Old 01-01-2010, 02:40 AM   #16
Default Not a good idea
I tried taking the prop shaft out thinking it would go faster as the power would only go to two wheels.
Well yea the wheels did spin like crazy but the car became uncontrollable it kept spinning even if i tried accelerating it slowly.
Was a failure for me!
UntitledWater is offline   Reply With Quote
Old 01-01-2010, 02:45 PM   #17
dsrbltoys's Avatar
The only way for the front and rear axles to turn in oposite directions is to have ONE of the diffs in BACKWARDS.
When you place a diff into the tub, the diff gear will be on YOUR RIGHT. Meaning at the back of the car the gear is in the right side of the car and the front the gear is on the left side of the car...
Good luck
dsrbltoys is offline   Reply With Quote
Old 01-02-2010, 08:12 AM   #18
BrokenCroW's Avatar
Send a message via MSN to BrokenCroW
when u check the tt-1 gear box, u'll notice there is a tiny plastic on upper part, that thing will lock ur diff gear when u misplace it, so just turn around it and u'll do fine. i just lock my gear perfectly with few metal nut , a left over of my option and it done perfectly.
the only problem to ur tt01 is that u misplace both the diff gear. check it again and u will do just fine
Make ur Life Fun And Memorable
- Tamiya TT01 Drift & TT01E Touring
- Tamiya DF03 MS Offroad
BrokenCroW is offline   Reply With Quote
SEO by vBSEO 3.5.0
