Duo 2 13.5 tight timing ring
I recently got a 13.5 Duo 2 but the timing ring seems really tight. I can move it from the default middle position clockwise to almost the last timing marking to reduce timing but can only move it counterclockwise 1 mark to increase the timing.
Is there a trick to advancing these motors to the full timing position? Taking the timing cover off it looks like the sensor plug is binding on the slot it rotates in.
Any ideas on how to fix this or is this normal for this motor?
Err.... besides the 2 screws at the back of the motor, please don't forget to loosen the 3 screws at the front of the motor slightly too!! With the loosened, you should be ok.
Hope this helps.
Cheers!!
Hope this helps.
Cheers!!
Check to see if any of the windings are getting in the way of the rotation of the timing ring.
I had the same problem with a Duo 2 17.5. I had to take it apart and push one of the windings back into place before the ring would rotate freely in both directions.
Thanks. I'll give those suggestions a try.
Hi,
I have a new Team Epic DUO 2 17.5T (red can).
(1) Just wondering which screws do what
There are the:
-- three black, hex head screws at the shaft end
-- three silver, star head screws at the sensor lead end
(2) If I take it apart, is there something I should be really careful with
Thanks in advance
There are the:
Thanks in advance
I've now got the timing ring able to go from almost -40 to almost + 40 now.
I had to take the motor apart and what I found was that the anodizing on the C shaped part that holds the timing ring and cover on looked a little rough. It wasn't able to rotate through the timing range fully. I sanded down the edge of this and it was a lot better. I'm now 1 mark away from full timing counterclockwise. I need to sand a bit more down to get the full range.
Kinda makes me wonder about Epic's statement that they test each Duo 2 motor at the maximum timing setting and then post the dyno sheet on the box. There's no way mine could have been tested at maximum timing unless they used a different timing ring to get the dyno numbers and then put my current one on.
Really not too impressed with the quality of this motor. Hopefully the results on the track don't reflect the build quality.
