Carbon Fiber?
Carbon Fiber?
Does anyone know where i can get carbon fiber plates?
The Penguin c/f is excellant quality.
NOT THICK ENOUGH
The penguine stuff isnt thick enough for todays chassis, i bought some 2'x2' 3 mm thick for $200 making 6 chassis out of it all. Wait and see what this car is going to look like... KILLLLLERRRRRRR TC3..
This aint no BMI-DEMON Copy cat chassis, this is a chassis that has proper balance front and rear, and side to side.
This sell carbon in many thicknesses...from paper thin to 3mm+
http://www.robotcombat.com/marketplace_carbonfiber.html
the paper thin sheets are great if you want to re-surface old graphite or change the color of black graphite to another color..
Edward, post some pics when you are done, thanks.
Re: NOT THICK ENOUGH
And yes-lets see your bad ride!! A pics worth a 1000 wirds you know!!
Ray
Thicker than 3mm?
I couldn't imagine how much thicker you'd want? A BMI with the 3mm chassis and upper deck is just about as stiff as it gets.
Good luck with that...at some point it can't get much stiffer.
There's always the mentality, "If two viagra are good, just imagine how good 10 would be?"
EHEH
rayhung:
I dont mean to offend BMI or DEMON chassis, there sick looking and prove on the track . I just took a different direction then the Demon and BMI chassis desgin's..
Ill get some pictures up around march, going to start production around March 14th.
Thanks guys
Picker-dink
Thanks guys
Picker-dink
