Old 11-24-2009, 05:49 AM   #1
swimbikerun's Avatar
Trader Rating: 100 (100%+)
Default Shock Oil Conversion: Cst not Cst?
I just saw this shock oil chart (see below) published by Sweep and the Cst to Associated Wt conversion seems to be in line. However what I was completely confused was the Cst difference between Sweep & MuchMore. I understand there will be some deviation between brands but I though the point of using Cst was that it's an established common measurement and also linear so why is it way off from these two brands? Is it marketing bashing between Sweep and Muchmore? I can understand deviations of < 100 cst but this?
Shock Oil Conversion: Cst not Cst?-cstchart.jpg
-Xray T4 '16/Xray X12 '16
-2010 Cincinnati Beer Mile Champion
swimbikerun is offline   Reply With Quote
Old 11-24-2009, 05:59 AM   #2
dontfeelcold's Avatar
Trader Rating: 20 (100%+)
Originally Posted by swimbikerun View Post
It is marketing bashing between Sweep and Muchmore?
As long as you use the same brand you cant go wrong, I am a big fan of the Cst rated oils now, much finer tuning.
You would have to do your own testing to see if there was any difference.
Any one have a RC shock dyno?
dontfeelcold is offline   Reply With Quote
SEO by vBSEO 3.5.0
