Old 12-01-2009, 05:26 AM   #1
AndiF's Avatar
Default Team Orion Carbon Molecular LiPos 5000 45C
Hi there
Is anybody running these LiPos? What are your experiences with them?
I have run mine for two weeks now, and I encountered a major problem. Three packs are showing only 8.24V even after being fully charged. We tried different new packs and also slightly used packs (coming out of the same batch).
After charging, they all drop to 8.24V of voltage. We measured all the three with the same Voltmeter and we have charged them with three different chargers. All results showed the same low voltage after charging.
When running them, the voltage drop is extremely obvious from the start and after 2 min of running time the loss of power is very eminent.
For comparison: an almost 2 years old 5200 35C LiPo marked a nice voltage of 8,42V after charging with the same charger and balancer and is still delivering much better performance after more than 100 cycles...
Did anybody had the same or similar experience?
I can't believe, that the packs are that bad, there must be a major problem with them...I'm using also the new LiPo saddle packs from Orion and these deliver very good performance and full voltage as expected.
What's wrong with the stick LiPos then?
Team Durango Switzerland - Corally - CRC - IRS - Team Associated
AndiF is offline   Reply With Quote
Old 12-01-2009, 08:07 AM   #2
Official's Avatar
Own 3 but one died after about 10 cycles. If people from orion are seeing this, can le me know where to send back for refund or replacement???
Got it online.
Chassis :4WD = CEFX Photon,TA-05|2WD = Xevo, M05PRO, FF-03Pro, Kysho Evola M3, Kyosho V-One RRR Shimo, Team C TC02
ESC :Brushless - Tekin RS-Pro, Keyence Tachyon|Brushed - Tekin FX-Pro
www.hiro-seiko.com ; www.cefx.net
e-mail: officialracing@gmail.com
Official is offline   Reply With Quote
Old 12-01-2009, 03:05 PM   #3
where can you get these from? i kinda wanted to try one...
Double D Donuts is offline   Reply With Quote
Old 12-02-2009, 06:53 AM   #4
Toh WL's Avatar
I been using Team Orion 3800mAH 30C batteries. They are kinda reliable. I was just wondering if the Team Orion Carbon Molecular LiPos 5000 45C are stable or not???
Toh WL is offline   Reply With Quote
Old 01-19-2010, 11:55 AM   #5
Hi,news about these batteries? Are they really good or not? Thanks,regards,Paolo
bazspencer is offline   Reply With Quote
Old 02-24-2010, 11:52 PM   #6
lem2's Avatar
Hi! Can these be charged with a muchmore platinum charger?
i want to use this for my crawler. thanks
lem2 is offline   Reply With Quote
SEO by vBSEO 3.5.0
