Indoor Track Barricade Materials?
#16
Hey Jim, we are using down spout from Home Depot, which is almost indestructable, the ones we have you can step on and the don't break, but pop back to original form and at $11 for a 10 foot section you can't beat the price. We used to have the road rail system and although it works well the only thing we noticed was it seemed to chunk tires more than usual.
In any matter, to make the corners just make some plugs that fit inside the downspout and have some of it sticking out then cut some puck board in strips the height of the wall and make the reqiured connector curve with a inside and outside wall and screw it to the plug. They will have some give but will give you good track definition.
#19
We're focusing on puck board and plugs right now. Good flexibility and adaptability. Johnny, we're using the same downspout, except ours is getting beat up a little. We have an annual ritual of cutting off the broken ends. Still, it's cheap and it works so we're sticking with it.
Colin, I'm also thinking about ordering the biggest, nastiest plough disc I can't find. Just for you!
Jim
Jim
#21
