Old 02-22-2004, 11:58 PM   #1
FlyinGT's Avatar
Send a message via AIM to FlyinGT Send a message via Yahoo to FlyinGT
Wink Torque Steer ??trouble
I am having trouble with torque steer with my TA 04 R chassis
coz when im going slow it goes straight ...But when i use full throttle i start to veer to the right ..!!
an it starting to get annoying ...can anyone give me advice on wat i can do to fix this problem ........
as u can see im all new to this so any help will b welcome ...!!
FlyinGT is offline   Reply With Quote
Old 02-23-2004, 12:50 AM   #2
fatdoggy's Avatar
R/C Tech Charter Subscriber
* Check all your bears are free.
* Check your droop settings.
* Make sure your right side shocks are the same length as the ones on the left side for each end of the car.
* Check your front toe settings and also make sure you don't have any bent pins that are hampering suspension movement.
fatdoggy is offline   Reply With Quote
Old 02-23-2004, 02:19 AM   #3
sosidge's Avatar
- Check the chassis is straight (the top deck could have been screwed on out of line, twisting the car)
- Check that the steering assembly isn't excessively loose or sloppy.
Furthermore, I have a little guide to setting tweak on my website here. It's for a Yokomo SD, but the principles for setting the suspension are the same. It may help.
Old 02-23-2004, 09:19 AM   #4
check for binding in the wheel bearings. and drive line.. also chk ball cups if worn they will cause servo not to center with the steering .. chk shocks . you might have a dead shock on one side of your car and make sure you car is tweaked correctly...
Mark Barden .
mb racer is offline   Reply With Quote
Torque steer and slipping rear diff issues... Syber Serulean Electric On-Road 24 01-31-2008 01:39 PM
What is Bump Steer? slrguy Electric Off-Road 10 12-29-2004 09:36 AM
Torque Steer wolfracing Nitro On-Road 32 09-07-2004 09:02 PM
Torque Steer? or could it be something else? Smoke21 Electric Off-Road 5 12-07-2003 12:01 AM
Under steer... i hate it teamsherman Rookie Zone 4 02-15-2003 11:00 PM
SEO by vBSEO 3.5.0
