snowbirds setup, rear tower in front, how are you able to get less than 5.5mm of rideheight?
second, Losi hubs in the rear, which hole?
#693
vtl1180ny, I found that using the TC4 ball cup lower shock ends gives a ton more adjustment range on the shock collars. The ball cup ends are way shorter than the original ends, so u can lower the car alot more. And it takes out all that slop in the original ends that happens when the pivot ball wears.
#694
rear of the 12L4
Anybody know who makes the aluminum left bulkhead (original AE p/n #4541) that Masami uses on his L4????
also, who makes the damper plate (original AE p/n #4530) that both Masami & Blackstock uses??????
can anyone helpme out???
I just received my L4 and already built it other than electronics and setting it up...
#695
hi Mike, nice one with finishing 9th in 19t @ Novak, i assume you were running the Reedy quad?
if so id be intrested in your motor setup, i have tried 180* springs and 767s used by 1 of the UK ae drivers at a recent indoor carpet championship, but felt it was kinda lacking in power hoping you can help
also the gearing of this motor slightly confuses me, i think its quad so i should run a high ratio, but then i think its got a large dia comm so i must gear low, im not really looking for a specific ratio, just an idea of which charecteristic of the motor out weighs the other
thanks for your help
stew
stew
#696
MIKE whos cells are ya running now have you played with the 3700 s yet?
#697
BACK..... Sorry for the long dry spell....
Hi guys I am back... Sorry had some personal stuff to take care of the last few months... Now that is all out of the way. I will be here as often as i can to help as much as i can.... So please post away ...
Mike
Mike
#698
BLACKSTOCK!!!!!!! Where's my password? LOL!!!!
#699
s2.. I ran 767's with a vertical slot with purple springs geared 43/100 with 2.23 tires... Hope this helps...
pony klr.. I run Reedy real time cell's... And no i have not seen the 3700's just yet.. I have heard some rumors of other teams running them in 3300 shrink , but i have not seen them yet...
Mike
Mike
#700
Ok, another stupid question.... I changed the front hubs to the Losi one's. C Hub and Knuckle and now have stupidly silly steering that I never had before... The car has such oversteer it's impossible to drive.... I'm running the 4 deg one's same as I was running with the AE hubs.... I tried every remedy I could come up to remedy the oversteer short of going back to the origional hubs and nothing helped.... Is it just the added ackerman angle or is it more????
#701
vtl1180ny.... YES.. The ackerman angle changes to a much twitchier and agressive feel when using losi blocks... I for one do not use them for this reason alone..... You can play with the ackerman without using the losi block's by shimming the steering rack....
Mike
Mike
#702
Mike
do you run your 12l4 stock?
if not what parts do you use
thanks
Rob
thanks
Rob
#703
TC4 Set-Up
Mike can you please post your TC4 set-up from the Novak race?
Are you running anit-dive in the TC4, what does this do?
Thanks!
Thanks!
#704
cool, thanks Mike
#705
Mike ...what was you set up at the Novak?
