Old 03-06-2002, 08:03 PM   #1
Default Tamiya Long Arm Suspension Set
Anyone know what this does (I know it makes the car handle better, but how?)? I'm mainly just interested in suspension arm lengths... how does this affect handling?
Potato is offline   Reply With Quote
Old 03-06-2002, 10:38 PM   #2
newracer's Avatar
R/C Tech Charter Subscriber
it has longer suspension arms and shorter hub carriers, changes the whole geometry of the suspension
newracer is offline   Reply With Quote
Old 03-06-2002, 10:39 PM   #3
Trader Rating: 62 (100%+)
in TCS, most TL01 racers have long suspension arms and i guess they can carry more speed in the corners. they are more stable bec of the wider track. the long arm kit also includes swaybars and maybe this makes the car handle better.
purplepro3, jericsm, rnold - any inputs? you have TL01's with long suspension arms, right?
marvi is offline   Reply With Quote
Old 03-06-2002, 11:03 PM   #4
Ok, but is it "the longer the suspension arms, the better" or is there an 'optimum,' a compromise between two things? Does0 there exist a downside to longer suspension arms?
Old 03-07-2002, 02:43 AM   #5
jericsm's Avatar
i'm not too sure about the effects of a longer suspension arm. the hub carriers are more inboard and the pivot points are virtually the same as the original arms.
in theory about suspension arms IN GENERAL, the longer suspension arms the better, IF it increases the track of your car. What is also important is the difference in length between the upper camber link and the arm itself. The bigger the difference, the the camber intake as the suspension is compressed. This is bad, you would want this effect to be minimized.
what the long suspension arm set from Tamiya gave me is a slop free suspension and all the hop-ups that i would have had to buy one piece at a time (stailess steel suspension shafts, adjustable camber links, adjustable tie-rods and front and rear sway bars), in one complete package at a lower price.
jericsm is offline   Reply With Quote
Old 03-07-2002, 04:17 AM   #6
mailboxck's Avatar
Send a message via Yahoo to mailboxck
The tamiya long suspension arms clearly states on the side of its bag that : Will not change track of the car. W/c means that your car wont get any wider. The longer arms allows a better shock response. You can mount your shocks at a bigger angle w/c gives you more progressive steering. And it also gives the car more bite and less steering slop
mailboxck is offline   Reply With Quote
How long are 12L front suspension springs? SkarTisu Electric On-Road 0 01-15-2008 08:10 AM
Tamiya DJ Suspension Pro4 Australia For Sale/Trade 0 02-06-2006 12:01 AM
Tamiya 415 with Long Suspension and extras olhipster1 R/C Items: For Sale/Trade 19 11-06-2005 06:53 PM
Tamiya lightweight suspension - trade for 415 suspension letitroll R/C Items: For Sale/Trade 3 10-19-2004 09:45 PM
Short vs. Long suspension arms. Barry White Electric On-Road 3 07-14-2004 11:57 AM
SEO by vBSEO 3.5.0
