largest pinion?????
I think 31t or 32t is about the biggest you can go with 72t spur. like said above grab a 60t rrp spur gear. part number rrp1860, tower has them. no you will not be able to run smaller than 29-30t pinion with the 60t spur. hope this helps.
phil
phil
A little heavy, but should work.
