Old 02-28-2004, 06:24 PM   #1
FlyinGT's Avatar
Send a message via AIM to FlyinGT Send a message via Yahoo to FlyinGT
Default how do i find out my final drive ratio??
....... Im running a TA 04 R tuned Chassis ...and i want to find out wat my final drive ratio is ?? can anyone help me !!???
i already kno how to find out my gear ratio ..??
FlyinGT is offline   Reply With Quote
Old 02-28-2004, 07:15 PM   #2
fatdoggy's Avatar
R/C Tech Charter Subscriber
Spur/pinion x internal gear ratio (ta04's is 2.133)
The internal gear ratio is the ratio of the pulley teeth(big/small)
fatdoggy is offline   Reply With Quote
Old 02-28-2004, 07:18 PM   #3
popsracer's Avatar
# of Spur Gear teeth ~ # of Pinion teeth x Transmission Ratio = Final Drive Ratio (FDR).
If you are running Foam tires, some people like to calculate rollout also. Otherwise with Rubber tires the FDR is all you need.
popsracer is offline   Reply With Quote
Old 02-28-2004, 08:40 PM   #4
Default gearing (fdr)
you can also check out ... www.gearchart.com .. there you will be able to get charts for roll out and 64, and 48 pitch charts which will help you at diffrent tracks for gearing...
Mark Barden .
mb racer is offline   Reply With Quote
Final drive ratio Starteur Electric On-Road 2 02-04-2008 06:33 PM
Final Drive Ratio on TRF 414 Arun Electric On-Road 8 03-03-2004 03:28 PM
Final Drive Ratio ??? FlyinGT Australian Racing 3 02-28-2004 11:06 PM
Hpi Mt Final Drive Ratio??? True R/C Racing Electric Off-Road 0 02-28-2004 10:10 PM
Final Drive Ratio Pandora's Box Electric On-Road 6 08-07-2003 01:13 PM
SEO by vBSEO 3.5.0
