Old 03-08-2004, 12:40 PM   #16
Bigdog, yes, WE do, no go play with your Mini cooper... lol
Currently taking a break from R/C, running 1/1 scale cars, they are cheaper then running Modified TC!!!
Greg Anthony is offline   Reply With Quote
Old 03-08-2004, 01:44 PM   #17
Hebiki's Avatar
Trader Rating: 26 (100%+)
hi mike..
glad to have more factory help. any suggestions for brush / spring combo for the reedy quad mag 19T.
im currently running 767+ w/ the stock spring, 766 - w/a trinity green spring.
what works best on a wide open parking lot track?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
Hebiki is offline   Reply With Quote
Old 03-08-2004, 02:48 PM   #18
Ike's Avatar
Hey Mike, glad to see you start a thread. You don't know me but I used to show up in Grand Rapids (Used to race with Mark Sweeney, Ty Phillips, Ken Pepe, Temmes, etc. in IL) from time to time and was impressed with your driving skills then. You've come a long way and I'm happy to see you stuck with RC with great success, seeing you and the other fast guys race at the Novak race played a good part in my getting back into RC after a more than 10 year layoff.
To the questions...
I've got a 12LW as well as some previous incarnations of the 12L, and trackside is talking about getting a regular 1/12th scale class going. Do you think there is a big difference in handling between the old 12L cars and the current more popular cars. I'm hoping to race the old car and not feel like I'm at a clear disadvantage car wise, then get the 12L4 once it's released, or once I'm sure the 1/12th scale class will remain.
My father races with me as well, and he's never been a very good driver and mainly has a bad case of the nerves. Would you recommend setting up his car to handle the best and just let him sort things out, or is there a way I can make the car drive a lot easier with the sacrifice of potential lap times? Any tips on this are greatly appreciated.
Last question, I recently changed a lot of things around on my car (FT TC3 in stock rubber)) and had been running it for the first few weeks per the manual. I went with copper springs all the way around, the rear tower on the front (with links per your setup on the AE site save for the camber link lower inside) with .030 shims under the tower front and rear, and stayed with 50wt oil in the front and 40wt. oil in the back, and the 2+2 rear block. Also running the droop, camber, caster, ackerman setting per the manual with stock sway bars front and rear. The car felt a little faster but more twitchy. I can get used to the twitchiness, but what can I expect from removing either the rear or both sway bars? Is there any one thing standing out from what you know of my setup that I should change?
Lastly, what do you think of me going with a 1 way on this setup, people keep giving me different advice, but I'm very tempted to try it simply because of the corner speeds I'm used to from racing 1/12th scale, the TC feels sluggish in comparison.
Sorry for all the questions and thanks for any help.
Ike is offline   Reply With Quote
Old 03-08-2004, 03:54 PM   #19
1 Question........
Why are you Soooooooooooooooooooooooooooooo damn fast?
Barry Baker is offline   Reply With Quote
Old 03-08-2004, 04:51 PM   #20
Speedie's Avatar
Thanks for starting the thread Mike and thanks for all the help you have already given us.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 03-08-2004, 05:02 PM   #21
He takes Viagra
Hey Barry did you like Brazil!!!HEHE
rangulo is offline   Reply With Quote
Old 03-08-2004, 05:12 PM   #22
Originally posted by Mike Blackstock
Hey Josh...
We ran the stock springs bent above 180 Basically the stiffest you can find LOL...
As for the setup for trackside...
I ran 70 wt#3's in the front with purple springs rear tower on the front spaced up .030 inside hole with camber link up and short. Droop was 5 and 4 degree's caster with the -1 antidive in the front.. .055 front sway bar -1.0 camber
Rear was 50 wt #3's Purple springs outside hole on tower, short wheel base , Droop at 4 and 3.75 on lr . camber link long and down with losi 0 degree blocks with a silver ball.. -1.0 camber Ride height 5.0 mm front and rear... Also i run the f block in the rear with 3+2 wich gives me about 1.5 toe per side..
If i left something out please tell me...
What about ackerman? From what I saw at the Novak race it seemed that no two had the same. What is your feeling on what ackerman really does. Thanks.
Brian Anthony
Brian Anthony is offline   Reply With Quote
Old 03-08-2004, 05:43 PM   #23
JusBox's Avatar
When's the TC4 coming out.
JusBox is offline   Reply With Quote
Old 03-08-2004, 05:46 PM   #24
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Thanks for opening THAT can of beans again.
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 03-08-2004, 05:50 PM   #25
Ike's Avatar
Can of beans!?!? Wait, what's that smell...
Old 03-08-2004, 06:01 PM   #26
RodneyB's Avatar
Default front antidive
What does the -1 antidive in the front do for the car on carpet?
RodneyB is offline   Reply With Quote
Old 03-08-2004, 07:00 PM   #27
Tech Legend
wyd's Avatar
Trader Rating: 47 (100%+)
Send a message via AIM to wyd
Hey Mike when you ran the rear tower on the front did you space the tower up .030 or did you space up the roll center blocks up .030?
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 03-08-2004, 07:02 PM   #28
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Each of those would do the opposite thing...
Under the tower would lower the roll center, under the blocks would raise it.
USVTA Member #211
Yokomo BD7 (Mod TC), Corally Phi '07 (VTA)
Support Formula SAE - get kids into engineering!
Brian McGreevy is offline   Reply With Quote
Old 03-08-2004, 07:25 PM   #29
Da4head's Avatar
Any suggestions for setup of the 10T Reedy Kryptons such as timing, brushes and gearing (rollout). Would the 10x1 opposed to the 10x2 work better on a tight track?.
Da4head is offline   Reply With Quote
Old 03-08-2004, 07:39 PM   #30
Mike, good job. I like what I see here. I have one recommendation. Don't let Baker help you answer the questions.
davidl is offline   Reply With Quote
Mike Blackstock & Team Assoicated back together again Kropy Electric On-Road 22 07-16-2008 06:18 PM
Where does Mike Blackstock GO next???? RCPIRATE Electric On-Road 104 07-15-2008 06:08 PM
CEFX signs Mike Blackstock Josh Cyrul Electric On-Road 39 05-17-2007 03:35 PM
Team br00d signs Mike Blackstock..... EddieO Electric On-Road 29 05-15-2007 08:24 AM
Congrats to Mike Blackstock on his move back to BIG T Tres Electric On-Road 0 10-26-2005 10:16 AM
SEO by vBSEO 3.5.0
