Old 03-02-2004, 12:18 AM   #1
xray racer's Avatar
Trader Rating: 22 (100%+)
Default xray diffs- what lube/grease to use
ive been looking around for a while to try and find a GOOD ball diff lube or grease. i used tamita ball diff lube for a while and it was okay and then i was told to use tamiya ceramic grease, but its shit and it just doesnt work well( sorry for swearing)
newayz, i was wondering what all u guys out there use in your ball diffs? brands etc.
and also, how do i PROPERLY rebuild the diff in the xray, do i start from scratch, or can i just take off the seals, unscrew it and clean the balls;spray it. and relube?
any help would be appreciated
Robbie Lloyd
Yokomo * HobbyWing * Sanwa
xray racer is offline   Reply With Quote
Old 03-02-2004, 12:28 AM   #2
AdR|aN's Avatar
Send a message via ICQ to AdR|aN
Tamiya Ball diff grease is the way to go (for me anyway).
Have been using it for a very long time now and never gave me problems. Ceramic grease and meant for other usage. Not inside the ball diff.
AdR|aN is offline   Reply With Quote
Old 03-02-2004, 01:40 AM   #3
lee82gx's Avatar
you're supposed to get a tube of grease in syringe with the kit.
Use that.DONT use ceramic grease as it's more meant for bushings.It contains grains which polish the surfaces.
Also , if you're anywhere near an AE dealer.Get the Stealth Diff Lube.That's the best i've known.
lee82gx is offline   Reply With Quote
Old 03-02-2004, 02:25 AM   #4
Speedie's Avatar
Stealth diff lube is a high quality silicone lubricant. Ive tried a few fancy magic lubes that were supposed to be great on my TC3 diffs and always clean em out and go back to using the Associated stuff.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
diffs for xray cliferton R/C Items: For Sale/Trade 2 06-16-2008 02:26 PM
Tamiya Anti wear Grease or Ceramic Grease..?? TRFTIM Nitro On-Road 6 04-24-2006 10:52 AM
Lube me up. Diffs and Thrust washers!! rayhuang Electric On-Road 8 02-22-2005 12:08 PM
Do you lube your diffs?? Silvercomet Rookie Zone 6 05-21-2004 06:35 AM
Silicone Diff grease, Axle thrust grease holycow Electric On-Road 3 10-25-2003 10:33 AM
SEO by vBSEO 3.5.0
