Old 02-22-2004, 04:32 PM   #1
FlyinGT's Avatar
Send a message via AIM to FlyinGT Send a message via Yahoo to FlyinGT
Default SPurs gears ??
Yeah AFter getting my TA 04 R Tuned chassis i have had problems using the 64 pitch spur gears an pinions(due to surface) and i want to know if i can use 48 pitch ones instead ??
An also can some one help me a find a gear ratio's chart for both the 68 and 48 pitch ... coz the one they gave me seems limited ??
FlyinGT is offline   Reply With Quote
Old 02-22-2004, 05:45 PM   #2
WC's Avatar
Trader Rating: 28 (100%+)
Yes, replace both spur & pinion and you can use any standard spur gears & pinions on your 04; Robinson RW, Kimborough etc make good ones for 48dp.
Gear ratio is: (spur / pinion) X (32/15)
When buying 48dp spurs, find something around the 75-82 size.
That will allow you to use 48dp pinions from 28 to 35+.
WC is offline   Reply With Quote
WTB: Rc10t4 Spur Gears, And Pinion Gears Associated-08 R/C Items: Wanted to Buy 0 03-10-2008 08:19 PM
1/10th Pan Car Setup - CORALLY C10X - Gears, Gears, Gears? paul73rc Oval, Larger Scales and More 4 04-06-2007 09:10 PM
prs spurs gears racer43 Electric On-Road 6 01-23-2007 05:10 PM
F/S Spurs gears - Brand new! Snowy R/C Items: For Sale/Trade 0 12-13-2005 03:30 PM
gears, spurs, pinions????? zachzachz Rookie Zone 21 08-20-2003 12:08 PM
SEO by vBSEO 3.5.0
